Old 07-21-2013, 06:02 PM   #401
likaroc13
Rollin' Old Skool
Re: '63 GMC Project
Originally Posted by creep View Post
My 20" steelies showed up this weekend while I was away. Have to wait untill next weekend to test fit.
Cool! So, are these the Mobsteel from Detroit Steel Wheel?
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 07-21-2013, 10:42 PM   #402
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
Yup.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 07-22-2013, 06:23 PM   #403
82swb
82swb's Avatar
Re: '63 GMC Project
[QUOTE=creep;6183514]My 20" steelies showed up this weekend while I was away. Have to wait untill next weekend to test fit.
Posted via Mobile Device[/QUOTE/]
They look great! I'm putting white ones on my 64. I'm kind of holding out because I k ow 22s are in the works. What are you doing for caps?
82swb is offline   Reply With Quote
Old 07-22-2013, 07:02 PM   #404
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
[quote=82swb;6185158]
I'm going to try using the center caps I have on my truck now. Hopefully they'll work since they are held on by the lug nut covers.
Old 07-26-2013, 03:33 PM   #405
ChefCy
ChefCy's Avatar
Re: '63 GMC Project
Sick!!
63 big window lwb bagged and shaved
ChefCy is offline   Reply With Quote
Old 07-26-2013, 11:00 PM   #406
coulter
coulter's Avatar
Re: '63 GMC Project
some cool rides at the show!! thanx for sharing!! cant wait to see the new wheels mounted up
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 10-11-2013, 04:47 PM   #407
bodydrop
Re: '63 GMC Project
R u running porterbuilt on it
bodydrop is offline   Reply With Quote
Old 10-29-2013, 05:54 PM   #408
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
Not Porterbuilt but the same style system.
I still don't have the 20s on yet. I gotta change out my spindles and do some trimming in the front and get rid of the middle stake pocket in the back then HOPEFULLY they'll fit.
Haven't been on in a while, been kind of a lousy summer for me, nothing major just lots of little crap. Can't complain to much with what other members are going through.
Old 10-29-2013, 07:07 PM   #409
likaroc13
Rollin' Old Skool
Re: '63 GMC Project
How long did it take to get your wheels, & can you give me an idea of pricing? You can PM. I didn't notice anything on their website. Guess you have to contact them directly. I like these, but I also like the "Delmo specials" too.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 11-01-2013, 12:10 AM   #410
johnlq6975
Re: '63 GMC Project
What rear end did you chose
johnlq6975 is offline   Reply With Quote
Old 11-01-2013, 05:45 PM   #411
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
I think it took a couple of months to get 'em and they cost about $220 a wheel + $25 each for the powdercoat.
Not sure what your referring to but I am using a ************* rear suspension set up with what I think is a Chevelle axle redrilled to 5x5" bolt pattern.
Apparently I can't tell you who's rear system I'm using even if I'm answering a question and not flat out advertising for them. That's whack.
Old 11-20-2013, 12:09 AM   #412
Holmes Cycles
Holmes Cycles's Avatar
Re: '63 GMC Project
What size/width and backspacing on the 15's you were running?
Holmes Cycles is offline   Reply With Quote
Old 11-20-2013, 12:22 AM   #413
johnlq6975
Re: '63 GMC Project
I'm not sure what happened there I'm just trying to figure out how to easily swap a positrac rearend like chevell or camaro . Thanks for replying
Old 11-22-2013, 01:27 PM   #414
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
The 15s are stock wheels from a 92 C-1500. I believe they are 15" X 7" with 4" of backspacing.
Old 11-22-2013, 01:35 PM   #415
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
I had to weld brackets to my axle to mount the air ride setup anyway so I was able to use any rear end I could fit in it. The rear I used already had all of the stock mounting brackets cut off and smoothed out so I don't know how they line up but I doubt it's a simple bolt in swap. I also had to have my driveshaft modified to work with it.
Old 11-23-2013, 12:09 PM   #416
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: '63 GMC Project
truck is looking cool! Keep up the good work! T.J.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-23-2013, 02:26 PM   #417
gringoloco
A guy with a truck
gringoloco's Avatar
Re: '63 GMC Project
Great build, even if you are using 'brand X' suspension The mobsteels are gonna look great. Also, kudos on the faux Hotwheels- that's too cool!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-26-2013, 05:21 PM   #418
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
Nothing new with the 63 but I wrecked my daily S-10 2 months ago and the replacement truck I ordered came in this week. Just picked it up today...
...2014 Silverado LT
Old 01-02-2014, 12:13 AM   #419
sams60gmc
sams60gmc's Avatar
Re: '63 GMC Project
cool truck! i really like the new styling... cant wait to see those wheels on the 63, i was looking into a set for the 60 also!
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline   Reply With Quote
Old 01-29-2014, 10:56 PM   #420
Desert.Chevy
Desert.Chevy's Avatar
Re: '63 GMC Project
Thanks guys.
Now that is Cool!
Can you tell me more about this, custom ordered or did you make it?
Any pictures of you wheels mocked up on your truck?
Thanks.
Desert.Chevy is offline   Reply With Quote
Old 01-31-2014, 10:39 AM   #421
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
I made the Hot Wheels replica from 2 '62 Chevys and a GMC panel truck. The card is just a photoshop job I did on my computer. Here's a thread about how I did it.
http://67-72chevytrucks.com/vboard/s...d.php?t=509982
Here's the best pic of the one of the wheels during the test fit.
Here's a vid of me starting the truck and pulling it into my storage unit. I shot this to see what the new horn sounded like from a distance.
http://s9.photobucket.com/user/88ast...7ce9a.mp4.html
Old 01-31-2014, 11:06 AM   #422
likaroc13
Rollin' Old Skool
Re: '63 GMC Project
The wheels are gonna look sweet. You gonna run a different center cap or sticking with those? The truck looks & sounds great in the video as well. I bet you can't wait to get it out of storage!
Phillip
My Build threads:
Pics:
Previous Rides:
Old 01-31-2014, 03:18 PM   #423
creep
Registered Loser
creep's Avatar
Re: '63 GMC Project
Thanks. Yeah I wanna drive it so badly right now.
I am going to use the centercaps I have for now but I may evenyually get some smoothie centers for them.
Old 02-03-2014, 06:58 AM   #424
lowlife4life
lowlife4life's Avatar
Re: '63 GMC Project
Man your truck is amazing. Just read whole thread. Brand x looks like a great product I also like how the lca mounts. Would be nice to know the company. First time I've seen them block it like that. Wonder what the reason is. Which horn is that? I had a farmer buddy of mine give me a set of nathan air chimes they are crazy loud. One rule no kids and no grey hair for mine. I'd feel to bad if I killed someone with a horn
lowlife4life is offline   Reply With Quote
Old 02-03-2014, 11:53 PM   #425
Desert.Chevy
Re: '63 GMC Project
Good looking truck, my two kids heard it in the other room and came running and said "What was that!, it sounded COOOL!" Us three think its cool. Could I get some info on it and maybe a picture of it. Thanks.
