Old 01-28-2015, 03:09 AM   #401
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
ok, I got some more issues / questions
Second question. Can I replace this hard line for the brake booster with a regular all rubber brake booster hose? Should I find / run a 90* elbow thingie at the back of the carb or just loop the hose around?
I ask because the original carb had a screw in outlet in the back of the carb and this new one doesn't, it has a traditional 3/8th nipple.
Gregski is offline   Reply With Quote
Old 01-28-2015, 03:15 AM   #402
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
last issue / question
the throttle linkage bracket I bought is not for this carb model, I knew that going in but I thought I could make it work, it does not have some sort of anchor to keep it from swiveling around the bolt, in the pic I show you what can happen if it comes loose as it is only held on by one bolt, not like the old original bracket which was held on by two bolts (by the way the old bracket does not fit this carb)
any of you running Holley carbs and can recommend a proper bracket
all help / advice much appreciated
Old 01-28-2015, 02:40 PM   #403
LSX408
Re: Restoring Rusty
I would just delete the evap stuff unless you want to keep it. Thats one of the first things i do one I start a new project is delete all of that stuff.
You can replace the hard line with rubber hose, just buy some good quality hose.
I'm running a Summit bracket on mine and I have the same carb as you. Part #SUM-G1414
1983 GMC SWB - 350, TH-400
2002 Camaro SS - 408 9sec street car
2000 Trans Am - H/C/I
2014 Chevy Z71
LSX408 is offline   Reply With Quote
Old 01-28-2015, 06:02 PM   #404
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
LSX I Love You Man!
Old 01-28-2015, 08:38 PM   #405
Chaplain
Chaplain's Avatar
Re: Restoring Rusty
I have discovered that I need one of those bracket. My truck has a 700r and would not shift properly after the previous ouner install a new engine and carb. The bracket that was installed when I got the truck moved just like yours and caused the throttle cable to bind. I learned from forum members that I need this bracket to get rid of the movement as well as to properly set up the tv cable.
Chaplain is offline   Reply With Quote
Old 01-28-2015, 10:11 PM   #406
Jake Wade
Jake Wade's Avatar
Re: Restoring Rusty
What is that gold bracket bolted to the intake for?
Jake Wade is offline   Reply With Quote
Old 01-28-2015, 10:52 PM   #407
enaberif
Re: Restoring Rusty
To convert the brake booster line to all rubber you'll need to find a NPT nipple that will fit. On my carb they put a NPT bung to allow a nipple attachment.
enaberif is offline   Reply With Quote
Old 01-28-2015, 11:01 PM   #408
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Jake are you talking about the triangle looking thing in that red square? If so I did not even notice it, but I really don't know. It's not part of the throttle bracket.
Old 01-29-2015, 01:34 AM   #409
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Restoring Rusty
Yes you can run all rubber line to the booster.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 01-29-2015, 07:46 AM   #410
Jake Wade
Jake Wade's Avatar
Re: Restoring Rusty
Yes, cannot figure that one out. Now I know it did not come with the kit, Thanks!
Old 01-29-2015, 10:04 AM   #411
jetmech85
Re: Restoring Rusty
I would recommend when replacing the metal booster line to use a rubber hose designed for vaccum booster applicaitions and not fuel hose. Got mine at O'reilly's. They didn't know what I was talking about but fianally found a part number and ordered one.
jetmech85 is offline   Reply With Quote
Old 01-29-2015, 09:21 PM   #412
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so the second bracket arrived today, here are some pics of it, I took it appart to show you how it comes with three different attachments for three different applications I guess, I at least was a bit confused looking on the original image of it with all the brackets on there, so I took it apart to simplify things
the last pic shows you the one I was planning on using
Old 01-29-2015, 09:23 PM   #413
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
here is how the second bracket compares to the first
I must admit the first bracket is made out of much stronger material, the second one is super flimzy
Old 01-29-2015, 09:34 PM   #414
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Verdict: same problem as with the first bracket there is nothing stopping it from swiveling out too far and causing the cable to potentially bind, not good
now normally I would not be such a Diva about it, but again this is the throttle and I am not going to take any chances, the pics tell the story below, you can see that non of these brackets have a metal stub if you will that goes into that square hole in front of the bolt that holds the bracket down
Old 01-29-2015, 09:38 PM   #415
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
OK time to order a third bracket, yes ladies and gentlemen this is how the game is played, I call it Bracket Hell and I've been there before with Alternator brackets for a 302 [shrugs shoulders]
CARBURETOR THROTTLE CABLE BRACKET
Carburetor Throttle Cable Bracket For Use w/Holley Spread Bore Models 4165 & 4175
PART# 20-32
Suggested Retail: $34.56
Your Price:$31.10 of course it's got to be the most expensive one!
https://www.holley.com/products/fuel...ge/parts/20-32
Will the third time be the charm?
Old 01-29-2015, 09:43 PM   #416
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
On the brighter side of sports, I decided to delete the PCV system all together and replace the ugly hoses with breathers. I got this Spectre push in breather at AutoZone and a new rubber grommet for the passenger side valve cover, see what you think
I am not too crazy about the mushroom being chrome I would prefer it in black so I see some etch primer and a coat of semi flat in its future
by the way, naturally it doesn't sit quite flush because it interferes with that cable bracket on the valve cover ~ but that's how it all starts, now do I shave off the bracket or do I leave it or do I get different brackets, see how the game is played? one thing leads to another, to another
Old 01-29-2015, 11:15 PM   #417
greg64
greg64's Avatar
Re: Restoring Rusty
Greg, I know how frustrating those carb throttle brackets can be. I make my own, because I want to avoid exactly the problem you're describing. Now, I have seen some brackets that loop all the way around the carb and tie into both studs that hold the carb to the manifold.
But I really like the work you're doing.
About the fuel gauge, there's probably a break in the wire somewhere. When the tank is empty, the sender is 0 ohms. When the tank is full, the sender is 90 ohms. So when the wire breaks, the resistance goes to infinity, and the gauge pegs Full. It's a pink wire, at least on my 77.
By the way, you could run your brake booster off the tapped hole in the manifold that you plugged, instead of the carb, if that gives you a cleaner setup.
Keep the progress coming.
Greg
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 01-30-2015, 12:15 AM   #418
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by greg64 View Post
... Now, I have seen some brackets that loop all the way around the carb and tie into both studs that hold the carb to the manifold.
I recon you are thinking of one that looks like this, I just discovered it also, but I am not a huge fan of sandwiching that wrap around bracket in between two base carb gaskets, seems like doubling our chances of a vacuum leak, at $80 bones it is also pricey, but maybe this one will be my last resort
Old 01-30-2015, 12:21 AM   #419
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
then as if that wasn't enuff Bracketology Talk for you, there is this one to wrap your mind around as it wraps half way around the carb
$35 bucks and FREE shipping on Ebay says it is finally specifically for the 4150 and 4160 carbs, uses two bolts to mount up to the carb like God intended, what's not to like
Old 01-30-2015, 12:24 AM   #420
Chaplain
Chaplain's Avatar
Re: Restoring Rusty
Post the link for that.
Old 01-30-2015, 12:29 AM   #421
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
OK, now I am upset, upset with the guys/gals who designed the Holley website
I was looking for brackets under
Home / Fuel Systems / Carburetor Components / Brackets and Linkage /
makes sense right, look at that path it leads to Brackets and Linkage ie that's what I want a Bracket for the 4160 carb
but no those knuckleheads put the bracket I want the bracket specifically designed for the 4160 carb Part # 20-88 under
Home / Fuel Systems / Carburetor Components / Carburetor Accessories
"Accessories" for crying out loud?
~ you mean all this drama could have been easily avoided ~
Old 01-30-2015, 12:45 AM   #422
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I just had a similar experience at AutoZone. The young man was very helpful and took me to the back where they cut the hoses from large spools. He looked up at the rack in front of him and said we have Fuel Lines, Transmission Lines and Vacuum Hoses. I looked up at the rack and sure as sh!t it said on there, Fuel Lines, Transmission Lines, and Vacuum Hoses, LOL.
Then he hands me a 3/8ths transmission line and I feels it and it feels just too soft, so we move on and he says here this is what you need and hands me a Low Emission Fuel Injection line.
I remind him that what I need is a 3/8 vacuum hose for the brake booster, a line that will not collapse.
I ended up buying 3 feet of that Cadna 50088 fuel injection line. I'm no Hose Scientist or nothing but I recon a fuel injection line is more stronger than a regular fuel line, at least it feel strong and stiff
FYI, there is absolutely no writing of any kind on my old brake booster hose line to give me any clues as to what to look for in a line.
Old 01-30-2015, 01:34 AM   #423
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I hope this is what you meant and were after I found it on eBay
http://www.ebay.com/itm/130823372709...%3AMEBIDX%3AIT
if the link is expired then try this Title
HOLLEY 4150 4160 POLISHED ALUMINUM THROTTLE CABLE CARB BRACKET CARBURETOR 350
Old 01-30-2015, 05:52 PM   #424
rusty76
rusty76's Avatar
Re: Restoring Rusty
Keep on pluggin. You are doing a dang good job.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 01-30-2015, 09:02 PM   #425
portrodder
Re: Restoring Rusty
Great work and enjoying your build, keep it coming.
portrodder is offline   Reply With Quote
