06-25-2016, 01:06 PM | #4251 | |
Post Whore
Re: Restoring Rusty
looks like it's going to be 100° F today and for the next five days, Awesome... Not! |
06-25-2016, 01:24 PM | #4252 |
Re: Restoring Rusty
I plan on building racks similar to your so I can haul 20' lengths of steel. I will likely have an extension over the cab.
However, I would place the cross bar lower, so the posts stick up above the cross bar to help keep things UP and not fall down. Gives you something to tie stuff against. For Kayaks, though, it probably doesn't matter.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
06-25-2016, 03:13 PM | #4253 |
Re: Restoring Rusty
Take pics once you get the kayak up on it. I want to see it.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
06-26-2016, 01:06 PM | #4254 |
Post Whore
Re: Restoring Rusty
found some rust under the doors, which was expected, fortunately its just surface rust
so a short dance with the wire wheel followed by a paper towel acid bath and we will be ready for primer in no time P.S. got a call from my buddy Lucifer he asked if I wanted to come down to his place to cool off today, (day 2 of over 100° F streak) |
06-26-2016, 03:03 PM | #4255 |
Re: Restoring Rusty
I would think Lucifer's place would be much hotter.
06-26-2016, 04:52 PM | #4256 |
Second Chance Program
Re: Restoring Rusty
Do like progress!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
06-26-2016, 04:55 PM | #4257 |
Re: Restoring Rusty
That's what I was thinking too
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
06-26-2016, 06:18 PM | #4258 |
Post Whore
Re: Restoring Rusty
simple ~ and as my buddy puts it "A Truck doing Truck Things!!!"
06-26-2016, 06:21 PM | #4259 |
Post Whore
Re: Restoring Rusty
in the front I use the holes in the purches to hold the tie downs, in the rear I had to bolt back up the hooks I removed when I first got the truck, lol, but this time I mounted them underneath, these are temporary and will do for now, ie this trip
06-26-2016, 06:24 PM | #4260 |
Post Whore
Re: Restoring Rusty
now back to the door hinges, here they are off the truck, I wasn't going to let one missing bushing prevent me from taking these pics after it went missing, of course I found it as soon as the pics were taken, ha ha
I can't believe how I loose things all the time, its as if there was someone hiding in my garage just pranking me all the time |
06-26-2016, 06:27 PM | #4261 |
Post Whore
Re: Restoring Rusty
and a mandatory old door hinge pin and old pushings along side a new pin and new bushings
06-26-2016, 06:28 PM | #4262 |
Post Whore
Re: Restoring Rusty
06-26-2016, 06:31 PM | #4263 |
Post Whore
Re: Restoring Rusty
and new bushes going in (not sure what these are made of - some orangy stuff) with a liberal coat of white lightning bacon grease
the top one slid it beautifully... |
06-26-2016, 06:32 PM | #4264 |
Post Whore
Re: Restoring Rusty
the bottom one was a bit shy
06-26-2016, 06:33 PM | #4265 |
Post Whore
Re: Restoring Rusty
had to use a rat tail file to open up the hole a bit (GM gods forbid I had a proper sized drill bit) to have used that instead, and made guick job of it
06-26-2016, 06:35 PM | #4266 |
Post Whore
Re: Restoring Rusty
and wouldn't you know it, the door still sags as it did before, so once I again I fixed things not needin' fixin, I recon my old bushes was fine, it was just hinges that needed proper adjusting - and still do, I bet the fender needs to come off for that type of action, fun level = 2
06-26-2016, 06:38 PM | #4267 |
Post Whore
Re: Restoring Rusty
now there are things that need doin', things you ought to be doin', things that need to be fixed, things that you oughta fix... BUT THAN THERE's things you WANT to do
06-26-2016, 06:39 PM | #4268 |
Post Whore
Re: Restoring Rusty
hey, what ever, works for me
06-26-2016, 06:42 PM | #4269 |
Post Whore
Re: Restoring Rusty
Yup I finally decided this truck suffers from TMG
Too Much Green |
06-26-2016, 07:22 PM | #4270 |
Re: Restoring Rusty
I say leave the one stripe and don't do another lol. Also if you want to save your doors spray some lubrication oil down the insides.
The doors normally rust from inside out because of bad window seals at the top. |
06-26-2016, 07:33 PM | #4271 |
Re: Restoring Rusty
Nice! I like the single stripe a lot.
Matt |
06-26-2016, 08:13 PM | #4272 |
Re: Restoring Rusty
I like seeing trucks doing what trucks do. Nice.
06-26-2016, 11:26 PM | #4273 |
Re: Restoring Rusty
I will likely be shunned from Gregskis build and the forum for all eternity for posting these pictures of my daily driver but I will risk it we are like brothers Gregski!
"Orange Crush" |
06-27-2016, 10:10 AM | #4274 |
Post Whore
Re: Restoring Rusty
Wow yup, I can barely tell our vehicles apart, ha ha. By the way how did you manage to swap an LS into that little Honda Cervix (wink wink)
06-29-2016, 08:04 PM | #4275 |
Post Whore
Re: Restoring Rusty
removed the door striker pin (came out much easier than expected with that torques star screw thingie, I thought I was gonna strip it fer sure) so that it would not interfere with the door alignmentability
with it worn the way it be, it's time fer a new one soon |
