Old 04-11-2012, 02:34 PM   #426
kikkegek
kikkegek's Avatar
Re: late build thread...LOL
^^^sweet pics dude! one of the sickest Burbs around!
kikkegek is offline   Reply With Quote
Old 04-11-2012, 05:19 PM   #427
SBTork
Garage wrench
SBTork's Avatar
SO MUCH!!!
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 04-16-2012, 08:53 AM   #428
trout
Originally Posted by justpball View Post
Oh and put tinted 90 style lights in the burb, with HIDs
more pics and info on the lights please
Edited by staff
trout is offline   Reply With Quote
Old 04-16-2012, 11:14 PM   #429
Leedogg
Just like everyone else has said....I love this Burban! NICE WORK.
1989 Chevy Crew Cab Dually - 454/400, Trans Am Hauler, Future bagged project.
96 Trans Am: 383/m6 - 11.98@115 on 315 M/T D/R's - 408rwhp 394 rwtq
05 VW Passat TDI - 38mpg @75mph
07 Bandit 1250S - Two wheeled fun!
Click here to see my FQuick Garage!
Leedogg is offline   Reply With Quote
Old 04-17-2012, 06:31 AM   #430
justpball
justpball's Avatar
Thanks guys, the 90 style lights... I bought them off eBay and they have the black plastic mounting unit on the back so you have to trim out the core support and mount the lights from the back side... I used long carrage bolts and 3 nuts on each one... Drill 4 holes, one on each corner of mounting bracket, then drill matching holes on the core support, stick the carrage bolt in the core support and run a nut up and tighten it, run another nut on the bolt all the way down, put the light in and get it close to where you want it then bring the second nut back to it... Put the third nut on and tighten it up so your mounting bracket is sandwiched between the 2 nuts, this will give you some adjustment as well. From there it is just fine tuning them until you are happy with the fit and most of all the focus of the
Lights. All in all it is a very easy swap... Def need a Sawzall or plasma cutter and a few hand tools... I'll take some pics from the back side when I can and it will make more since... LOL
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 04-17-2012, 11:58 AM   #431
watahyahknow
watahyahknow's Avatar
it looks nice i know of another guy that spayed his original rearlights in that darkening stuff in a rattlecan but he put a couple of coats of clear over it , flattened them with 1000 grit waterproof and polished them after that and they look verry factory and realy shiny
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 04-20-2012, 02:11 PM   #432
1984chevypickup
I read the whole build up and I love the truck the colors and all the work you have done to it I also own a burb same year but it's 4x but it needs way more work and right now I have a 84 k10 I an working on you gave me alot of good ideas for my truck. I am a new member and so far I am loving this forum everyone has so much good ideas that I can run with. Love those door pods but I have a question what kind fiber glass did you use? And did you use a mdf then glass to that or did you use a foam and carv it out and glass over it anyways sweet burb and thanks for the ideas
1984chevypickup is offline   Reply With Quote
Old 04-20-2012, 02:24 PM   #433
justpball
justpball's Avatar
Welcome to the forum! I will do a how to on the door pods....
87 Crew SWB
Build for the crew
90 burb 2wd
Old 04-20-2012, 04:35 PM   #434
1984chevypickup
Alright badass and when you going to put that grill on I think it will look good I am thinking about making one kinda like that. Phantom grill but instead of the billet I want to use the wire overcrowding each other kinda like a strut grill or rbp. Another question what the rest of your plans for the interior?
Old 04-20-2012, 04:44 PM   #435
watahyahknow
there a few how to's to be found on the internet , there even have some youtube movies about them
the usual way to do it is to make rings and squares out of mdf where the speakers and watever else you want to mount intoo the doors fit intoo and use hotglue nails screws and little scraps of mdf to orientate them on a base in the direction you want the speakers to point and still be able to close the doors and figure out a way to mount the setup ontoo the top part of youre doorcards once there done
when youre happy with the setup you use fleese , thats the same fabric they use in cheap joggingtrousers housepants sweaters and stuff like that and you tention the fleese over the whole thing you made from mdf and tack it all over with a tackgun
once it tightened over the mdf cut the fluf thats on the back and you dont need
then you mix standard fiberglass resin the same stuff they use for boats or watever and soak the fleese in it
once thats dried you either use resin and pieces of fiberglass mat or use stuff called kittyhair its fiberglass hairstrands in resin thats ready mixed you only need to mix component B intoo it and aply like clay over the fleese , that will give a LOT of extra strength
after that you need to grind sand aply normal automotive filler and sand fill sand fill sand fill sand etc untill youre happy with the smoothness and shape
than you paint and mount them run the wires and mount the speakers
Old 04-20-2012, 06:01 PM   #436
1984chevypickup
Yeah I get the whole prosses but i was just wondering how he did his because there are so many different ways. I don't really like the cat hair I would rather lay the glass mat. Wouldn't it get to thick with the cat hair and block sound waves? Thank for the input
Old 05-16-2012, 08:37 AM   #437
justpball
justpball's Avatar
Got around to building my amp rack...
87 Crew SWB
Build for the crew
90 burb 2wd
Old 05-16-2012, 09:08 AM   #438
kikkegek
kikkegek's Avatar
sweet! is that snake skin?
Old 05-16-2012, 09:38 AM   #439
justpball
justpball's Avatar
Caiman or alligator...
87 Crew SWB
Build for the crew
90 burb 2wd
Old 05-16-2012, 09:39 AM   #440
kikkegek
kikkegek's Avatar
Old 05-16-2012, 10:57 PM   #441
dragitvinn
That has to be the burban built!! Great job bro
1972 Chevy suburban sale
dragitvinn is offline   Reply With Quote
Old 05-17-2012, 06:53 AM   #442
justpball
justpball's Avatar
Thanks bro!
87 Crew SWB
Build for the crew
90 burb 2wd
Old 05-17-2012, 06:57 AM   #443
justpball
justpball's Avatar
Use spandex as your top because it is nice and slick so you get a smooth surface to start with.... Then add the glass mat to the inside... A lot less time doing bodywork to it...
87 Crew SWB
Build for the crew
90 burb 2wd
Old 05-17-2012, 07:22 AM   #444
watahyahknow
thats a good idea if you can reach inside it all around
the thickness is actually good for the soundwaves , you dont want the box to flex as it causes standing waves (makes certan tones/frequencies come out louder than the rest )
Old 05-17-2012, 08:46 AM   #445
justpball
justpball's Avatar
Yea sometimes you have to cut the back out to get to it, then put that piece back in and glass it to...
87 Crew SWB
Build for the crew
90 burb 2wd
Old 05-17-2012, 03:15 PM   #446
justpball
justpball's Avatar
Originally Posted by 54Caddy View Post
you ever get the A-Arms in?? Also since you narrowed the lower did you do the uppers also? This would also narrow your track width so what did you do about your tie rod ends did the clear when adjusted without touching each other or did you trim them down some?
You need to trim your inner tie rod 1/2 and the outer a 1/2...
87 Crew SWB
Build for the crew
90 burb 2wd
Old 06-12-2012, 07:07 PM   #447
csa daddy
csa daddy's Avatar
In the first post the fifth pic down what all had you done was it just drop spindles an bags an how big of a notch was in it to start with
csa daddy is offline   Reply With Quote
Old 06-13-2012, 01:52 AM   #448
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
dude. hadn't seen the burb in a while. flippin sweet.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 06-13-2012, 09:59 AM   #449
justpball
justpball's Avatar
Yea 2.5 spindles and bags.... 4inch notch...
Thanks smashing!
87 Crew SWB
Build for the crew
90 burb 2wd
Old 06-13-2012, 12:47 PM   #450
csa daddy
csa daddy's Avatar
Cool thanks
