#4326 |
Re: What did you do to your truck today? Chapter II
Washed the tires and out to a show.
#4327 |
![]() Join Date: Jan 2007
I live in California, but identify as a Texan ![]() "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#4328 |
![]() Join Date: Jul 2015
Bought more Parts, feed me, ffeeeeeeedddd mmmeeeee!
#4329 |
totally laughed out loud at this. shared it with my wife and she made fun of me and laughed that there's someone else out there who loves their truck as much as me. lol!
#4330 |
Finally got my 71 back on all 4's. After it being on stands all summer for a dana 44 refreshing and a front spring up grade. As you can see still lots of work too do.
Next up is putting in all the new steering components with a ps up grade ![]() Gotta get it roll able so i can push it into the garage for a lil' welding On the firewall at the bottom of the heater box mount. Then the 400ci. can get dropped in. This winter i'll do the rockers and other sheetmetal work.i hate being all dressed for cutting and welding in the heat of summer. VERY SLOW WORK as its not a priority.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#4331 | |
what are your plans with them ?
1972 Chevy C10 Custom Deluxe Highlander 1972 Chevy C10 Custom Deluxe Medium Green |
#4332 | |
![]() Quote:
Was that on the cam tag ? . New or re ground cam and solid or juice lifters , new/reground ? . TIA, I like bench works and engine overhaul/rebuilding so I like to discuss /learn new details any time I can .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#4333 | |
Re: CamShaft Breakin Details
Attached is a cam break-in write up that I found online, I don't remember where, but props to the author because it is great.
'67 c10 cst farm truck |
#4334 |
![]() Join Date: Dec 2012
Finally scored the correct fuel adapter to finish my fuel line replacement
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#4335 |
Installed a correct square bore to spread bore plate in search of my low vacuum issue. It didn't improve the vacuum.
1970 C10 Short Stepper with 71/72 front clip. |
#4336 | |
![]() Quote:
That's pretty good . If I'm using a new cam I follow this almost exactly, if re using an old cam I use 3,000 RPM's ~ either way if you set everything up correctly , the entire engine breakin is done in 60 seconds .
#4337 | |
https://www.youtube.com/watch?v=GdQxrL3diWE If the link doesn't work just go to youtube and type in: "SBC 383 xe274h Camshaft break-in"
#4338 |
Picked up my original driver's side front outer fender from the painter. The guy did an excellent job welding up three rust holes. He used pieces from a 1968 Buick Skylark, so even the patches are General Motors and "period correct."
![]() ![]() ![]() ![]() ![]() Last edited by In The Ten Ring; 09-16-2016 at 11:07 AM. |
#4339 |
#4340 |
![]() Join Date: Nov 2007
Got my new old lookin' tach installed.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
#4341 |
I cleaned up and painted my lower steering shaft, and added a tilt steering column. I need to know which U-Joint to order to complete the job.... Anyone know?
#4342 |
#4343 |
#4344 |
Thanks!! I can post more pics of it here soon. It's getting color sanded and polished and finished up this weekend hopefully.. My buddy Greg from fullers machine did my emblems and my boy Michael "sic" Cato did the roof and panels on my truck we wanted something a lil different on the truck.. C-10 club brother Aaron Boise is responsible for doing my bodywork and painting the whole truck including dash..
#4345 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I'm selling the buddys and keeping the buckets and console for my truck.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#4346 |
![]() Join Date: Sep 2009
Painted the inner grill on my 71.
#4347 |
I painted that reinforcing bar that attaches the driver's side inner fender to the front of the truck's frame.
The best paint I had for the job was Rustoleum Engine Enamel but I primed it first and it seems to be curing well. |
#4348 |
found that you can lock all four drums in a panic when a chick in a Honda talkin on her cell runs a stop sign . get it home safe and drive into the ditch in the end of my drive way . too dark to see the damage so much for those 14 hour days this week
#4349 |
Hey guys,
I want a steering column that is between 2 to 3 inches shorter (I want to move the steering wheel closer to the dash). Anyone know if there is a vehicle that has a column that would do what I'm wanting? I'm not really concerned about tilt, but it's not a deal breaker. I think I saw something about some of the Camaro's columns doing this, but I can't find it. |
#4350 |
![]() Join Date: Feb 2009
Finished pulling wire less the cab. Cleaned parts and put em away............So fun.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
