Old 02-16-2020, 06:24 PM   #376
Robert Haas
Re: Two is easier then one 1965 GMC S/W/BB build
last shots for today, just some over views
Hope I didn't bore you. We have other stuff to show (Body work and custom fabrication going on in the engine compartment and cab) Will post that up when it looks less messy.
Our 1965 GMC big block pro mod build http://67-72chevytrucks.com/vboard/s...d.php?t=746098
Robert Haas is offline   Reply With Quote
Old 02-17-2020, 10:41 AM   #377
slimjim66
Nice!!!! love this build. Not over the top, you might have said it in a earlier post but how much power does that BBC have?
slimjim66 is offline   Reply With Quote
Old 02-18-2020, 10:41 AM   #378
Robert Haas
Jim, thank you for showing enough interests in our build to ask a question. It seems the builds side of this forum is mostly a place for folks to blog about their travels and what they cooked for dinner.
Motor was started and run in on a engine dyno and made 570 and change with a dual plenum intake and a 850 Holley. We will be using a open plenum air gap style intake and see if the Holley can keep up. Expect to make close to 550 at the wheels.
Old 02-18-2020, 01:41 PM   #379
pdxhall
pdxhall's Avatar
Beautiful work!
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 02-18-2020, 08:50 PM   #380
slimjim66
so awesome, are you using some sort of scoop on that trans cooler to grab the air or just relying on the fan to draw it through? im in the process of doing a trans cooler on mine, i guess a scoop and a fan wouldn't hurt.
Old 02-19-2020, 10:33 AM   #381
Robert Haas
Transmission coolers like the one we chose do exactly what the transmission needs and that is to dissipate extreme heat. The transmission actually needs some temperature in the fluid(this is why stock coolers run inside the radiators so they can actually heat the fluid in extreme cold conditions) Our fan has a thermometer that turns the switch on at a pre-determined setting and having the cooler mounted above the exhaust system should aid if this truck is ever operated in extreme cold.
Of course this is just theory and experience speaking. I have no formal data or education in thermal dynamics or fluid viscosity parameters
Old 02-21-2020, 08:51 PM   #382
Robert Haas
Nobody builds a instrument panel that is worth a damn for the GMC's so I will build my own.
Old 02-25-2020, 10:42 AM   #383
Robert Haas
Little more work done, broke the X axis in the mill so have been working on that repair.
Old 02-25-2020, 11:28 AM   #384
Duncan K
You gotta have $100 worth of aluminum chips on the floor. It always hurts to machine over 50 % of the material away to make a part.
What mill are you using?
66 GMC 910
My Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=754257
Duncan K is offline   Reply With Quote
Old 02-25-2020, 11:31 AM   #385
Robert Haas
More like 85% by the time I am done.
No other way to machine it to attain the final dimensions I need.
mill are you using?
It is a monster.
Built in the late 1970's on contract to the US Govt.
It is a DEBER US 120
has twin spindles and a compound table to do tapers (You will see that feature when I get this beast back up and running.
Old 02-26-2020, 11:10 AM   #386
88Stanger
88Stanger's Avatar
Goodness, what a beautiful build!!!!
88Stanger is offline   Reply With Quote
Old 02-26-2020, 11:38 AM   #387
Duncan K
That is a really sweet machine! Not much you cant do on that one. I just picked up a Bridgeport from the 60's. Having fun learning to use it making a few parts for my truck.
Keep the posts coming, love following such a custom build.
66 GMC 910
Old 02-26-2020, 10:23 PM   #388
Robert Haas
So I got the mill back up and was able to get to the part ready to be bored for the 7 instruments it will hold. I showed a picture of the cool part of my mill where I can swing the x/y axis and cut tapers. That allowed me to machine the sides at the 7 degrees from vertical.
Old 02-27-2020, 08:30 PM   #389
Robert Haas
Well the first phase is complete. Still need to add the bottom and get the steering column notch completed as well as final facing.
I'm pretty glad to have this off the mill for awhile.
Old 03-29-2020, 01:56 PM   #390
Robert Haas
Machining on the dash insert is complete. Now need to get it mounted.
It is just sitting close to its final location in these pictures. It will actually be about 5/16" higher in the dash when complete.
You can see the lower panel We fabbed that will be the location of the new switch gear.
Old 03-29-2020, 03:19 PM   #391
Robert Haas
comparison to original GMC dash insert
Old 03-29-2020, 03:24 PM   #392
Robert Haas
What makes this so different (other then the increase in size and the ability to relocate or even delete some of the switches and knob) Is the angle our gauges will be laid back at. The original they were aimed at the drivers chest. Now they are in perfect alignment with the drivers point of view. It is subtle but very noticeable in application.
Old 03-29-2020, 03:42 PM   #393
Very nice. I really like the looks of those dash bezels/inserts.
Old 03-29-2020, 03:52 PM   #394
SkinnyG
SkinnyG's Avatar
Will the lights from the gauges reflect up onto the windshield at night?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 03-29-2020, 04:13 PM   #395
Robert Haas
They shouldn't. they have their own built in bezels as well as they are dimmable.
Old 04-06-2020, 02:34 PM   #396
Robert Haas
Not that anyone actually looks at this thread anymore but here is the new dash bezel and the custom one off under dash rolled pan that will hold the AC ducts as well as hide the underdash.
Old 04-06-2020, 03:33 PM   #397
floormonkey
looks great, as usual. how much does that gauge panel weigh now?
Similar to your roll pan, I saw a guy at Lone Star Nationals who took a spare dash, cut it in half length-wise, flipped the top half upside down and welded it to the bottom of the dash.this made the shape of the dash be mirrored on top and bottom. It gave him a slot/shelf to store stuff in and he put his vents in that.
floormonkey is offline   Reply With Quote
Old 04-06-2020, 05:34 PM   #398
Robert Haas
Less then 2 pounds.
30 gallon barrel of chips widdled away
Old 04-07-2020, 08:53 AM   #399
slimjim66
man that dash looks good, great work
Old 04-07-2020, 11:02 AM   #400
Robert Haas
Comparing what we are building to what I built 20 years ago is illuminating.
