08-28-2016, 05:52 AM | #4201 |
Re: What did you do to your truck today? Chapter II
More body work. Welded up the old farm mirror holes. Grateful to have access to some body shops to work in. Perks with the job. The other day played around with a sharpe, not sure if I will continue with it.
08-28-2016, 06:00 PM | #4202 |
not much.. just stuck this where it goes.. that Captain Fab mounting bracket is top notch...
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
08-28-2016, 06:05 PM | #4203 |
Installed 4 newer/better Yankee 77 marker lights, replaced 2 lenses that were white with amber ones, and generally made them all look better.
08-28-2016, 06:20 PM | #4204 |
Is it normal for the rear light lens to be really tough to get in?
Seems as if it has shifted out of alignment, cant get the bottom screw back in. |
08-28-2016, 06:24 PM | #4205 |
70+ ( Old Skool Club )
Does your truck have the chrome trim around the taillights? If so yes, you have to finess them to get them in. Where do you live in Saskatchewan?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 Last edited by Already Gone; 08-28-2016 at 08:01 PM. |
08-28-2016, 08:09 PM | #4206 |
Changed transmission filter, and rear diff fluid today(no leaks) and changing the ball joints and tie rod ends tomorrow. One stop at the alignment shop, and I'm off to the races...
08-28-2016, 08:10 PM | #4207 |
Installed my flywheel cover. And discovered about a pound of dirt inside the drivers door? Anyone know why that would be there primered the door and fender a little better from my body work yesterday. Closer to being one color at least.
08-28-2016, 08:22 PM | #4208 |
Cleaned up the hardware (bolts and that angled steel bracket) to the driver side inner fender and outer fender. I just used Evaporust and wire wheel on that bracket and I have to say, it doesn't hold a candle to the effectiveness of electrolysis and Evaporust.
08-28-2016, 08:32 PM | #4209 |
got a few things done today on old blue.
Got the new bumper put on...
1972 K-20 Custom Camper 1971 K2500 Custom Camper (Sold) 2014 GMC 2500HD DMAX |
08-28-2016, 08:35 PM | #4210 |
Got the blue bench installed...
08-28-2016, 08:37 PM | #4211 |
Got one stainless mirror installed, will do the other next weekend.
08-28-2016, 09:07 PM | #4212 |
08-29-2016, 12:36 AM | #4213 |
Pierceland, it is on highway 55 going to Cold lake AB, im like 10 mins from the AB/SK border. My truck actually comes from Buffalo narrows, which is even further north from
08-29-2016, 06:27 AM | #4214 |
Blacked out the grill
08-29-2016, 07:35 AM | #4215 |
Got the Drop Spindles and Springs installed:
Steve My Build Thread: http://67-72chevytrucks.com/vboard/s...=morning+glory 1971 C10 Inline 6 250 700R4 "Marlene" 1934 Chevrolet Master Sedan 350 700R4 "Iris" 1941 Ford 1/2 Ton 5.0 H.O Roller C-4 "Rose" 2019 Honda Ridgeline |
08-29-2016, 10:17 AM | #4216 | |
http://www.consolidatedcompressor.com/diy.html
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
08-29-2016, 12:40 PM | #4217 |
I thought I would try to get the last bit of shine out of my old 69. I tried clr but that must be just good for rust. the best way I found was to wet sand it with 1200. then I used meguires mirror glaze to get scratches out. finished it off with the mothers. it was a lot of work but it looks a little better. pictures show some before during and after.
08-29-2016, 02:58 PM | #4218 |
Finally adjusted drivers side door, install new door seals (2nd Gen) SS thresholds and inside rear view mirror all from GMC Pauls. If I could figure out how to load more than one picture....on an iPad
1970 C10 Short Stepper with 71/72 front clip. |
08-29-2016, 11:06 PM | #4219 |
Who Changed This?
Got the appropriate adapter to get the rear brakes working on my truck. I still have to run new front lines to the new flex lines on the rotors, after converting to front disc brakes. Almost done. I put in new upper and lower control arm shafts and ball joints (the ball joints came with the kit). The ball joints were ORIGINAL from 1970, as were the rest of the steering components! I will admit that getting the master and booster replaced was a bit of fun that I am looking forward to never doing again. I'm going to make new lines for the front brakes with parts from the parts store. A bit different, drum to disc. I was thinking rear disc somewhere down the road. Not so sure, any more. Next is getting the wiring for the new (to us) trailer we bought installed. I have an old 5-pin connector. Talk about old-school! Got to get a 7-pin connector setup.
~Steven '70 Chevy 3/4T Longhorn CST 402/400/3.56 Custom Camper Simi Valley, CA Last edited by Steeveedee; 08-29-2016 at 11:12 PM. |
08-29-2016, 11:25 PM | #4220 |
I pulled the 71 Camaro wheel I recently installed. The wheel is small and turn signal stalk was too close, my knuckles kept catching it. I modified it and its perfect now.
Repainted a pair of 15x8 rally wheels argent silver
1982 K10 SWB 1987 V20 - Sold - Doh! |
08-29-2016, 11:30 PM | #4221 |
I attempted to change out my ball joints today. I accomplished three, but ran out of time tonight. I'll do the last one and the tie rod ends on Saturday.
The YouTube videos I watched sure made it look easy, but then again they weren't replace OE ball joints, on a 46 year old truck either. Knowing now what I learned today, Saturday should go smoother, and a lot less frustrating. |
08-29-2016, 11:50 PM | #4222 |
Made up some screens from rain gutter screen.
08-30-2016, 12:39 AM | #4223 |
Drove it around the block while sitting on a bucket because, you know, I couldn't let cobwebs grow on it.
08-30-2016, 01:16 AM | #4224 |
Finally got my wheels on . They were sitting in garage for about a year.
08-30-2016, 04:55 PM | #4225 |
Love the stepside man and you have the spare where God told GM He intended it to be.
I paid for two fender emblems, put up a counteroffer on two more, filtered all of the Evaporust I used last week, and I am just about to finish up spraying the bolts and clips from the removed inner fender with NAPA Rust Treatment. |
