View Poll Results: which paint job looks best? | |||
1 |
0 | 0% |
2 |
0 | 0% |
3 |
1 | 5.88% |
4 |
0 | 0% |
5 |
0 | 0% |
6 |
0 | 0% |
7 |
6 | 35.29% |
8 |
2 | 11.76% |
9 |
4 | 23.53% |
10 |
1 | 5.88% |
11 |
1 | 5.88% |
12 |
4 | 23.53% |
Multiple Choice Poll. Voters: 17. You may not vote on this poll |
#426 |
motor exploder
Re: 71' (gonna be) a one of a kind custom
Things are coming together nicely - that engine looks awesome and your powdercoater is a BEAST!!!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
#427 |
Thanks guys, in the next two weeks or so I will be starting the ignition system. I did test fit the headers and they fit beautifully. That was a huge sigh of relief for me. So the headers will be going on permanently soon too. That means exhaust will be on the table soon too. It feels like I can almost see the finish line just over the horizon!
..........___ ..____//_{)] ______ [_(O)_[___][__(O)_] Project: Under Pressure II http://www.67-72chevytrucks.com/vboa...d.php?t=559720 |
#428 |
I just love my wheels!
I should be finally ordering a bunch of parts tomorrow. Mainly ignition parts (distributor and wires)
#429 |
Them wheels look cool!
Current Build 89 s10 ecsb 2wd 4.3/700r4 50k OG Miles Instagram- shaggin_s10 '86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD |
#430 |
Finally, parts!
I will have the secret weapon installed soon, stay tuned!
#431 |
Say hello to the secret weapon
#432 |
motor exploder
Is that one of those fancy carb spacers that adds 150hp?
#433 |
You know it!
![]() I had to give the solenoids and brackets a paint job. I put the smallest jets in it to start. Still a 100 shot though!
#434 |
I can hear the evil laughter now...
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#435 |
Haha, the evil laughter will be much easier to hear early next month! I don't know if I have already said what I am going to be doing carb wise yet, but it will be really nice!
....... ok, I can't take it! It is going to be the MSD Atomic EFI! And I have plans for it too ....... ok ok, it will be getting a custom powder coating job too. Geez I just can't keep a secret, ![]()
#436 |
Thinking about changing directions with the build....
#437 |
Oooo, uhhhh... Yeah um, nice...
![]() Edit: I will say, that was a lot of work to get the fenders and hood created and lined up, |
#438 | |
![]() Um, donno where you found that other truck picture but... It hurt my eyes. ![]()
#439 | |
#440 |
Ok guys, I need some help here. I recently found out when I looked up my 1:6 rocker arms, somehow I chose some for a small block ford. Now I have heard of ford guys using Chevy rockers but never heard of it vice versa. They seemed fine when I installed them but I am not 100% sure what problems it may cause. Any suggestions / ideas?
#441 | |
What comes to mind is make sure the rocker tips are centered on the valve stems, and the push rods don't contact the heads. Could the push rods from chevy and ford have a different radius on the ends? in other words if the end of the push rod was larger or smaller than the cup on the rocker it could wear badly.
#442 | |
#443 |
Thumbs up for Summit! Hey you caught it before break in, its all good!
#444 |
![]() Join Date: Jul 2012
Nice Work!!!
Ryan... 1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain http://67-72chevytrucks.com/vboard/s...11#post5532411 |
#445 | |
Thanks! The Atomic EFI should be here Monday and the replacement rockers on Tuesday. Now I am facing a decision; If I have th TB powder coated, only the side plate and the fuel rails can be coated, the body itself will have to be painted. Now the design will be like the rest of the engine, black with the MSD and raised lines in blue. The only blue on it will be on the side plate and fuel rails though. My concern is if I pant the body and coat the other parts, is the black from the body to the other parts being off color from each other. The other problem, my powder coater I have does such a fantastic job but isn't the fastest. I really want to have this engine cranked within the next month or so and I can't do that if the powder coater has my fuel rails. I figure if I am going to have him do it, I will have to give him a time limit to have it done. Then hope he sticks to it, lol
#446 |
Well, bad news. There will be no powder coating on the throttle body. Turns out the plate on the side has the ECM attached to it. Spray painting it would be next to impossible with all the sensors and wiring in the way. Hand painting it would be the only option and I do not think that would look very good. So for now it will just have to stay the way it is. I did get my new rockers today and started to install them. Getting back on track now. Next up is the dampener and a few miscellaneous parts.
#447 |
So close to being able to start this puppy. I can almost hear it!
#448 |
Well, guess they didn't offer the unit in black then.
Ya know what once you start the engine you'll forget about the color.
#449 |
Mind taking a couple close pics of your upper shock mounts in front? And I was surprised that you didn't have to notch the frame for the steering rack, thought it needed a little. Nice, that's a good thing.
'68 C10 SWB '85 K30 Blazer |
#450 | |
I will take some pictures of them in the morning for ya. They are nice, I like them a lot. I still am not sure they were worth that much money though, lol. I probably wold not have installed that kit if I had to notch the frame any more than I did. All in all I am really happy with that rack kit though. No Limit was definitely the way to go.
..........___ ..____//_{)] ______ [_(O)_[___][__(O)_] Project: Under Pressure II http://www.67-72chevytrucks.com/vboa...d.php?t=559720 Last edited by 71' Custom; 02-14-2016 at 01:38 AM. |
