Old 01-08-2019, 03:16 PM   #426
6t9camaro
6t9camaro's Avatar
Re: 67 C10 "Green Gobblin" straight from the field!
Originally Posted by UniqueOdyssey68 View Post
Nice! I used same parts on mine. What's your thoughts on the saying "Richmond gears are noisy, they often omit a ticking sound" ?
I went with them anyway since I already bought them and they are durable.
I’ve never had any issues with Richmond’s. Any car I’ve ever put a set of gears into usually had a pretty loud exhaust! Lol
Build
67 Green Gobblin
http://67-72chevytrucks.com/vboard/s...d.php?t=688755
6t9camaro is offline   Reply With Quote
Old 01-09-2019, 09:40 PM   #427
6t9camaro
6t9camaro's Avatar
Getting close, Motor and transmission almost ready to go in !!!
Build
67 Green Gobblin
Old 01-15-2019, 08:44 PM   #428
6t9camaro
6t9camaro's Avatar
Finally got the motor and trans together and in place!
Build
67 Green Gobblin
Old 01-15-2019, 08:52 PM   #429
6t9camaro
6t9camaro's Avatar
Lots of clearance around everything but thats making me want to drop and move the motor back but we will see how it looks once its together.
Build
67 Green Gobblin
Old 01-15-2019, 10:46 PM   #430
nlped
nlped's Avatar
Get your headers/manifolds fitted because that’s what has me STUCK on my motor position finalizing. My BBC is just low enough that I can’t find $hit that’ll fit and I’m stuck waiting on Nate or fabbing them myself (which I guess will be the case & that’s really frustrating that PB doesn’t seem to give a d@mn).
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 01-15-2019, 11:05 PM   #431
NewType72
NewType72's Avatar
Looking absolutely gorgeous. All trucks should be bit with this quality and care in mind
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 01-16-2019, 10:14 AM   #432
6t9camaro
6t9camaro's Avatar
Ya I’ve already built and fit a set of headers to this engine height. The factory bbc truck manifolds also fit with lots of room but I’ve been trying to track down a set of 1970 ls6 exhaust manifolds. Once I get my hands on a some I would like to set engine height to those if I decide to scrap the header idea? I feel your pain with PB leaving you hanging!
Build
67 Green Gobblin
Old 01-16-2019, 10:15 AM   #433
6t9camaro
6t9camaro's Avatar
Thanks man! It’s getting there!
Build
67 Green Gobblin
Old 01-22-2019, 09:02 PM   #434
6t9camaro
6t9camaro's Avatar
So the engine sitting high has been bothering me and I want to get it a little lower! I decided to refit my headers and a factory set of exhaust manifolds. I don't have much clearance with the headers left ( I already knew that from when i modified them to fit ) but once I put the manifolds in there I realized I've got tons of room and can easily go down about 1.5"+ Since I've been leaning towards factory manifolds lately I'm going to hunt down a set of 70s High-Perf Chevelle or Camaro manifolds. (they will probably out perform my headers anyway) without all the leaks and high engine bay temps!
Build
67 Green Gobblin
Old 01-22-2019, 09:06 PM   #435
6t9camaro
6t9camaro's Avatar
After playing around with exhaust for half the day i decided to get some powder coated pieces out and accessories installed!
Build
67 Green Gobblin
Old 01-22-2019, 09:09 PM   #436
6t9camaro
6t9camaro's Avatar
Finally starting to look like a motor! (Yes i forgot to powder coat the air cleaner)
Build
67 Green Gobblin
Old 01-22-2019, 10:59 PM   #437
nlped
nlped's Avatar
Nice!!!
Carter
Old 01-22-2019, 11:06 PM   #438
nlped
nlped's Avatar
You’re motor looks like it sits about 1.5”+ higher than mine. My serpentine crank pulley (about 6’ish inches in diameter) is same height as the crossmember in front of it.
Carter
Old 01-22-2019, 11:11 PM   #439
6t9camaro
6t9camaro's Avatar
Oh ya I’m definitely going to drop the motor after seeing that. That’s a good reference pic! Thanks!
Build
67 Green Gobblin
Old 01-22-2019, 11:15 PM   #440
nlped
nlped's Avatar
You bet!!! I’ve gotta come up about an inch from looking at yours. For reference, my 700r4 fits with a low hump with about 1/2” of clearance.
Carter
Old 01-23-2019, 03:50 PM   #441
68Gold/white
I was going to comment the other day, and got interrupted....the factory big block frames are not as wide at the top, where your headers are potentially having clearance issues. i did not know this, was reading a thread here about some of the different things on these pickups...
Carry On, great to see a factory looking big block in one of these. I plan to do the same on my 68, when that day comes...I have the original grungy somewhat rusted original valve covers, that I am thinking about installing. Yous look much better!!! I also have 2 sets in much better shape...
68Gold/white is offline   Reply With Quote
Old 01-23-2019, 05:25 PM   #442
knomadd
knomadd's Avatar
That big block sure looks good on that frame though. Keep it up!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
Last edited by knomadd; 01-23-2019 at 09:51 PM. Reason: Realized I read the post I was replying too differently than OP intended
knomadd is offline   Reply With Quote
Old 01-25-2019, 10:25 AM   #443
6t9camaro
6t9camaro's Avatar
Hmmm interesting! I’ve never heard that before. The frame rails in this truck are from a C20 and when I compared them to the factory 67 rails there were no differences other than the steering box location. But I’ve never had a factory big block frame so can’t really say.
Build
67 Green Gobblin
Old 01-25-2019, 10:26 AM   #444
6t9camaro
6t9camaro's Avatar
Thanks!
Build
67 Green Gobblin
Old 01-27-2019, 08:33 PM   #445
6t9camaro
6t9camaro's Avatar
Weekend update! Picked up some goodies friday and you can see my boy was excited! Got the Boyd tank fitted and installed this weekend with no problems. Also picked up my High-Perf Car manifolds!
Build
67 Green Gobblin
Old 01-27-2019, 08:39 PM   #446
6t9camaro
6t9camaro's Avatar
Heres a few pics of the manifolds! Im pretty excited about these as they were hard to find and showed up better than expected! After fit up Im going to sent them off to get surfaced and coated.
Build
67 Green Gobblin
Old 01-28-2019, 04:04 PM   #447
jkeating1
jkeating1's Avatar
I'm down with the LS6 replication! Good job nailing details (like the single Tonawanda decal). How about some Cowl induction?
jkeating1 is offline   Reply With Quote
Old 01-28-2019, 05:21 PM   #448
6t9camaro
6t9camaro's Avatar
Oh ya that’s a good looking big block! I’ve been keeping my eye out for the cowl induction air cleaner setup but haven’t found one yet!
Build
67 Green Gobblin
Old 01-30-2019, 11:37 AM   #449
68Gold/white
Although I have not seen my stock 396 manifolds in a while (they are in the garage...somewhere...) those look VERY close to what came on my stock 396 in my 68!!! Yours look even better, mine have the air injection holes in them...
Old 01-30-2019, 03:35 PM   #450
6t9camaro
6t9camaro's Avatar
The passengers side are almost all the same on the 60-70s big blocks but it’s the drivers side that’s the different hard to find one. The truck ones dump at a different angle and don’t hug the block as tight as the car manifold. In my case I need that to clear the choppin block front crossmember and the steering shaft to the rack.
Build
67 Green Gobblin
