Old 07-23-2013, 06:59 PM   #426
SeTx67
SeTx67's Avatar
Re: 1968 Chevrolet SWB Stepside Restomod
Making some progress. Looks good
SeTx67 is offline   Reply With Quote
Old 07-23-2013, 07:34 PM   #427
gdavis
gdavis's Avatar
Originally Posted by Xeen View Post
Hey all;
Yesterday I drained the differential fluid and installed the new chrome cover.
Today I trimmed the brake hose bracket then I painted and installed it.
Enjoy.
I fixed my bracket like yours. I like it. thanks Brian
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 07-24-2013, 05:29 PM   #428
Xeen
Xeen's Avatar
Hey all;
The Camaro radiator and electric fan came in today.
I test fitted the assembly and it fit fine, it looks like I don't have to move my engine.
Even though the radiator is the right height for the stock mounting brackets to work they are in the wrong place so I will have to fabricate my own brackets.
Onward and forward.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 07-24-2013, 07:44 PM   #429
SeTx67
SeTx67's Avatar
Hey all;
Onward and forward.
Awesome! Did you get any pics? Like we discussed over the phone, this is the route I want to take. You're going to make my life so much easier when I start my swap
Old 07-24-2013, 07:53 PM   #430
gdavis
gdavis's Avatar
Good job there. I am glad that it works out for you.
Check out Patches
Old 07-24-2013, 07:58 PM   #431
69sinker
69sinker's Avatar
Hey Brian,
Just spent the last hour reading your build, looks great. Your gonna love that ls, 17 mpg, overdrive transmission, no cold starts and plently of power. My only problem is keeping the my foot out of it. I've already been selling all my old small block parts, I've got my truck tore back apart for new body and paint seems like its taking forever.
Did your do your own harness or purchase?
Keep up the great work. Dave
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build
http://67-72chevytrucks.com/vboard/s...d.php?t=589869
69sinker is offline   Reply With Quote
Old 07-24-2013, 08:28 PM   #432
Xeen
Xeen's Avatar
Hey Dave thanks for stopping by and for the kind words.
You should put a link to your build thread in your signature.
I purchased a Standalone Wiring Harness from
(PSI) Performance Systems Intergration.
Old 07-24-2013, 09:04 PM   #433
69sinker
69sinker's Avatar
I think I will put a link in, I tried to start a build thread on lsx swap side but no one put it up on the site.
Ive heard good things about the psi harnesses, I did my own using info from members here. It took a lot of time and cussing but I did learn a lot about the engine,transmission, sensors,etc.
I also used the fbody radiator and fans, they work and fit great.
Dave
Old 07-24-2013, 09:31 PM   #434
Xeen
Xeen's Avatar
Hey all;
I just purchased a heater delete hose so I can drive the truck while I'm saving up for the Vintage Air system, here's a link incase you are interested in purchasing one.
http://www.ebay.com/itm/160884055553...84.m1439.l2649
Old 07-25-2013, 05:22 PM   #435
gdavis
gdavis's Avatar
Hey, Brian I bought the stock column you sent me the link for. So it want be to long that I can see a big change with the old girl. A few more parts came in today. A new HEI distributor, a new 3'' chrome air cleaner, a new set of 350 emblins for the fenders and a power steering pump. It leaked in transit so I have to clean it up.
You should have said something about the hose. I would have gave you one. But now you can get the beast running.
Check out Patches
Old 07-25-2013, 08:02 PM   #436
Xeen
Xeen's Avatar
Hey all;
Today I went and purchased some 5/16 to 3/8 adapters for the radiator and some 3/8" compression fittings so I can rerout the transmission cooler lines.
Whenever it stops raining I can get the cooler lines installed.
Old 07-25-2013, 08:26 PM   #437
502ms
502ms's Avatar
Hey Brian,
I agree! I have the same problem with the right foot. Does not help that I switch gears and step on the gas and she pulls and pulls.
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 07-26-2013, 05:46 PM   #438
Xeen
Xeen's Avatar
Hey all;
Today I bent and installed the Transmission cooler lines, I might have made the lower line 1" too short so I may have to redo that one.
Old 07-26-2013, 07:38 PM   #439
gdavis
gdavis's Avatar
It looks good from here. I can't see the difference between the two.
Check out Patches
Old 07-26-2013, 08:01 PM   #440
SeTx67
SeTx67's Avatar
Good job on the transmission lines. More notes taken
Old 07-27-2013, 05:07 PM   #441
gdavis
gdavis's Avatar
Hey you need to spend some time on that rear end housing. It makes your work look undone. A wire wheel and some primer and paint. And a lot of elbo grease.
Check out Patches
Old 07-27-2013, 05:20 PM   #442
Xeen
Xeen's Avatar
Yep I need some cool weather where I can sit outside for a few hours without losing 10 pounds in sweat.
Luckily it's not greasy it just needs the old paint stripped off and repainted.
Old 07-28-2013, 02:44 PM   #443
gdavis
gdavis's Avatar
yea I can relate to the heat. in the 90's here. That is why I buy parts and don't get to install them.
Check out Patches
Old 07-30-2013, 07:21 PM   #444
Xeen
Xeen's Avatar
Hey all;
I have been wrestling with the idea of moving my engine back 2" towards the firewall for some time now.
Recently CPP released a new redesigned sheetmetal engine perch that is more like the original factory perches and give a lot more clearance for exhaust manifolds and headers.
After learning about the new perches I decided to go with them instead of the tubular perches and move my engine back at the same time that I change them out.
For all you guys who are curious here is a stock CPP photo of the new sheetmetal perches with Hooker GM clone manifolds.
Old 07-30-2013, 09:02 PM   #445
gdavis
gdavis's Avatar
I was about to say man that don't look like your truck. I thought you had headers and then I read what you posted. Good luck with the switch and the moving to the rear.
Check out Patches
Old 07-31-2013, 03:24 PM   #446
gdavis
gdavis's Avatar
I got your drive shaft all sand blasted and primed and painted. I sent you a PM this afternoon. About the front yoke.
Check out Patches
Old 07-31-2013, 05:59 PM   #447
Xeen
Xeen's Avatar
Here is your driveshaft.
It looks really nice George.
Old 07-31-2013, 08:54 PM   #448
502ms
502ms's Avatar
Looks good buddy!
Best Regards,
Leon M.
Old 08-02-2013, 08:09 PM   #449
gdavis
gdavis's Avatar
Did you get the motor slid back thoes 2 or 3 inches and the transmission lines also.
Check out Patches
Old 08-02-2013, 09:11 PM   #450
Xeen
Xeen's Avatar
I'm waiting for the new perches to be delivered.
1968, chevrolet, restomod, stepside, swb
