03-15-2020, 09:25 PM | #401 |
Re: Frankentruck
It rained most of the morning, but this afternoon I was able to get the rag joint rebuilt and get the fresh Redhead box torqued down to the frame.
I should've done this 4 years ago when I put the disc brake kit in! Frankentruck steers much smoother now and I don't have to saw back and forth on the wheel to keep it going in a generally straight direction. Going over bumps doesn't even pull the wheel in different directions now. Money and time well spent for the fresh box
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
03-16-2020, 01:30 PM | #402 |
Re: Frankentruck
This crappy weather sucks. Instead of working outside on the truck this morning, I spent some time organizing my parts shelf and figuring out what I am keeping, and what I am selling. I didn't realize I had accumulated this much stuff
03-16-2020, 06:27 PM | #403 |
Re: Frankentruck
I bought a Flarestat hazard flasher switch a couple weeks ago and got a chance to install it today. It works great and looks like it was meant to be there
03-18-2020, 07:18 PM | #404 |
Re: Frankentruck
At some point, Frankentruck apparently had an old trailer hitch that was welded in and then torched off later. Additionally, the truck was rear ended which bent the frame a little bit. All it took was a pipe wrench and a hammer to bend the frame back enough to useable shape
Also spent some more time getting friendly with my Harbor Freight grinder to get rid of what was left from the old hitch. Taking the bumper off made all of that easier. I finished up the install today and got the bumper back on. The truck already has trailer wiring and a trailer brake controller, so now that I've got a good hitch, I'm ready to tow some stuff Funny story: I left my 9/16 and 5/8 socket sitting on the wiper arm when I was working on the truck yesterday. I then forgot to grab them before I drove up to a local body shop to ask what I should do about the frame. When I pulled into the shop's driveway, my 9/16 fell off the truck. Didn't realize it was missing until today, so I drove back there and found it half way squished into the gravel. Both sockets are safe and sound in the garage tonight
03-19-2020, 08:58 PM | #405 |
Re: Frankentruck
Another day, another task completed
The burlap material used to keep the springs from cutting into the foam. Well, it was no longer up to the task, so for a cheap and easy fix, I decided to throw a piece of carpet down between the foam and the springs. I was surprised to find that none of the seat springs are broken. Eventually my budget will allow me to get an original style seat done properly, but for now, this will keep my bum happy on longer trips and the seat won't look completely blown out anymore I've been driving the truck since I got the new steering gear in and dadgum, it's so nice. That will be one of the first things I do whenever I get another project truck
03-20-2020, 12:35 AM | #406 |
Re: Frankentruck
Man, liking the progress!
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
03-20-2020, 12:42 PM | #407 |
Re: Frankentruck
Thanks!
No online class until the 30th and staying at home because of the Carona means that I have plenty of time to make a bunch of progress. I've had parts accumulating since Christmas that needed to go on the truck, so might as well do it now
03-20-2020, 08:07 PM | #408 |
Re: Frankentruck
It took pretty much all day to do it, but I got the door hinge pins and bushings replaced. The passenger door fought me from the beginning. One of the hinge pins had broken off inside the hinge and rusted together, so I had to end up drilling through what was left of the pin and cutting it off before I finally got it hammered out. That was after several hours of trying to hammer it out beforehand
Everything is back together and the gaps are much nicer around the entire door
03-23-2020, 12:43 PM | #409 |
Re: Frankentruck
Took a break from working on the truck to get dad's boat out of the garage. Last time we had it out was in 2014. We got it out on the water one time that summer, and it has sat ever since. Before 2014, it hadn't been out on the water in 7 years. So since 2007, it's been out one time. At least it's been in the garage all these year.
So far, everything has worked on it, but we have not tried to start it yet. The gas we put in 6 years ago has gone bad so we have to drain the tank first. Now that I have a trailer hitch on Frankentruck, I just might have to hook up the boat and do some social distancing out on the lake
03-25-2020, 10:29 PM | #410 |
Re: Frankentruck
I purchased a 67-72 door switch harness from Fred a couple months ago, and I finally had a chance to install it today. The harness had been cut up by someone else, which ended up being good for me because I picked up some floor lamps from the front dash of a Jeep XJ and spliced them in. To mount the floor lamps, I trimmed them to better fit on the speaker mounts I made a while back. Also threw some paint on the lamp brackets and got the holes drilled and tapped for the door switches.
03-25-2020, 10:34 PM | #411 |
Re: Frankentruck
For the driver's side, I had to drill a hole into the cab. On the passenger side, I just used the radio antenna hole.
I thought about getting two more floor lamps, but just the pair I have lights up the floor nicely. I'm not even using LED bulbs The door switch harness plugs in between the harness for the dome lamp, so the dome and floor lamps turn on whenever the doors are open or when the dash switch is turned on. The last two pics show the before and after. Well worth drilling more holes in my cab
03-26-2020, 09:51 PM | #412 |
Re: Frankentruck
I got the 60 glove box door script installed today. The truck it came off of had been sitting with the glove box door open all this time, so the script and barrel nuts are in great shape. It was easy to do and it made the passenger side less bland.
Best part is I paid $7 for the emblem
04-05-2020, 04:51 PM | #413 |
Re: Frankentruck
All clean with nowhere to go
04-07-2020, 12:09 PM | #414 |
Re: Frankentruck
Great work and progress from the beginning to now. Keep at it. Its great to see the youth take interest in these old trucks. Job well done Christian.
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692 70 C-30 Tow truck AKA Highlighter 02 Silverado 2500 HD CUCVII Tow Rig/DD 1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800 1980 Buick Regal Dirt Stock car |
04-07-2020, 02:23 PM | #415 |
Re: Frankentruck
Thank you for the kind words!
04-19-2020, 12:57 AM | #416 |
Re: Frankentruck
Unfortunately, I haven't done anything to Frankentruck since I washed it. Online school has kept me super busy for most of the day.
I went to go out for a drive, but I guess the starter had other ideas. Every time I turn the key, the dash lights just dim down. No clicks or sounds from the starter at all. Oh well, I guess I'll look into it in 2 weeks when I'm done with this semester. I hope y'all are staying safe out there!
04-19-2020, 12:58 AM | #417 |
Re: Frankentruck
How old is the battery?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
04-19-2020, 01:11 AM | #418 |
Re: Frankentruck
Not sure, but I think the glove box door light that I had installed got pushed back far enough where it ended up staying on and I didn't notice it. The battery in the truck has 7.74 volts because of that, but I had no issues at all until I missed that light. I hooked it up with jumper cables to a battery with 11.5 volts. No noise or anything from the starter on either battery. Just dims the lights lol
04-19-2020, 09:30 AM | #419 |
Re: Frankentruck
Do you have a charger ? If not you can borrow mine or my jump box . Neither of your batteries have full voltage .
04-19-2020, 12:44 PM | #420 | |
Re: Frankentruck
Remember when we went to the swap meet at Paradise dragway last year? I think it might be doing the same thing that it was doing then. I don't remember what we did to fix it though
04-20-2020, 01:17 PM | #421 |
Re: Frankentruck
11.5 volts should be enough to at least make some clicking noises I would think.
Be sure to check all your connections!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1998 chevy c1500 4.3L 5speed (My current driver) 2002 Chevy s10 4.3L auto 4x4 1971 mercury monterey wagon 400 auto To many projects! |
04-20-2020, 03:35 PM | #422 |
Re: Frankentruck
Having voltage, and having current, are two different things.
Charge that battery up, and then try.
04-20-2020, 10:49 PM | #423 |
Re: Frankentruck
Thanks guys, I will hopefully get a chance to look at it some time later this week, but my main focus right now is doing well on my audit exam on Wednesday and the 4 final exams I have next week.
This is the starter that was on the truck when I bought it, so I wouldn't be surprised if it finally gave up. I have been having issues of the bendix spinning but not shooting out, and since December it seems to have been getting worse.
04-20-2020, 11:09 PM | #424 | |
Re: Frankentruck
You can clean the commutator bars off and replace the brushes. If that stuff is still available? I sure it is
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
04-20-2020, 11:17 PM | #425 | |
Re: Frankentruck
When I did the engine swap, I used the reman starter that came with it. Since then, it failed, so I put the starter from the old engine back on. It was on borrowed time when I put it back on Anyways, since I probably have two cores, I can send the reman one back as a core for another parts store reman if I can't rebuild the older one myself.
