Old 12-08-2017, 05:22 AM   #426
ls1nova71
ls1nova71's Avatar
Re: 67-72 Electric speedo
Caustik, are you trying to use a '94 speedometer? If so, I don't think it will work. I have tried using one of those, but could never get it to be as accurate as the '96. I don't know what resistor you're going to change on it, but don't thonk it's going to be that simple since the older speedobused a circuit board that was about half the size of the newer one. If it's an availability problem, I can probably get you one.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-08-2017, 09:47 PM   #427
Caustik
Caustik's Avatar
I am just using this one for mockup and playing with it a little while waiting for my other cluster and PCM to come in. I am only basing this as a hunch from the V8 conversion in my s10, initially when setting up the stock Tachometer for the v8 I soldered to the wrong circuit and it caused my speedometer to accelerate at about 3 to 1. if it works then cool, if not at least it gave me something to do while waiting for more parts.
Caustik is offline   Reply With Quote
Old 12-20-2017, 02:10 PM   #428
Steve Cole
Question for Eric, (or anyone else who knows) - when I push down the reset knob for the trip meter, the locking bar pulls away from the numbers but they do not roll back to zero. I can manually turn them to zero while holding down the rest knob but they don't spin on their own. Is this broken or does the cluster need to have power applied for this to work? I wouldn't think that is the case, but I see no reason for this not working.
Thanks!
Steve Cole is offline   Reply With Quote
Old 12-21-2017, 12:58 AM   #429
ls1nova71
ls1nova71's Avatar
Thanks!
They're spring loaded, so that when you push the button down, they roll back to zero, no power needed. It sounds like the spring may be broken or something is binding them. Is this with everything installed, or not?
Old 12-21-2017, 09:40 AM   #430
Steve Cole
This is uninstalled, just holding it in my hand. If you are talking about the spring on the plunger itself, it is fine. When I push the plunger (knob) down, it is spring loaded back up. When I push it down, I can see that bar at the top side of the numbers that keeps them from rotating, move out of the way so that the number dials rotate freely, they just don't do it on their own. I hope this is making sense to you. Thanks.
Old 12-21-2017, 10:28 AM   #431
ls1nova71
ls1nova71's Avatar
Yes, the numbers themselves are spring loaded. If they dont return to zero, then the spring in it must be bad.You will just have to replace the odometer number part.
Old 12-21-2017, 11:52 AM   #432
Steve Cole
Thanks Eric, I was afraid of that. I guess I will have to buy another cluster from the junkyard. Maybe I can find one with less mileage this time.
Old 01-04-2018, 06:55 AM   #433
ewoody625
ewoody625's Avatar
I have a few questions on wiring.
1. Do you have a part number for the hi beam indicator?
2. What connector did you use to wire it into the main harness?
3. I have no idea how to follow the printed circuit. So how do I wire this thing
4. Do I have to do the volt gauge swap or will the factory one work?
Eric
70 CST10 long bed in pieces also factory air and cruise(the project)
18 Silverado crew cab 5.3 4x4
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=402166
ewoody625 is offline   Reply With Quote
Old 01-04-2018, 10:44 PM   #434
ls1nova71
ls1nova71's Avatar
1 - I don't have a part number, but it was just a 12v LED that I picked up at Radio Shack.
2 - you can use what ever you want, but I like these. http://kwikwire.com/15-position-amp-connector-kit/
3 - To follow the printed circuit board, you just have to look at it. The gauges are bolted to the printed circuit, the 12v powers will all be hooked together, so by following it, you should see it. The grounds are usually grounded to the tin, and the sender wires are separate. Just follow the printed 'wire' from the gauge back to the original dash plug so you know what each wire does. I really cant explain it any more than that, but if you cant figure it out, you may need to find someone in your area that can either wire it for you, or at least help you out with it.
4 - You don't have to put a volt gauge in, but there really isn't any good way to get the original ammeter to work with the LS alternator, so that's why I change them. If you can live without that gauge then you don't need to do anything.
Old 01-04-2018, 11:08 PM   #435
ewoody625
ewoody625's Avatar
[QUOTE=ls1nova71;8152170]1 - I don't have a part number, but it was just a 12v LED that I picked up at Radio Shack.
4 - You don't have to put a volt gauge in, but there really isn't any good way to get the original ammeter to work with the LS alternator, so that's why I change them. If you can live without that gauge then you don't need to do anything.[/QUOTE
Ok Thanks for the info I'm gonna try to work on it tomorrow I'll let you know if I have any issues
Eric
Old 01-11-2018, 12:43 PM   #436
ewoody625
ewoody625's Avatar
Another question... what is the difference between the square body volt gauge and the 67-72? I started shopping for a gauge and they look the same to me, as far as the back of the gauge goes. Also, I thought I saw a link to a thread on doing that swap but can't find it now, am I making that up? Thought I would find the answer to my question there. Thanks
Eric
Old 01-11-2018, 10:45 PM   #437
ls1nova71
ls1nova71's Avatar
They are two different gauges, one is a voltmeter and one is an ammeter. They do look the same, but internally are different. If you want a simple bolt in that looks factory, this thread has what you are looking for. Post #274 http://67-72chevytrucks.com/vboard/s...653967&page=11
Old 01-12-2018, 03:32 PM   #438
ewoody625
ewoody625's Avatar
If i wanted to do this swap myself what is involved? I already purchased an 87 cluster with the impression I had to do it myself. Thanks
Eric
Old 01-23-2018, 12:50 PM   #439
Steve Cole
I forgot about the high beam indicator, but there's a pic on page 1 of this thread. It's a 12v LED I bought at Radio Shack. it has a small nut that threads on it so you can bolt it in a hole. I made a bracket that bolts to one of the screws that holds the speedo part in. I also ended up putting a piece of window tint under the face, between it and the clear plastic part, to keep it from appearing to glow when the dash lights are on. The dash lights will light up the clear and the indicator will be white. putting the window tint darkens it so you don't see it, but it's not so dark that the LED doesn't show through.
Hey Eric, two questions: since you mounted the high beam indicator to one of the speedo attachment bosses, does this mean you only used the other two bosses to attach the speedo to the plate? To clarify, there are only 3 attach points to secure the clear plastic speedo plate to the metal plate, so was the upper attach point omitted so the light bracket could be used there?
Also, I noticed you added two of the single wire lights between the 2 sets of small gauges, does this make a noticeable difference in gauge brightness?
Thanks!
Old 01-24-2018, 07:47 PM   #440
Steve Cole
Hey Eric, never mind the first question, I took a different approach by counter boring the plastic piece so the LED sits flush with the surface of the plastic piece, then ran the nut and lock washer down on the backside. I think it will work pretty good but if it ever fails, I'm screwed. Lol.
Old 01-24-2018, 11:48 PM   #441
ls1nova71
ls1nova71's Avatar
Sorry I missed your post yesterday, but it seems like you figured out a solution. What I did was made that bracket, then put the bolt through both it and the mounting plate to hold it on. As for the other lights, it does make them brighter, but that's the only cluster I did it on because it makes them brighter than the gas gauge and speedometer and that kind of bugged me.
Old 01-25-2018, 04:03 PM   #442
Steve Cole
Thanks for the reply Eric. Have you tried a lesser wattage bulb, or a tinted bulb to reduce the brightness to an acceptable level? It seemed like a good idea when I saw the pic. Thanks.
Old 01-26-2018, 12:36 PM   #443
ls1nova71
ls1nova71's Avatar
No, I never tried it again. I just paint the underside of the tin flat white rather than the green they are originally and it seems to brighten it up enough.
Old 01-30-2018, 03:20 PM   #444
Steve Cole
Hi Eric,
I have two questions for you-
does the LS motor run at a higher oil pressure than the old Gen1 350? if so, would an 80# oil pressure gauge be better to use (for keeping the needle mid-scale) instead of the 60# one ?
Also, what is this ?
Old 01-30-2018, 09:22 PM   #445
ls1nova71
ls1nova71's Avatar
I think oil pressure is more dependant on how good of shape the engin is in, but mine do seem to run a bit higher than the older engines. My gauge goes way over to the right on start up and stays to the right most of the time, so if you want the needle in the middle an 80# gauge would probably get you there.
The black box on that cluster is a relay I was using for another purpose, you wont need it.
Old 01-31-2018, 11:33 AM   #446
Steve Cole
Thanks for the reply Eric!
Old 02-11-2018, 07:04 PM   #447
Bucky10pt
Eric, do you have a kit available? I'm getting ready to build one
Bucky10pt is offline   Reply With Quote
Old 06-19-2018, 12:10 AM   #448
Caustik
Caustik's Avatar
Just about done, needs some final placement tweaks and a needle.
Old 06-25-2018, 10:27 PM   #449
ls1nova71
ls1nova71's Avatar
Looks good! I hear about people doing these, but almost no one posts any pics of their builds, thanks for posting some.
Old 06-25-2018, 10:43 PM   #450
lutronjim
What is the XF21
lutronjim is offline   Reply With Quote
