Old 01-31-2015, 01:15 AM   #426
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by greg64 View Post
... But I really like the work you're doing. ... Keep the progress coming.
Greg
Why thank you Greg I appreciate the kind words and all the advice
Gregski is offline   Reply With Quote
Old 01-31-2015, 01:16 AM   #427
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by rusty76 View Post
Keep on pluggin. You are doing a dang good job.
Thank you Rusty!
Old 01-31-2015, 01:17 AM   #428
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by portrodder View Post
Great work and enjoying your build, keep it coming.
Thank you Mr. Retired, lol
Old 01-31-2015, 01:29 AM   #429
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
got going on Rusty again today, wanted to button him up
first put in the second push in breather in the driver side valve cover
AutoZone only stocks one of these breathers and one of the rubber base grommets so I had to hit a couple stores to get em
Old 01-31-2015, 01:41 AM   #430
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
next it was time to replace the stock thermostat housing ie water outlet, I really don't care for chrome bits, I just wanted something without that ugly therma switch double nipple appendage
I believe the kind I got comes with a built in rubber O ring so I didn't even need the typical gasket, maybe somebody can confirm that for me
it even came with auto/car style bolts, so I didn't have to go to the hardware store, I was glad since the new housing is way taller on one side for some odd reason so it requires a longer bolt
I even used anit sieze and torqued the bolts to 25 ft lbs, the manual said 30 but this new part is not at hard as the stock one it feels a bit flimzy so I took it easy
Old 01-31-2015, 01:50 AM   #431
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
man the new water outlet looked great - - - TOO BAD IT WAS WRONG!!!
I forgot that the alternator bracket mounts to one of the water outlet bolts, silly rabbit
so out came the wire wheel and I had to clean the old special bolt for reuse
then loosen both bolts and start torquing all over again ~ fun
honestly I knew there was something special about this water outlet bolts but I thought I would have to buy the longer bolt, when I realized it came with the housing I got so excited I forgot about his neighbor with special skills on the other side
Old 01-31-2015, 01:57 AM   #432
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
By the way, you could run your brake booster off the tapped hole in the manifold that you plugged, instead of the carb, if that gives you a cleaner setup.
Greg
Good call Greg (and others who have suggested I do that), thank you
Old 01-31-2015, 02:06 AM   #433
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
next I cleaned and reinstalled the original hard fuel line, I didn't think it would be wise to run a 4 foot all rubber fuel line to the fuel pump from the carburetor
I still need to resolve the threaded end on the hard line situation to mate it to the 3/8ths nipple on the new carb
Old 01-31-2015, 02:11 AM   #434
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
cleaned up a bit the space where the alternator lived
sharing a before and after pic
Old 01-31-2015, 02:15 AM   #435
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
no sense in dropping a dirty alternator into that clean new space so I gave it a bit of a gentle back scrub with the ol' wire wheel
Old 01-31-2015, 02:19 AM   #436
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
also didn't paint the alternator bracket because eventually I will relocate the alternator lower using one of them mid mount set ups, and I don't like painting in the winter time
I degreased the bracket and yes it looks like crap
Old 01-31-2015, 02:22 AM   #437
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
the third throttle linkage bracket had not shown up yet so I mounted up the second one I got for now (just to pull the truck out of the garage and into the driveway, the lady of the house wants her space back)
Old 01-31-2015, 02:23 AM   #438
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
at this point I found myself saying, my god man when did you take off all these parts, and how many more are there to put back on...
...ever had one of 'em revelations ...
Old 01-31-2015, 02:29 AM   #439
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
decided this was as good of a time as any to pull that pink resistor ignition wire and replace it with a regular one, since I had to wire up the electric choke and all
I ended up using a brown wire I yanked out during the SMOG system deletion phase, this is a temporary solution till I find the right wire at the junkyard
today's mission was get that ol' truck running at any cost
Old 01-31-2015, 02:32 AM   #440
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
at this point I was feeling anxious, just wanted to hear this thing run, and my work was getting sloppy
for example I didn't bother wire wheeling the old distributor hold down bracket notice the specs of orange paint left on it (now that's not like me, did I run out of beer or something?)
Old 01-31-2015, 02:37 AM   #441
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I also mickey moused the rubber fuel line to the hard line, man I had to hear this thing run ~ tonight, tomorrow I would go to NAPA and find a female 3/8ths NPT with a 1/8th barb thingie, and maybe even pop in an inline fuel filter, scouts honor
Old 01-31-2015, 02:39 AM   #442
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
battery connected, everything buttoned up, fluids going in
Old 01-31-2015, 02:41 AM   #443
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
... and then DISASTER struck !!!
Old 01-31-2015, 02:55 AM   #444
68post
Re: Restoring Rusty
UH-OH ! That's a big leak !
Tim K.
84 K30 srw Silverado 454 auto
85 C20 350 C6P auto flatbed
94 K1500 lifted shortbed 350 4 bbl NV4500
68post is offline   Reply With Quote
Old 01-31-2015, 11:45 AM   #445
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Yup, I don't recon this is what they mean when somebody says:
"You've flooded the engine!" LOL
Old 01-31-2015, 11:53 AM   #446
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
guys first of all the new intake manifold only flooded on one side, the passenger side, weird, I have never seen that happen before and this is the fourth manifold I have replaced in my illustrious shade tree mechanic career, JK, and the first I had a problem with
Please Note: That all the other manifolds were always stock OEM ones that I removed, cleaned, and replaced gaskets, then installed them back in. This is the first time dealing with an after market one. But trust me the only thing I am blaming here is myself, not the parts. I took a straight edge to the manifold and it seems fine, no gaps or warps.
I got to tell you that after the swift kick to the groin pain subsided I did not even let one expletive fly, instead I went Def Con Three and had that new manifold off the engine in 7 minutes Pit Crew Style
Old 01-31-2015, 12:08 PM   #447
Jake Wade
Jake Wade's Avatar
Re: Restoring Rusty
Greg, Get some Felpro gaskets part # 1256, they work a lot better for aluminum intakes.
The gaskets you used should not have leaked like that though, I have used them in that application.
Jake Wade is offline   Reply With Quote
Old 01-31-2015, 12:09 PM   #448
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
It is Saturday morning and I just tried to call Holley Technical Support ASK OUR EXPERTS: 1-866-464-6553
Voice message says Our Office is Now Closed our hours are M - F 8 to 5:30 and Saturday 8 - 2 Central Time
So why are they closed? It's only 8 am Pacific Time
Old 01-31-2015, 12:32 PM   #449
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Thanks Jake, dang it that's exactly what the Weiand instructions recommend, and that's exactly what I asked for at AutoZone, and they gave me a FelPro gasket which I thought was it, the number on it is MS90314-3 but I thought that was Autozone's part number (cause its in a different format and all) for the same thing.
Kooglie Mooglie, guys you just have to watch out for yourselves cause no one cares more about your truck than you do!
I will try to post a pic of the correct / proper 1256 gasket below, because sharing is caring, lol
Old 01-31-2015, 12:35 PM   #450
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
this is the bad gasket that I got
