#401 |
Re: 72 Dropmember Suburban
I keep getting called out to work so I haven't had much time to work on Alice. I decided to move the accuair valve block because the airlines were going to look bad where it was mounted so I had to add some length to the harness. I still haven't mounted the ride height sensors yet.
I moved the Dakota digital modules behind the glove box over to straighten out some of the wiring and make some room. I am supposed to have the rest of the Dakota digital stuff that was back ordered today. I got the 4 core radiator brackets and they were too big. I ended up using the 2 core brackets with some modifications. I started working on the vintage air, got the condenser mounted. The fire wall panels are over at my dads so he can get them painted. ![]() Im kind of in a holding pattern with the Dakota digital stuff and the vintage air. I need the firewall panels before I can do much more with the vintage air, plus I don't want to get it completely done before I finish up all the wring. I did find some front seats that should be here soon too. |
#402 |
#403 |
that is soo sexy!
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
#404 |
#405 |
Laid Back
![]() Join Date: Apr 2010
I say run them like that..
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
#406 |
#407 |
Laid Back
#408 |
#409 |
![]() Join Date: Apr 2007
^^^ thats 2 of us............jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
#410 |
![]() Join Date: Dec 2012
Love it!
I expect to use the same, or similar, HVAC unit. did yours come with a pre-fabbed plastic glovebox---and is it big enough to actually be of any use? I ask because I was pondering making a flat panel 3 or 4" deep behind the glovebox door to mount the fuse panel (and maybe some modules like yours--but only those that require calibration or some other routine access). What would be the drawback to that? That is, assuming the door will stay closed 99% of the time.
JK |
#411 | |
#412 |
Laid Back
Looks great.. Great job on keeping the wiring clean..
#413 |
I got my problems figured out, it was the connectors on the relays. Every time I would push the connector onto the relay, the internal connectors would slide out of place. I ended up not using them and used some individual connectors instead. Everything works as advertised, all the lights work properly, the accessory (radio) stays on until one of the doors open and the dome light dims. Here is a video of the dome light.
#414 |
Everything looks so good.
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme Mike |
#415 |
#416 |
![]() Join Date: Dec 2006
Nice job on the wiring, gauges look great too
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#417 |
Thank you
I got the front ride height sensors installed and then I broke the tap I was using. Just about that time the UPS man came and dropped off my ac compressor so I went ahead and got in put in. Looks like I am going to have some long hoses. ![]() Last edited by blfuller123; 01-29-2014 at 09:36 PM. |
#418 |
Just finished reading the whole build, and everything looks top notch !
Every new page I read I was hoping you would be test driving it. Lets just say I'm excited FOR you to drive that sled!! Keep the pictures coming too.
1972 C20 Custom Camper Cheyenne Super - new shop truck |
#419 | |
I finished up mounting the ride height sensors, got the wire run for them and mounted the valve block mounted and the air lines cut. I have a little more to tidy up the wiring, but the hard part is done. The valve block is going under the tank, the tank is pushed back in the picture. I think I am going to do the tank in the color match bed liner like the floor. ![]() Was looking at the ac compressor and I have run into a problem. It fits, but there is no adjustment once the line is installed. If it goes toward the drives side, the line will hit the master cylinder, and if it goes to the passenger side, it hits the valve cover. I think I am going to take off the lug on the compressor and see if that works out, the only other option that I can think of is to change the master cylinder and I really don't want to do that. ![]() |
#420 |
A320 Pilot/USAF Retired
VA has a compressor with the ports on the back that might help.
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#421 |
Does March make an idler with a spring tensioner built in that would go in place of the idler below the compressor? Seems to me GM had that on some serpentine applications. The tensioners had a 1/2" square hole in the front that a ratchet, or a breakover bar fit in to un-tension it.
JK |
#422 |
#423 |
I was checking the ride height sensors with air and realized the back ones wernt right at all. I figured the travel correct as long as the front and back went up and down at the same time. When I went to let the front down first, there was more travel on the back sensors than I accounted for so I ended up having to move them.
I just ordered this rear head for the compressor. Since the hoses will connect to the back, I may get some extra length and route them down low instead of across the top of the engine. ![]() |
#424 |
low n' slo
![]() Join Date: Mar 2009
project looking good...love this build
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#425 |
