#4451 |
Re: What did you do to your truck today.The 3rd chapter
Ordered rear brake hardware kit, front brake hoses, wheel bearings, races, seals, inner & outer tie rods, sleeves, idler arm, and ball joints.
Cleaned up spindles, backing plates, rotors and calipers. Parts should be in soon, and I can slap it back together. |
#4452 |
After over a year of being apart for lotsa changes, I have power once again!
Everything confirmed working, except the tach. (Have not started the engine yet) Vintage Air with DDC-4000 controller. I made the control panel out of a block of aluminum, and installed a couple of push buttons. The one lit up is for the electric fan over ride, working. The other is for the electric fuel pump. (Off in the picture, but I did test it.) Words can't explain how excited I am!
"If it ain't broken, fix it 'till it is!" |
#4453 | |
Who Changed This?
![]() Join Date: Jan 2013
#4454 |
Thanks!
I should clarify...I used the stock temperature controller, and gutted it. The aluminum block/panel you see is sitting inside the stock controller, held in place by the DDC-4000 mounting brackets. It really turned out good, I think. The block of aluminum was like $20-$25. No welding in patch panels, or paint matching.
#4455 | |
![]() ![]() Join Date: Mar 2016
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() |
#4456 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Went and picked up my rear brake drums from a friend who had blasted and painted them, with VHT Caliper Pain, as it drove me nuts since I installed the TT2's seeing the crusty drums through the spokes. Callipers were painted when front end was rebuilt last Winter.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#4457 |
Working on these vehicles can be jumping down a rabbit hole. I borrowed a ball joint press and got the old joints out. That’s when I noticed some play in the A arm shafts. So I will order new upper and lower A arm shafts. Fortunately Rock Auto has a great price on them, but it all adds up.
It will be worth it when it’s done. I was able to get all the A arms, shafts and removed out steering components. Will clean up what isn’t being replaced. |
#4458 |
Waited for my Son to come home for Christmas, so he could be there for the first fire up of the new engine.
He took a video of it. Exhaust just has a 45* piece on each collector to direct the exhaust away from under the truck. https://youtube.com/watch?v=CmFBpei_...S_eN7smUFW8V8n
"If it ain't broken, fix it 'till it is!" Last edited by Extended Power; 12-24-2023 at 04:59 PM. Reason: Video link attached. |
#4459 | |
![]() Join Date: Feb 2002
#4460 |
Not today, but Friday I received a new radiator for my '35.
#4461 |
Installed courtesy lights this evening.
#4462 | |
#4463 |
#4464 | |
But I have never been able to leave anything stock. I bought the truck four years ago...it was running and so had changes done to it...but not even being able to start, and drive it for over a year, has been very hard. I never intended for it to take that long, but it just snowballed all at once. Sure does! The wife wanted to hear it with no exhaust, so you know...who am I to deny her? Lol
"If it ain't broken, fix it 'till it is!" Last edited by Extended Power; 12-25-2023 at 02:25 PM. |
#4465 |
Yea, I love those under dash lights. Put them in my truck and used LED Bulbs. I put an LED bulb in the dome light as well.
#4466 |
#4467 |
Since I had the A arms off to replace the shaft, I thought I would clean them up. I wire wheeled the major crud off, glass beaded them, and painted.
#4468 | |
#4469 | |
![]() ![]() Join Date: Apr 2022
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
#4470 |
Got the exhaust done up to the mufflers, and called it a day.
But what's a post without pictures and video?! 3" exhaust with Flowmaster Super 44 mufflers. Lol...gonna need a new oil pressure gauge with a higher range. The 0 to 60 psi ain't gonna cut it. https://youtu.be/1GsllcchyT8?si=rimvyzTB5SdpH166
"If it ain't broken, fix it 'till it is!" Last edited by Extended Power; 12-30-2023 at 10:57 AM. |
#4471 |
Cleaned and painted the center link. I setup the new tie rods to match the length of the old ones. Then bolted them to center link.
Installed new ball joints and control arm shafts. Wire wheeling front frame area to get ready to paint. I ordered new control arms u bolts from LMC, they sure take their sweet time getting my order ready before they ship it. How hard can it be to scrounge up 4 bolts and toss them in a box??? |
#4472 |
I ordered a level 3 PB drop member kit
#4473 |
Wire wheeled frame and inner fenders. Painted frame with rust oleum brush on satin black. Used rust oleum rubberized spray on the inner fenders.
Now that that mess is finally done, I can start re assembling the front suspension and steering. |
#4474 |
Got one side together
#4475 |
Got both sides assembled. Installed the new shocks and upper shocks supports. Got the steering linkage installed.
Getting close now. |
