Old 05-20-2011, 02:36 PM   #401
kevinr1970
Re: How about some pics of '73-'91 Crew Cab Short beds?
Originally Posted by Devillusion View Post
...what size tires are you running? And what drop front/rear? I am doing the same thing to mine except keeping it 8 lug and using a cab and chassis 14 bolt which is narrower for a wider meat out back. Going to stick with widened stock steelies in a 16"...
nice ride by the way, build thread?
275/60-15 rear, 255/60-15 front
flip kit (6"?), 3" spindles, 1" springs - had 3" springs (first picture posted), but that was too much. Looked cool, but was not realistic to be driven regularly. That picture was when I had 235/75-15 tires on it, with the 255/60's it would have been probably 1" closer to the ground in front...
Back surgery on Monday 05/23 and then 2-3 weeks off work. I ought to have plenty of time then to go through my pictures and put a build thread together.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 05-20-2011, 02:44 PM   #402
kevinr1970
Originally Posted by D.FENS View Post
If I started with a 1ton DRW crewcab, what would the smartest way to get the parts needed for a CCSB conversion? Buy a 1/2 ton parts truck?
Don't light me up for axing a stupid question. Never really used my dually for what I bought it for and maybe this way I can actually get some use out of it.
Depends what your desired end result is; do you want to convert to 1/2 ton suspension?
If so, then getting a complete (as far as the parts needed) swb parts truck would be ideal.
- lower control arms (although I read that someone is making a 3"(?) drop spindle for converting 3/4 and 1 ton trucks to 5-lug rotors)
- rear-end
- short bed gas tanks (14 gal.)
- rear frame section if you choose that method, which I did because I had the donor and it seemed like the easiest most straight forward way to do it, but turns out that is not fool-proof either?
- most importantly, a short bed
- etc.
2000 Tahoe Limited
Old 05-20-2011, 06:05 PM   #403
Chevy_Crazy
Chevy_Crazy's Avatar
Cool pix
FREE Classic Chevy Classifieds
Hundreds of Manuals and Much More!!!
All FREE at http://www.chevycrazy.com
Chevy_Crazy is offline   Reply With Quote
Old 09-27-2011, 02:33 AM   #404
freemoto_xxx
heres mine
freemoto_xxx is offline   Reply With Quote
Old 09-27-2011, 01:43 PM   #405
joe231
joe231's Avatar
Originally Posted by freemoto_xxx View Post
heres mine
NICE!!
what are the specs?
and what part of AK are you in?
CHEVY ONLY
Old 09-27-2011, 03:09 PM   #406
freemoto_xxx
At the time it had a 9.5" lift on the front 11.5" in the back. 350 hp marine 6.5 turbo diesel th400 np205. Right now it's in the process of a 5.9 and Allison 1000 swap. I'm in anchorage btw.
Old 09-27-2011, 04:01 PM   #407
joe231
joe231's Avatar
right on!
glad to see you post up....you been lurking since 2006?
you still have the 6.5?
CHEVY ONLY
Old 09-27-2011, 05:55 PM   #408
freemoto_xxx
Yep I still have it but after running 20 psi of boost one of the pistons cracked. The motor only had 2000 miles on it.
Old 09-27-2011, 07:19 PM   #409
joe231
joe231's Avatar
Oops!!
Lol
Single turbo?
How are the heads and turbo system?
CHEVY ONLY
Old 09-27-2011, 09:06 PM   #410
freemoto_xxx
Yea it a single turbo. It's the banks sidewinder turbo with a custom 4" straight piped exhaust. Only 1 head is good and the turbo system survived also.
Old 10-27-2011, 10:19 PM   #411
coxey26
start of my ccsb...getting ready for body work and paint very soon..
coxey26 is offline   Reply With Quote
Old 10-27-2011, 10:30 PM   #412
coxey26
Doesn't seem to really make sense why the box doesn't line up though.
dont know exactly what you are talking about...but if you are talking about the bed, and you cut the frame to make a ccsb then you might not of got the frame square, we are doing two right now and on 1 of the 2 the bed wouldnt line up right and was sitting like the bed was tweaked...come to find out the cut that was made on the pass. side wasnt exactly right and it made the frame tweaked a bit.
Old 10-28-2011, 12:40 AM   #413
Devillusion
Devillusion's Avatar
That is kinda what I was getting at....something in the bigger scheme of things is wrong.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 03-04-2012, 08:12 PM   #414
samuel.grinder
1989 CCSB Air Ride Tech 20"x10" and 20"x8.5" Z cut the 1ton frame. 1/2 ton control arms out with 2.5" spindles.
samuel.grinder is offline   Reply With Quote
Old 03-04-2012, 10:20 PM   #415
bustedknuckles
bustedknuckles's Avatar
lotta nice crews. here's my newest project. going 4wd.
84 GMCummins
91 CCSB Dually
american squarebody association
bustedknuckles is offline   Reply With Quote
Old 03-05-2012, 12:40 AM   #416
joe231
joe231's Avatar
Sweet trucks guys!!
Feel free to post more pics
CHEVY ONLY
Old 03-05-2012, 06:03 PM   #417
rs72z
rs72z's Avatar
Mines getting close so here's a few pics. I hope to get closer to wrapping it up this weekend.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 03-05-2012, 06:39 PM   #418
joe231
joe231's Avatar
CHEVY ONLY
Old 03-06-2012, 12:06 PM   #419
CHEESE
The Cheesiest
CHEESE's Avatar
Originally Posted by joe231 View Post
X2!! sweet!!
CHEESE is offline   Reply With Quote
Old 03-06-2012, 12:21 PM   #420
rs72z
rs72z's Avatar
Originally Posted by CHEESE View Post
X2!! sweet!!
Thanks guys. Look for some new pics over the weekend.
___________________
78 ccsb dually
5.3
4l60e
Old 03-06-2012, 01:10 PM   #421
72longhornTX
Well I just looked through this whole thread. I have to say some of y'all have some dang good looking trucks.
I did notice a picture of my truck back in post 15. That was way before I owned it though haha. It was this picture.
I have a lot more pictures but I have them in a large size and if I post them here it will distort the whole page. I plan to swap in a 12v Cummins I have. I am already collecting parts for the engine and the swap. I still need a transmission. Have been looking into the 6 speed Allison a lot lately. With my gearing I will be turning 1615 RPM at 70 MPH and 2087 RPM at 90 MPH. Should equate to decent fuel mileage.
Current:
2012 Ford F-250 4x4 6.7 Powerstroke
1971 C-20 2wd 350/TH400
Former:
1979 C-20 2wd 350/TH400, 300+hp. Rattle can paint job
1982 K-30 454/700R4. 4in lift with 37" Goodyear MT/R's Lots of goodies - Trail clean up truck
72longhornTX is offline   Reply With Quote
Old 05-01-2012, 04:49 PM   #422
rs72z
rs72z's Avatar
Here's a couple of new ones.
___________________
78 ccsb dually
5.3
4l60e
Old 05-01-2012, 05:03 PM   #423
1badgmc
1badgmc's Avatar
That is a sexy beast!
Old 05-01-2012, 05:03 PM   #424
mikev
mikev's Avatar
Short bed dually?
awesome
mikev is offline   Reply With Quote
Old 05-01-2012, 08:05 PM   #425
rs72z
rs72z's Avatar
Thanks guys.
Yes it's a swb dually
___________________
78 ccsb dually
5.3
4l60e
ccsb crew cab short
