08-07-2020, 12:25 AM | #376 |
Re: My 1970 GMC Project
Has anyone else noticed that the view counter appears to have stopped quite some time ago or is it just something on my end?
08-07-2020, 08:28 PM | #377 |
08-07-2020, 09:11 PM | #378 |
Wow, I don't think I would have ever taken one on in that shape. I've primarily got to weld up the 50 something holes that my uncle drilled in the 71 I have that he had for years. I think my dad gave him that electric drill for his Birthday one year too. You sure are doing a nice job on it though.
08-07-2020, 11:58 PM | #379 | |
08-09-2020, 02:17 AM | #380 |
Cab corner has nearly been finish welded. I had to cut it back off in order it weld all the bottom stuff. For some reason my welder is trash at welding from underneath. Its all good though as I had to remove it for weld through primer and to finish cutting the back to fit. It turned out to be alot easier than expected to remove the lip around the bottom of the cab corner. Im hoping to possibly get it tacked into position tomorrow. We'll see if I have enough time.
08-09-2020, 06:50 PM | #381 |
All welded up. Just need to check for pinholes in the welds, clean up the back side, shoot with weld through and it will be ready for the final install!
08-09-2020, 11:25 PM | #382 |
I'm hoping that someone who has installed vintage air might be able to chime in on this. Im still trying to figure out how I can mount the unit as clean as possible but I can't afford the unit as of yet. I would like to have the fasteners hidden from the engine bay to stick with my clean firewall theme. So my question is, if I were to weld in two vertical channels on the inner firewall that were just wider that the overall unit, would I then be able to build a mounting plate that I could bolt to the unit, and then to the channels? Im fairly sure that it would work, my only concern is that I would be then mounting the unit, Im guessing around 3/4" further into the cab. Does anyone know if this would work? Thanks in advance for any help on this.
08-10-2020, 01:03 AM | #383 | |
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
08-10-2020, 08:55 AM | #384 | |
08-10-2020, 03:59 PM | #385 |
beautiful work, thanks for the pictures. this will help me when i start my restoration
08-10-2020, 05:02 PM | #386 |
Right on. Glad I can help out in any way. Lots of what I've done was found on this forum.
08-14-2020, 01:20 AM | #387 |
Nothing ever seems to work out in what I think i can get done in an evening. There is always something unforseen that slows me down. Tonight It was my rear floor patch. It looked like it was pretty close from the bottom which is where I've been viewing it from. I should have looked from inside the cab as well but of course, I didn't. Oh well its all fixed up now. I had to slice it along the top edge and twist the top out towards the back of the cab to get it to where it needed to be to work with cab corner. After all that fun, I even managed to get it tacked into position.
08-17-2020, 01:52 PM | #388 |
very nice work sir.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
08-18-2020, 02:15 PM | #389 |
Very nice looking truck
What are you using for a mig ? I had a mig pak 10 from Ct i hated it and sold it even a welder i know had a hard time with it |
08-18-2020, 04:16 PM | #390 | |
Thank you sir.
My mig is an old Hobart Handler probably from the 80's. My dad has a hobart Handler 140 and it is a great machine. Thats what I started welding with back when I lived at home. |
08-21-2020, 09:25 PM | #391 |
Well I did manage to get on the truck for about 30 minutes today. I have been sidetracked on a different project for my quad. It turned out so much better than I expected so I just have to share it here. I did managed to correct the rear door gap. It was quite tight near the body line and for anyone who has the same issue, it seems that correcting it with the cab corner tacked on seems to be the best way. I had tried to correct it several times pre cab corner and it always went back. I guess it just needed something to hold it in place.
08-21-2020, 11:06 PM | #392 |
Great idea axe holder on the quad
And doing a great job on the cab corner. .
08-22-2020, 10:03 AM | #393 |
Thanks man! I'm hoping to get out there later today to make some more progress.
08-22-2020, 10:08 PM | #394 |
Wooo weee is that alot of welding. I got 2 hours in tonight and have the rest of the plug welds done and I also finished up the butt weld on the outboard side. It is all ground down and cleaned up. So shiny
08-27-2020, 08:19 PM | #395 |
Cab corner is in! It fought me pretty good on the back so it will definitely need some decent filler but im pretty happy all things considered.
08-28-2020, 12:32 AM | #396 |
You're a true craftsman Kyle! It may take long time to do it right, but you'll know exactly what you're driving and have pride in it at the same time.
08-28-2020, 12:02 PM | #397 |
You sure know how to make a guy feel good about his work. Thanks! It's comments like this that keep me motivated.
08-28-2020, 12:05 PM | #398 |
Agreed. Such great work here. That corner looks really nice.
08-28-2020, 06:10 PM | #399 |
Thanks man! I appreciate the kind words
08-29-2020, 02:37 AM | #400 |
Nice work
I have seen cardboard as backer for bondo on rusty trucks seen a bronco where the fellow rivited the patch panels over the rust spots My aim will be after i get a mig to make my work look close to yours Practice will help I seen a trick one fellow showed me make the patch and the panel trimmed close to same size tack the two together use zip disk cut at a 45 degree angle back tack the fresh cut flush make the next cut and continue until you have the patch completely flush fit finish welding and watch how much heat you drive into the panel |
