Old 08-16-2010, 12:42 AM   #426
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 08-16-2010, 01:30 AM   #427
3r!c84
Badass
3r!c84's Avatar
Re: my 80 build
Plan on doing any proformance mods to it? Cam,intake,headers,tune. Youknow tge works lol.
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 08-16-2010, 01:38 AM   #428
flamingbig10
6.0 powered square
Re: my 80 build
yes cam, headers, cold air intake, tune, converter and 373s
Aaron
Old 08-17-2010, 01:12 AM   #429
flamingbig10
6.0 powered square
Re: my 80 build
I got the motor on a stand and started wire brushing the rusty block and degrease d it a little but I need to get some duct tape before I do a full clean and then new gaskets and paint
Aaron
Old 08-17-2010, 01:13 AM   #430
spudz
spudz's Avatar
Re: my 80 build
sweet......
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 08-17-2010, 01:21 AM   #431
flamingbig10
6.0 powered square
Re: my 80 build
thanks, tomorrow if I have time at work I'll see if I can't pick up a 4l80e, and order a ACDelco EP381 fuel pump so the fuel tank will be complete on inside then a coat of rattle can black on the outside
Aaron
Old 08-21-2010, 10:38 PM   #432
flamingbig10
6.0 powered square
Re: my 80 build
got the fuel pump 107 dollars from a gm dealer.just need to get some high pressure hose clamps, then paint the tank, painted the motor some what, and picked up a few parts drive belt, thermostat, and a/c delco plugs
Aaron
Old 08-22-2010, 12:19 AM   #433
flamingbig10
6.0 powered square
Re: my 80 build
I didn't bother painting the timing cover and oil pan since I'll be installing a cam and will be installing a shallower oil pan
Aaron
Old 08-22-2010, 01:35 AM   #434
flamingbig10
6.0 powered square
Re: my 80 build
a few maybe parts for 6.0
a tr224 cam
http://www.thunderracing.com/shop-by...ain/Camshafts/
a custom stall converter probably a 3200 stall
http://cgi.ebay.com/ebaymotors/GM-4L...Q5fAccessories
Aaron
Old 08-27-2010, 09:30 AM   #435
flamingbig10
6.0 powered square
Re: my 80 build
few change of plans I'm going to do a frame off frame swap since mine has been shortened and its bent, its been likes this a lot longer than Ive had it
Aaron
Old 08-27-2010, 10:01 AM   #436
JohnC
JohnC's Avatar
Re: my 80 build
And so the snowball begins.
It's better to do it now, or it will bug you from now on. Take your time. As good a job as you have done on the truck so far it should turn out great.
JohnC is offline   Reply With Quote
Old 08-27-2010, 10:09 AM   #437
menace121978
menace121978's Avatar
Re: my 80 build
X2! good advice John
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 08-27-2010, 02:27 PM   #438
bakerboys
bakerboys's Avatar
Re: my 80 build
what type of exhaust do you have on truck
also how wide of a rim can I fit on back of mine
1977 swb
What are the total inches you lowered the truck
LOOKS NICE
bakerboys is offline   Reply With Quote
Old 08-27-2010, 07:35 PM   #439
flamingbig10
6.0 powered square
Re: my 80 build
oh I no I been wanting to it 4 years since I noticed the frame was hacked and nothing lines up and also when I patched the floors I used lmc lay over floor pans over the rusty floors so I will be cutting those panels out with new pans, the lower cowl panel has a little rust and when the past owner shorted the frame he curled up the rear brake lines so I plan on installing all new brake lines.
Aaron
Old 08-28-2010, 10:31 AM   #440
flamingbig10
6.0 powered square
Re: my 80 build
1977 swb
LOOKS NICE
I have true dual header header back exhaust with 2 1/4 pipe that ends behind the rear tires with flow master 40 series, I would like to go with 3" with x pipe and flow master 10 series. For wheels if you have the right back spacing and a little trimming you can fit a 11" wheel, and the drop is a 5-7
Aaron
Old 08-28-2010, 12:20 PM   #441
breeze85cten
Re: my 80 build
If your looking for a good convertor circle d's are great.
breeze85cten is offline   Reply With Quote
Old 08-28-2010, 01:14 PM   #442
flamingbig10
6.0 powered square
Re: my 80 build
Ive heard good things about the circle d's the price isn't to bad either compared to the other well known converter companies
Aaron
Old 08-29-2010, 01:08 AM   #443
breeze85cten
Re: my 80 build
I bought a circle d not too long ago for my set up. I have a 4.8l with a big cam and alot of extras but havnt got far enough to start her up but I did my research and circle d is just as good or better then the rest.
Old 09-03-2010, 06:02 PM   #444
bakerboys
bakerboys's Avatar
Re: my 80 build
hey big10
If you dont mind what kind of rims are those Jegs says no one make racing type wheels with 5.5 bolt pattern for my 77 swb any info would be great
thanks
Old 09-03-2010, 06:20 PM   #445
mooseknuckles
mooseknuckles's Avatar
Re: my 80 build
hey big10
thanks
5x5, 5 on 5 or 5x127mm
mooseknuckles is offline   Reply With Quote
Old 09-03-2010, 06:31 PM   #446
bakerboys
bakerboys's Avatar
Re: my 80 build
thanks what about the back spacing
Old 09-03-2010, 08:00 PM   #447
flamingbig10
6.0 powered square
Re: my 80 build
i'm running 4.125 front with a 7" wheel and back 8" the wheels are cragar street stars
Aaron
Old 09-03-2010, 08:21 PM   #448
bakerboys
bakerboys's Avatar
Re: my 80 build
just to be clear backspacing for front and rear is 4.125 right
Old 09-03-2010, 11:37 PM   #449
flamingbig10
6.0 powered square
Re: my 80 build
yes but the sad thing is cragar doesn't make these wheels any more but summit racing still sells them is 15x12s and 15x14s though
Aaron
Old 09-04-2010, 08:39 PM   #450
bakerboys
bakerboys's Avatar
Re: my 80 build
WOW who new rim options would be such a problem
