Old 08-09-2016, 03:53 PM   #401
jimbosprint
jimbosprint's Avatar
Re: jimbosprint 1972 C20 - the good, the bad, and the ugly
I'm not happy. The receiver I ordered is just under 33.25" wide so the distance between the bolt holes is too narrow and they line up on the edge the frame. It specifically says "fits 34" frame". Draw-tite says they have been selling these for 20 years without any complaints. What the hell!!!???
jimbosprint is offline   Reply With Quote
Old 08-18-2016, 05:58 PM   #402
jimbosprint
The trailer hitch that didn't fit has been returned, and one that does fit is installed. Draw-Tite #41001 is the correct part number if anyone is looking for a class IV hitch that fits good. It drops 5.5" for bumper clearance and sticks out about 10 inches from the end of the frame.
This truck is now ready to tow better than ever, and the search for a little classic travel trailer begins!
Old 08-18-2016, 07:03 PM   #403
dfwright
dfwright's Avatar
That hitch is perfect! I have a very similar bumper, and I will get the same hitch, once I mount the bumper and measure the drop and depth. Thanks for posting the part number.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 08-18-2016, 09:01 PM   #404
Aus69c20
Aus69c20's Avatar
Looks good. Do you Still have room for your spare tyre under there?
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 08-18-2016, 09:31 PM   #405
jimbosprint
Good question! The truck has never had a spare tire under there since the old bumper/hitch was in the way. The hitch instructions say "the spare tire carrier might have to be removed or modified to install this hitch". I'll have to see if I can find a factory spare tire carrier and try it out.
Old 08-19-2016, 08:01 AM   #406
Aus69c20
Aus69c20's Avatar
I was interested because I installed a tow hitch on mine and was able to retain the spare, but it's tight. It pushed everything forward and left me with about a half inch of clearance to the panhard rod.
mine may be different to yours though, it was a Curtis hitch.
If you need pics of the spare tyre set up I'll happily snap some.
John
Old 10-26-2016, 12:38 PM   #407
jimbosprint
Time for a performance upgrade!
I just ordered Doug Thorley Tri-Y headers. Now for the hard part - waiting for them to be made. I was told late November probably.
Old 10-27-2016, 07:38 AM   #408
Aus69c20
Aus69c20's Avatar
Something to look forward to. Now you need something else for Christmas.
John
Old 10-31-2016, 05:06 PM   #409
jimbosprint
Holley Sniper EFI would be nice...
Old 11-03-2016, 03:42 PM   #410
jimbosprint
I just got a custom windshield sun shade to protect the interior from the harsh Northern California sun. It is made by Covercraft.
Old 12-09-2016, 11:49 AM   #411
jimbosprint
O'Reilly Auto Parts posted a picture of my truck on Facebook for #TruckTuesday, and it got over 7500 likes and 450 shares!
Old 12-09-2016, 12:17 PM   #412
Troy Sr
Troy Sr's Avatar
I installed a hitch on mine, I believe it's a Hidden Hitch I was able to retain my spare in it's original location. Here's some pics and also the extension I made to extend beyond my 11 1/2 foot cab over camper.
Take Care
Troy
Troy Sr is offline   Reply With Quote
Old 12-09-2016, 01:51 PM   #413
jimbosprint
Attachment 1598147
Attachment 1598148
Wow! That is one insane hitch extension!
Old 12-09-2016, 08:42 PM   #414
Troy Sr
Troy Sr's Avatar
Yeah, and it worked great, didn't sag one bit and that was with a 4000 lb boat w/ 400 lb tongue weight. Got rid of the camper and replaced it with a motor home. Here it is at work!!
Take Care
Troy
Old 12-14-2016, 01:11 PM   #415
jimbosprint
My Doug Thorley headers finally arrived! I can't wait to get them on the truck!
Old 12-16-2016, 07:33 PM   #416
jimbosprint
Well my truck is giving me a couple problems, so I have postponed putting the headers on until I can get them sorted out. Maybe someone here can tell me if these things are related or give some other advice.
- Temp gauge reads hot and moves around a lot. It doesn't bounce, it goes up when you drive, and cools down when you idle. According to the infrared thermometer pointed at the thermostat housing, the engine stays between 185-200 degrees in the driveway at idle or at higher rpm. I wish I had some help to see if the gauge moves with the actual temp.
- Today with the engine running, the fusible link between the battery + and the fender distribution block melted and smoked. I replaced it and it started to melt again right away. No obvious shorts, the temp sensor wire appears fine as well as distributor, starter, and alternator wires.
Old 12-18-2016, 07:09 PM   #417
jimbosprint
So the smoking fusible link wire turned out to be a bad voltage regulator. At higher RPM it was charging above 16v, and now it is 14.3v max.
This might have also fixed the temp gauge, but I need to drive the truck a little more and see how it acts.
Old 12-23-2016, 08:14 PM   #418
jimbosprint
Got my new headers installed! They are sweeeeet!!!
Old 12-26-2016, 06:59 AM   #419
Aus69c20
Aus69c20's Avatar
They look great
John
Old 12-27-2016, 01:15 PM   #420
rusty76
rusty76's Avatar
Awesome
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 12-27-2016, 02:57 PM   #421
TXBoudy
TXBoudy's Avatar
Nice!
TXBoudy is offline   Reply With Quote
Old 01-27-2017, 09:32 PM   #422
jimbosprint
I still need to get new plug wires that are the correct length, but I finally got the ones I have straightened out with some zip-tie wire separators. I found the idea searching online for some to buy, and I think I like this better.
Old 01-27-2017, 09:47 PM   #423
Orange67
Orange67's Avatar
Nice work man! I've been using the zip tie trick for years, I think I found it online too. Love the truck!
Justin
'67 C20 CST Custom Camper
'04.5 LLY Duramax CCSB...sold
Orange67 is offline   Reply With Quote
Old 01-27-2017, 09:51 PM   #424
GR8-68
GR8-68's Avatar
That looks sweet !! Nice work, those headers are saweeeeettt !!!
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 01-28-2017, 11:08 AM   #425
dfwright
dfwright's Avatar
That zip tie separator trick does look really good. I think I'll steal it from you now,
1972, c20, deluxe, stock
