Old 05-07-2013, 03:20 PM   #376
NEWFISHER
NEWFISHER's Avatar
Re: 1949 Chevy 3600 into a daily driver
Send it to Oregon, I have nothing to work on and driving my wife nuts wanting to buy another project. She says sell one to fund the next....I just can't!
NEWFISHER is offline   Reply With Quote
Old 05-07-2013, 05:30 PM   #377
Red Foreman
Red Foreman's Avatar
Coach knows how to take awesome photo's!
RIP John (Lambis), my beloved Father & best Friend.
My Build 56 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=486721
Red Foreman is offline   Reply With Quote
Old 05-08-2013, 02:56 PM   #378
Coach529
Coach529's Avatar
A little headway last night.
Master Cylinder bench bled. Truck jacked up and on jack stands.
Master cylinder installed and I double flared a couple small sections of brake line!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 05-08-2013, 03:05 PM   #379
Dan in Pasadena
Dan in Pasadena's Avatar
Bit by bit, Coach. Bit by bit.
You know how you know you've got a cool truck? Yours looks good with the wheels not even touching the ground! Lol.
Dan in Pasadena is offline   Reply With Quote
Old 05-08-2013, 05:16 PM   #380
Coach529
Coach529's Avatar
Baby Steps!!
1949 Chevy 3600
Old 05-11-2013, 04:29 PM   #381
Coach529
Coach529's Avatar
Plugging along!!
Brake light, tail light and blinker wiring ran to back of truck.
Front end completely greased and cotter keyed.
Brake lines ran. Started the bleeding process and am having a heck of a time with the prop valve tripping. I am just going to order the tool to keep it centered and some speed bleeders to ease the process
1949 Chevy 3600
Old 05-14-2013, 09:43 AM   #382
Coach529
Coach529's Avatar
Last nights progress.
Drivers side front shock is mounted.
Peal and sealed the roof in the cab.
Got a good game plan for building my rear shackle mounts which I hope to work on today after work!!
1949 Chevy 3600
Old 05-14-2013, 10:05 AM   #383
mknittle
mknittle's Avatar
You can finish mine if you like
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 05-14-2013, 10:08 AM   #384
mknittle
mknittle's Avatar
He does have an eye for composure for sure. Looks as if he may be a photographer.
Mark
My GMC build.
Old 05-14-2013, 10:20 AM   #385
Coach529
Coach529's Avatar
Thanks for the compliments. Just a normal guy with an expensive camera.
1949 Chevy 3600
Old 05-15-2013, 10:01 AM   #386
Coach529
Coach529's Avatar
Short night last night as well..
Verified my temp gauge was working. All seems OK. Little 216 just takes awhile to get warm enough to move the gauge!!
Starting stripping the doors down and prepping for a EZ latch install. Got the drivers side 90% done. What a great product!!
http://www.triquemfg.com/Altman-Easy...ck-p/ael07.htm
1949 Chevy 3600
Old 05-18-2013, 09:57 AM   #387
Coach529
Coach529's Avatar
And the rear suspension is finally finished!!!
Got some time this week to weld up some rear shackle mounts and welded them on Henry yesterday after work. I also welded on some square tubing for my bed mounts.
Goal for the weekend. Get this baby off the jack stands and on the ground and get the bed mounted.
1949 Chevy 3600
Old 05-18-2013, 03:42 PM   #388
Dan in Pasadena
Looks good, BUT...I gotta ask:
1. Why go to the trouble; why didn't you use the original shackle mounts?
2. Will those "L" mounts withstand the torsion they're gonna see or should you put triangular gusset plates on them?
3. Installing them there moves the leaf springs CLOSER to the tire, thus limiting the width tire you can use. (Or maybe that's of no issue cause you're sticking with narrow, original sized rubber?)
Sorry to sound like a critic. The work looks first class to me and maybe you explained elsewhere in the thread why this was necessary and I just missed it(?)
Old 05-18-2013, 06:24 PM   #389
Coach529
Coach529's Avatar
These springs were originally out of an S-10, made to mount under the frame. With the narrow 3600 frame, I decided to mount them outboard like the original springs.
I may have overlooked the load on them. Rookie builder mistake. I think I have a solution.....I will post some pictures later.
I have 235/70-15's mounted and they are not even close to the springs. Plenty of room.
No problem critiqueing my work...........I am just learnin
1949 Chevy 3600
Old 05-18-2013, 06:34 PM   #390
Dan in Pasadena
Thanks Coach. I didn't mean to come off sounding like a 'hole.
Your work looks a LOT better than someone "just learnin" to me. I couldn't do it....add it to the list of things I can't do yet. lol.
Old 05-18-2013, 09:52 PM   #391
Coach529
Coach529's Avatar
Didn't sounds like a "Hole" at all Dan!!
Attached are a couple pictures and what I will hope will handle the stress.
1949 Chevy 3600
Old 05-18-2013, 10:28 PM   #392
NEWFISHER
NEWFISHER's Avatar
Dan, the 3600 frames are 10 inches narrower than a 1/2 ton AD or TF truck. That may be throwing off the tire to leaf thing you are wondering about.
Old 05-18-2013, 11:26 PM   #393
Dan in Pasadena
Oh, ok I didn't know that. I know little about the A.D. trucks -as is apparent.
I just didn't want to see Coach get it all dialed-in only to have stress cracks (or worse!) after he got it back down on its wheels. I meant to be helpful but when I went back and re-read it I thought I sounded critical. The LAST thing I'm qualified to be of anyone else's fab work.
I wonder WHY the bigger trucks have a narrower frame? My only idea is the same frame served double duty as the frame for a dually A.D. back when they were new??
Old 05-19-2013, 07:40 PM   #394
Coach529
Coach529's Avatar
Overbuilt to the max!!
1949 Chevy 3600
Old 05-19-2013, 08:28 PM   #395
Red Foreman
Thats what you call structural engineering!
My Build 56 GMC
Old 05-19-2013, 10:29 PM   #396
Coach529
Coach529's Avatar
This weekends achievements:
Drivers door latch is done inside and out. Weather stripping also done. So impressed with the Altman kit. Easy to install and the doors latch so nice.
Bed is installed and loose bolted along with passenger side fender and splash guard between running board and bed.
Fiddled around tonight putting the seats bases in and cleaning up stuff. Spent some time with my 1 year old on my lap making motor noises and trying to honk the horn. Life is good!!
1949 Chevy 3600
Old 05-19-2013, 10:42 PM   #397
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
lookin real good coach.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 05-19-2013, 10:43 PM   #398
Coach529
Coach529's Avatar
Thanks......that means a lot. I am REALLY happy with how it is turning out!!
1949 Chevy 3600
Old 05-20-2013, 12:42 AM   #399
NEWFISHER
NEWFISHER's Avatar
+1....your doing great job!
Old 05-20-2013, 09:30 AM   #400
Coach529
Coach529's Avatar
Thanks Fish!!
1949 Chevy 3600
