#401 | |
Re: The '67 Burb Build Thread
#402 |
lol. yah im glad i finally took the time to put them on. now i need get used to using them to pull the door shut from the inside instead of the window opening or the door open handle
#403 |
changed the alt/power steering belts today, took a pic of the lowest part of the front while i was airing up the back. also got my 1" wheel spacers today
#404 |
wow you are havin a heck of a time these days getting good parts haha
#405 |
seems that way lol. well i took them back today and they said they will have them fixed for me but it will be about 5-7 business days, they have to ship them back to nevada to be fixed as that is where they were made and then shipped back out here, hope i can have them back and installed before the show. on another note, the burb is basically done enough for the show, just need to fill up the gas tank, get the windshield installed, repaint and install the hood, give it a good washing , and clean out the inside. oh, and readjust the pan hard bar.
#406 |
cool so you cleanin it right now?
#407 |
nah not yet, just took all of the crap out of it yesterday and carefully hosed it off this morning.
#408 |
after i hosed it off i took a trip to the gas station with no hood or windshield
#409 |
They sell super thin lug nuts for those adapters. Also try to keep paint off the mating surface too. Maybe it's just me but the studs on the new adapters look thick! I haven't been on here for about 3 weeks so maybe I have missed something...
#410 |
no not much just look and read a little lol. ok i will make sure to clean the piant off the mating surface when i get them back from being fixed. they also told me i had to cut the lug nuts i have
![]() edit: where do they sell the super thin ones at?? i have the regular open ended ones right now Last edited by project 67 sub; 03-04-2011 at 06:16 AM. |
#411 |
They have to be open nuts for sure! Off hand I'm not sure where to to get them, I haven't used those in a long time. In the German car industry they are used all the time, it's incredibly common. That's the only time I have ever used them was putting them on BMW's, VW's, Evo's and STI's. The customer I use to do the work on, for his cars, brought me everything.
If I see the the thin lug nuts I'll let you know for sure. You can sand them down, but do not get them too hot, they might crack when you torque them or while you are running them. Definitely don't want that. I'm surprised the company that sold them to you didn't have any to sell you, nor sent you in the direction to get them. ------------------------- **Edit - I'll PM ya what I found.... Last edited by Mkcustums; 03-04-2011 at 07:03 AM. |
#412 |
thanks, and thanks on keeping a look out for me, and yah i am suprized as well, we will see when i go pick them back up if they have any or what not. what about carfully cutting them with a cutt off wheel after they are installed or is that not a good idea??
#413 |
If I was to cut them I would measure just shorter than they need to be, and mark it with a fine tip sharpie and sand them down slowly with a bench style belt sander, dipping them in water to keep em cool. It would be hard to get them cut flush when they are mounted.
#414 |
low n' slo
![]() Join Date: Mar 2009
on the thin lug nuts, im not sure if this is what u need but i tried something called gorilla lugnuts from discount tire. they were about 40 bucks. i had some 22's i bought for the other suburba i had and regular lug nuts wouldnt fit. the rim was the kind with no center cap..the lug nuts were recessed. they came with its on socket too
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 03-04-2011 at 07:39 AM. |
#415 |
You just need to make sure those spacers get mounted as good as you can. Studs should come almost all the way out to the face, and to use up as much threaded stud with the nuts as possible.
Yeah, you could use locking ones too like Kev said as long as they work out right. |
#416 | |
#417 | |
#418 |
#419 |
ok thanks, if they dont have any to give me for my troubles
#420 |
got the hood repainted and installed today/tonight, looks much better now. also have still not figured out why i am having issues with that tail light, but then again i did not mess with it today. oh! i also cleaned the 67 arm rests off with some acetone and now they look alot better minus the seafoam grean color
#421 |
For your tail light issue check the tail light housing bolts. Mine use to do that cause the housing couldn't ground well enough. Just unscrew them and screw them back in with the lights on.
Always remember those that had your back Never forget those that turned it Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt, Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner |
#422 |
i am running 89-93 caddy tail lights, not sure if that matters or not though, and they also have their own ground wire coming out of the bulb socket plug thing
#423 |
yeah never mind then
#424 |
haha thanks anyways bro i appreciate it
#425 |
