#401 | |
Re: 52 GMC Envoy Burb meld/build
![]() Quote:
Looking forward to more progress!
"I feel the need for speed!"... as soon as I am done with my nap. |
#402 |
VA72C10
![]() Join Date: Mar 2008
Cool! Looking forward to the progress
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#403 |
Junior Member
![]() Join Date: Feb 2005
This is where the body sits compared to the stock 17 inch Envoy wheel with a mud & snow tire. Planning to use 20's. When the fender was permanently mounted, it was moved out about 1/2 inch. Should be interesting to see how big a tire/wheel combo I can get under it!
#404 |
Great job.
#405 |
Junior Member
Cut the top off!!
48 GMC Panel Sold 12-14-15 52 White/Chevrolet School Bus 52 GMC Burb/Envoy Meld 61 Impala Wagon SOLD BARRETT JACKSON SCOTTSDALE 1-18-13 67 c/10 SOLD 2012 71 SS454 77 c/20 Sold 11-11-15 08 TBSS The Wife's car!! 50 GMC School Bus SOLD 11-7-10 29 F**D Delivery (Chevy powered) SOLD 11-4-11 53 GMC 630 Firetruck/Ramp Truck |
#406 |
Wow that's a big sunroof!
![]() Posted via Mobile Device
1971 Suburban... work in progress |
#407 |
Chevy Enthusiast
Wow why did you go an do that?
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
#408 |
#409 |
VA72C10
Cool! Re-doing the shape of the roof in metal, a ragtop, or a solid plexi roof?
#410 | |
Junior Member
Lets see, Volkswagen cloth rollback, new Caddy Wagon double sunroofs, . . . nope. Sectioning 2-3 inches out. Should give it a chopped look without the actual chopping. Plus, while it is off, I am making a fiberglass mould of it so I have a smooth, paintable headliner. |
#411 |
BBEEP, Can not wait to see the difference. I thought about putting a sliding rag in my panel truck till I was reading about them leaking. Great build!
Shannon |
#412 | |
#413 |
Junior Member
Thanks for the kind words. I just can't stop thinkin!! And I can't wait to see the results either!!
#414 |
Junior Member
1st tail light roughed in. I like the way it follows the contour of the door.
#415 |
![]() Join Date: Mar 2007
It looks good. Is that the factory envoy lense? I also like the molded in rear bumper
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#416 |
Junior Member
#417 |
Atleast you kept it in the same family..ha ha.
Keep the progress coming. How about you roof? Marc
#418 |
I'm in..love the old with the new!
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
#419 | |
Junior Member
When the body was dipped, there was too much sediment in the dip tank to clean the top. (& yes, will fix the hole in the roof before I do the glass) |
#420 |
Slick idea for the headliner. I bought a fiberglass one off of EBay but I'm not sure how great it fits. I started fiberglassing some kick panels and it is in the 30's today in MI so it is taking a little time for the resin to set up..
Marc
#421 |
Junior Member
Since I plan to glass the dash, I figure I will only upholster from the windows down. Everything else inside will be painted body color, dash, headliner, window surrounds, pillars, etc.
And originally Marc, I was going to paint it black over the new Camaro Synergy Green Metallic--so love your truck!! |
#422 |
Did you have it dipped in the Portland area or? I'm pretty sure that somewhere in the build the cab I am putting together will be better off with a trip to the dip tank.
The hole in the roof from the light that was on the truck in it's early life? |
#423 | |
Thanks for the kind words. Mine is a custom mix but I get asked all the time if it is Synergy green.. Marc
#424 |
Looks like a new Camaro tail turned sideways
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
#425 |
Junior Member
Tags |
suburban |
