05-03-2020, 09:56 PM | #376 |
Re: Dumptruck Dolly
Worked on the motor some more. The headers came from my C10 but hung too low, so I get to put the Doug Thorley’s on Dolly...hope they clear everything. I am waiting on a water pump and a thermostat housing that clears the oil filler.
05-04-2020, 06:10 AM | #377 |
Re: Dumptruck Dolly
Nice!!!
71 C10 72 K20 72 K10 Super Kirk |
05-04-2020, 08:59 AM | #378 |
Proprietor of Dale's Corner
Re: Dumptruck Dolly
The motor is pretty!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
05-04-2020, 11:13 PM | #379 |
Re: Dumptruck Dolly
Thanks guys...
05-05-2020, 06:28 PM | #380 |
Re: Dumptruck Dolly
Nice work, and continued progress.
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692 70 C-30 Tow truck AKA Highlighter 02 Silverado 2500 HD CUCVII Tow Rig/DD 1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800 1980 Buick Regal Dirt Stock car |
05-12-2020, 10:35 PM | #381 |
Re: Dumptruck Dolly
05-12-2020, 10:53 PM | #382 |
Re: Dumptruck Dolly
Great Progress.
I just noticed / You really like those Extended T wing & Y wing hold downs. I will share a trick I learned. Once you get the Engine (Broke in) / (Warm-Up) and (adjusted). It is a good idea to put a Touch of silicone on the inside of those T-Wings. So the next time you raise the hood they will be there. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
05-15-2020, 09:29 PM | #383 | |
Re: Dumptruck Dolly
I’m using them here because I pulled them off a different project which will no longer be needing them...I didn’t want them to go to waste. |
05-15-2020, 09:48 PM | #384 | |
Re: Dumptruck Dolly
I really like those for the looks. Years ago ,/ I had a set of those. I raised the hood and (WHere did they go) . Luck had it. / It was laying on the upper A-Arm. .
06-01-2020, 07:10 AM | #385 |
Re: Dumptruck Dolly
Water pump, intake, thermostat housing finally put on...robbed another small block for the carb. Slowly coming along...
06-01-2020, 07:32 AM | #386 |
Re: Dumptruck Dolly
That's fine looking engine
06-01-2020, 09:35 PM | #387 |
Re: Dumptruck Dolly
06-07-2020, 11:40 PM | #388 |
Re: Dumptruck Dolly
Ordered new flywheel, clutch, pressure plate, (with throw out bearing) from my local parts retailer, but they included the wrong throw out bearing...have to wait a bit.
06-20-2020, 05:41 PM | #389 |
Re: Dumptruck Dolly
Another step closer...
06-22-2020, 01:04 AM | #390 |
Re: Dumptruck Dolly
Oh man that's a beautiful thing. God bless Chevy orange!
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
06-22-2020, 06:47 AM | #391 |
Re: Dumptruck Dolly
06-22-2020, 09:20 AM | #392 |
Re: Dumptruck Dolly
Looks great...
06-23-2020, 01:58 PM | #393 |
Re: Dumptruck Dolly
07-09-2020, 11:25 PM | #394 |
Re: Dumptruck Dolly
We have lift off today...I’ll be able to clean the frame and paint it, and then drop the drivetrain in all at once.
07-09-2020, 11:31 PM | #395 |
Re: Dumptruck Dolly
I found a pair of old skool cool pipes that I think I’ll add to the exhaust.
Also ordered and received some Warn lockouts. |
08-03-2020, 11:10 PM | #396 |
Re: Dumptruck Dolly
Got back to the frame...found a common spot on both the 3/4 and 1 ton frames. Measurement was made from the 3/4 ton and transferred to Dolly’s frame. The 2 1/8 “ location is the front bolt hole for the V8 crossmember.
08-03-2020, 11:19 PM | #397 |
Re: Dumptruck Dolly
Hey, check out the bottom hole that lined up after drilling the top holes...made me feel feel like I did something right.
08-03-2020, 11:24 PM | #398 |
Re: Dumptruck Dolly
After a little paint and some grade 8 hardware...
08-03-2020, 11:44 PM | #399 |
Re: Dumptruck Dolly
I got rid of the 2wd driveshaft and the 6 cylinder exhaust and cleaned/painted under the cab. Next time I’ll get rid of the transmission crossmember that’s used with the 292.
08-04-2020, 08:21 AM | #400 |
Re: Dumptruck Dolly
Looking good, starting to come together.
