Old 04-18-2017, 09:23 PM   #401
donandal
Re: Plus Five
Originally Posted by solidaxel View Post
Thanks I can do that!
I have a oil gauge screwed to the oil bypass on the side of the pan, but have not turned the engine over
It did not say to pressure the system until the rocker arms have oil before turning the engine over?
So with the starter motor only you have good oil pressure, did it come right up to 50# ?
We primed the engine first using a bug sprayer. I called Pace Performance a few months ago and they said to prime it like the videos on U Tube using a bug sprayer to pump oil. One of my friends in the local Chevy club knew how to do it.
It took only a couple of cranks of about 10 seconds to show oil pressure, and it was nearly 50 psi with just the starter cranking it, before we hooked it up to fire.
My oil pressure sender is hooked up in the same spot as yours, at the bypass fitting near the oil filter.
53 Chevy Pickup
donandal is offline   Reply With Quote
Old 04-18-2017, 09:34 PM   #402
donandal
Re: Plus Five
Forgot to mention, we also used the bug sprayer to fill the coolant. We disconnected the heater hose at the firewall after we filled as much as we could at the radiator, then pumped coolant into the heater core and hoses until it bubbled out from a little bleeder I had installed at the firewall on the other heater hose at it's high spot. I think we got it mostly air free.
I'm hoping the rest will fill from the reservoir after we run it some.
53 Chevy Pickup
Old 05-01-2017, 03:39 PM   #403
donandal
Re: Plus Five
I've been busy cleaning and packing up our house to sell it
and move to our new house we will be building.
I have had a few hours here and there so I built some straps to
help limit the door opening. Being five inches longer made it
heavy enough that I was concerned about depending on just the
upper door hinge pocket for the stop.
The strap has heavy steel brackets behind the rocker panels and door
cavities to carry the load. I had already welded in a hat channel into
the back of the rocker panel so it is very strong.
The strap I made from seat belt material.
It seems to work pretty well in conjunction with the original stop.
It doesn't have any stretch so I adjusted it to snug up just as the door
reaches its travel limit.
I just need to round all of the edges then paint it body color and it will
be done.
53 Chevy Pickup
Old 05-01-2017, 07:17 PM   #404
oldman3
oldman3's Avatar
Re: Plus Five
Very nice, and a slick ideal...Jim
oldman3 is offline   Reply With Quote
Old 06-26-2017, 02:38 PM   #405
II_Slow
II_Slow's Avatar
Re: Plus Five
Just had to float this build back to the top in case anyone missed it. There is some of the nicest fab work I've seen in this build. If you have never looked through it all, treat yourself to it. Might make you feel a little inadequate as a fabricator, but you'll learn a thing or two dozen!
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and
47RH AOD transmission
http://67-72chevytrucks.com/vboard/s...d.php?t=640042
II_Slow is offline   Reply With Quote
Old 06-26-2017, 10:26 PM   #406
34kw
Re: Plus Five
II Slow - Thanks for the bump. I had missed it and you're right - one of the nicest builds I've seen for sure.
34kw is offline   Reply With Quote
Old 06-27-2017, 06:04 PM   #407
donandal
Re: Plus Five
Wow time flies...
I've been busy moving to an apartment and lost track of time.
We sold our house and found a nice new apartment.
I haven't lived in an apartment since my wife and I were first married
and we had a lot of crap to move! And put in storage!
We will be building a new house for the next several months and then
moving again. Hope to retire there in a few years.
Probably good to be downsizing and building new, but it's a lot of work.
I hope to get back to the truck soon.
53 Chevy Pickup
Old 06-27-2017, 06:24 PM   #408
solidaxel
solidaxel's Avatar
Re: Plus Five
We are waiting!
Good luck with moving, not to ever be done again for me!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-27-2017, 09:13 PM   #409
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Plus Five
I've got a spare piece of land next door to me you can build a house on..haha..I wouldnt mind having your fab skills next door to me..
I must have missed the door straps...nice touch..
Old 06-27-2017, 11:08 PM   #410
34kw
Re: Plus Five
After careful review of this thread it seems like the only logical thing to do is go outside and burn my shop down.
Old 05-19-2019, 03:19 PM   #411
donandal
Re: Plus Five
Wow!!!!
Time really flies. I can’t believe it’s been almost two years.
Sorry it’s been so long.
Way more work to build a house than I thought, and most of it was contracted out.
House is finally done. We moved in last August. I haven’t touched the truck since we started building, except to fire it up once in a while. Hope to be back on the truck this summer.
53 Chevy Pickup
Old 10-14-2019, 11:41 PM   #412
MarKist
MarKist's Avatar
Re: Plus Five
any updates Captain?
Markist
oh well,..you'll have that!!
MarKist is offline   Reply With Quote
Old 10-16-2019, 01:22 PM   #413
donandal
Re: Plus Five
Hi again to everyone.
I am slowly getting back on the truck.
Spent most of September finishing the lawn around the new house.
What a job.
Here is the latest work on the truck.
I installed the stainless steel bed “ boards “ and bed trim.
53 Chevy Pickup
Old 10-16-2019, 01:25 PM   #414
donandal
Re: Plus Five
I’ll try to get more posted in the next few months as I expect more time in the winter to work on the truck.
53 Chevy Pickup
Old 10-16-2019, 01:54 PM   #415
MarKist
MarKist's Avatar
Re: Plus Five
looks awesome! I really hope you don't let your wife haul mulch in that bed, like you said. that would be a shame..
Markist
Old 10-20-2019, 05:36 PM   #416
donandal
Re: Plus Five
Started on the front end assembly.
We got the internal hood braces on, and installed
the stainless center strip and Chevy emblem.
53 Chevy Pickup
Old 10-20-2019, 05:43 PM   #417
donandal
Re: Plus Five
These pieces were reproductions, and they worked very well.
The strip fit perfectly and the tabs aligned exactly.
The emblem needed a little work on the back side to complete
the bend of the rear flange but took only a couple of minutes
with small hammer and bean bag.
Also not shown, the “3100” side emblems worked great too.
I did modify the pins that stick thru by threading them with
a 10-32 die, and used nylon lock nuts to hold them on.
I wanted them a little more secure than the slip on round clips.
53 Chevy Pickup
Old 11-01-2019, 04:01 PM   #418
donandal
Re: Plus Five
Got the hood, fenders and grill installed.
Gaps came out pretty good, after quite a bit of fussing.
53 Chevy Pickup
Old 11-01-2019, 04:11 PM   #419
dug224
dug224's Avatar
Re: Plus Five
Man, love the door strap detail! Moved to an apartment?? Yikes. Swore those off many years ago. Building a house as we speak. Hope to sell old house and move to new house in one motion.
dug224 is offline   Reply With Quote
Old 11-02-2019, 12:12 PM   #420
donandal
Re: Plus Five
In the apartment for about a year.
We are loving the new house now.
Probably more so because of the apartment experience.
Lots of time to work on the truck this winter.
53 Chevy Pickup
Old 11-09-2019, 05:20 PM   #421
donandal
Re: Plus Five
Installed the headlights, front bumper and front bumper balance.
53 Chevy Pickup
Old 11-15-2019, 05:46 PM   #422
donandal
Re: Plus Five
Video of the tilt hood,
Never tried this, but I think it works.
https://youtu.be/pbUqdMUvVRE
53 Chevy Pickup
Old 11-16-2019, 08:33 AM   #423
mongocanfly
Post Whore
Re: Plus Five
Well that's slick...!!!
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-16-2019, 05:52 PM   #424
donandal
Re: Plus Five
Thanks,
It sounds a bit noisy in the video, but is really not too loud.
I think it's the acoustics of the shop.
53 Chevy Pickup
Old 11-16-2019, 05:58 PM   #425
donandal
Re: Plus Five
Put the mudflaps on the front today.
53 Chevy Pickup
