Old 11-11-2019, 06:26 PM   #426
cornerstone
cornerstone's Avatar
Re: TA_C10: Stage 1
Is there any reason besides weight transfer and aesthetics to mount your battery down on the frame rail? Which drop out tray did you get if you don’t mind sharing. I’m debating wether or not to do this also.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 11-13-2019, 10:12 PM   #427
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Well I guess I am relocating the battery for a couple reasons. 1. Since I'm doing a frame off it would be a good time to do so. 2. Weight transfer to back passenger side is good. 3. Cleaning up the engine bay.
I like the idea of it relocated too, I can re-route the battery cables the way I want. I plan to route them pretty close to this idea:
And the battery box came from Amazon store. It's a drop box. It's SS and seems well built. Here is the link and some pics:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 11-13-2019, 10:16 PM   #428
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - Driveshaft and Wiring Harness
Driveshaft is now shortened and all new u-joints installed. I had a local driveline shop do it from a LS shop recommendation. Cost me $220 for all.
And I sent back my wire harness to brothers and they swapped it out for me to the classic version. There is quite a bit more in this box. Very nice and I am anxious to get started installing.
"It's only money".
Old 11-14-2019, 10:12 AM   #429
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
I'm glad to see that you exchanged your harness for the classic update, you'll be glad you did. Installing mine has been pretty easy.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 11-15-2019, 11:09 AM   #430
cornerstone
Re: TA_C10: Stage 1
That really does look like a well built box plus it's a nice bonus to be cheaper than most. Thanks for the awesome detailed pics. I'm still on the fence about it for my situation. This will be the first truck I've ever had air ride on and I'm thinking, worst case scenario here, would be able to have access to the battery if catastrophic failure were to occur and the truck is flat on the bump stops?
In regard to the rewire, both you and Potter are making me want to keep up with the Jones'. My Uncle bought this truck new and was an electrician by trade so the original harness looks very good, but its still almost half a century old. Then there is always the argument "might as well since I'm this deep in it". I think the best price I've found on the AAW kit is $539., unless you know better?
Brian
Old 11-15-2019, 11:19 AM   #431
SCOTI
SCOTI's Avatar
Re: TA_C10: Stage 1
You want a remote mounted jumper junction block. You find a spot that's easy enough to access for connecting to & put terminals there. Some do small covered boxes w/the POS/NEG terminals tucked in side while others might just tuck them out of sight somewhere while still being partially exposed.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-15-2019, 11:38 AM   #432
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
$539 is the best price I could find, it seems to be price controlled. I bought mine from Summit because they're so fast.
Old 11-15-2019, 02:01 PM   #433
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Yeah me too, thanks for helping me out with that, I thought I had what I needed before but having the bulkhead is gonna make my life so much easier rather than re-doing my firewall with body work and etc. And yeah cornerstone, it's same price for me too at brotherstrucks.
Ditto. What SCOTI says. I was planning to install mine on the core support where the original battery tray would be. And I was planning on using something like the following:
"It's only money".
Old 11-17-2019, 12:11 AM   #434
siggyfreud
siggyfreud's Avatar
Re: TA_C10: Stage 1
I used that on my last build. Seemed like a quality piece too. It was on up the firewall near the passenger side so I could run straight down to the starter. Core support is a good idea to and easier if you need a jump.
siggyfreud is offline   Reply With Quote
Old 11-17-2019, 11:31 PM   #435
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - Vintage Air - Front Drive Accessories
Well I spent most the weekend on drugs trying not to get sick, lot's of vitamin c, shots of flonase and 24 hour zyrtec everyday for last 5 days and it worked. I never got real sick just mainly felt like i was gonna be and hardly any energy. So I just cleaned the garage out last couple days and organized all my stuff better. That is a big task let me tell ya, sucked.
So tonight after finishing rest of that, I decided to install my 2010 camaro mid-mount A/C bracket for Sanden 709 compressor from vintage air. Wasn't too hard. Follow instructions and study the diagrams is all there is to it. It's cool how they figured out you buy a certain tensioner pully and swap its pulley for another pulley they provide(VA) and boom, it all works together just right. I mounted the compressor 90 degree left, didn't think I was going to want my a/c lines on the top but maybe I do, we will see how it looks another time, might switch that.
Also installed the LS alt/ps bracket. Cleaned up the alternator and PS pump that came with my engine and installed them too. Starting to look like a complete engine again
Pics for your viewing pleasure:
"It's only money".
Old 11-17-2019, 11:41 PM   #436
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
I also got my new parking brake cable retainer from GMCPauls! It's the little things like this bracket that I lost that really make a big difference. I think I threw my original one away still clamped to the old cable....
I started by prying the clamp open to get it over the cable.
Then I took a pair of channel locks and slowly pinched it back down over the cable. Installed the bolt and pin.
Then I got back under truck and adjusted the double nuts on the parking brake cables and all done. Works like OE
"It's only money".
Old 11-17-2019, 11:46 PM   #437
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Quick update on my power steering too. So after installing I noticed the PS pump return line looked pretty twisted and bent. Figured I was gonna have to get a new one. Then I figure out if I bent it down just a little more the return line could route right through an existing frame hole! Before it was like 1/2 inch from the frame. Now I can get a hose on it no prob.
This is before I bent it down a bit.
"It's only money".
Old 11-17-2019, 11:47 PM   #438
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
And for the 4th post tonight...... I have started wiring
"It's only money".
Old 11-18-2019, 10:32 AM   #439
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
I'm right there with you! Wiring, plumbing, brake cables, etc.
Let us know how the Kwik brackets work out once you have it running - you're probably aware that some of us have had trouble with them squealing.
Old 11-18-2019, 10:57 AM   #440
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: TA_C10: Stage 1
Tons of time to do all that. Lookin good. You will be driving her before long.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 11-18-2019, 02:48 PM   #441
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
No I didn't know about the squeal.... If you look at my pics you can see the tensioner pulley isn't centered and the belt looks like it will be rubbing on the edge/lip of pulley. Great, I may be re-engineering their engineering....
"It's only money".
Old 11-18-2019, 02:50 PM   #442
cebra
Re: TA_C10: Stage 1
Looking good, I hope you have better luck with your VA AC bracket than I did (it looks quite similar). I have been battling squeals (4 belts, 2 tensioners, 3 alternators, 2 hours paid shop labor as I threw in the towel) for about 4 months now with mine without success. I just got a replacement bracket so I get to do it again for the ~15-20 time this weekend. Just a tad frustrating.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 11-18-2019, 07:30 PM   #443
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
Whoops, didn't mean to be the bearer of bad news. cebra has had the worst luck of anyone I know with it. If you end up having trouble, look at his threads on it in the lsx swap section. My dad's had a squeal and through some shimming and just over time it's slowly gone away. My suggestion is to hold Kwik and Vintage Air to a standard of providing a product that works well and insist that they help you to reach an acceptable finished product (if you have issues). I'm considering using a low mount setup on mine if I have the clearance.
Old 11-20-2019, 12:34 PM   #444
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
What do you think?
Here is what I have going fellas. Redesigning the power/ground system from scratch. I went ahead and am going to use a Ford Solenoid for extra protection from the starter. Using 1/0 awg all the way to the jump terminals. This makes a nice backbone so I don't have to worry about voltage drop or distance from battery. However now I realize I have the 150amp Circuit Breaker inline with the starter power feed.... How would you route this?
"It's only money".
Old 11-20-2019, 01:41 PM   #445
SCOTI
SCOTI's Avatar
Re: TA_C10: Stage 1
Where do you plan to physically mount the remote solenoid?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-20-2019, 01:49 PM   #446
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Ok, I looked closer at the way the circuit breaker works, so I added on the battery side(not protected) a direct link to the starter solenoid. Then I ran the protected side(another cable) up to the rest of system. I was trying to avoid that second 1/0 cable... This should work I guess.
"It's only money".
Old 11-20-2019, 01:51 PM   #447
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
I was going to mount it on the frame up close to the starter. Should I mount it closer to the battery instead?
"It's only money".
Old 11-20-2019, 09:50 PM   #448
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Putting this here for my reference:
4awg is good for 135amps
2awg is good for 181amps
1/0awg is good for 245amps
Power rating on my stock style alternator is 160amps
Power rating for my stock style starter is 1.35kW
Ohms law = 1000xpower(kw)/volts(12)=amps
1.35kW = 112 amps
starter could see 250amps under load
Thanks cuz.
"It's only money".
Old 11-21-2019, 01:54 AM   #449
siggyfreud
siggyfreud's Avatar
Re: TA_C10: Stage 1
Where did you decide to put the solenoid? Given that you're doing a remote mount battery on the passenger frame, low, I'd probably put the solenoid close to it, assuming it would be more accessible there than on the frame or firewall close to the starter.
Old 11-21-2019, 01:52 PM   #450
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Yeah man I moved it closer to the battery. I changed my diagram again, see below.
Changes made:
1. 4awg to 2awg for alt and PDU circuits
2. Slid the starter solenoid back towards battery
3. I might remove the fuseable links since I have a 150a CB in line at the battery. Those fuseable links came with the AA classic wire harness so I figured they would be beneficial since my routing/path from alt to battery is so long but I'm second guessing this.
So everything you see is basically going to be mounted/routed in the frame rail. The battery is on passenger side frame rail, right next to it mounted on frame rail will be the starter solenoid and 150a circuit breaker. I wanted to mention also that I'm not using the frame rails as much to ground a lot of circuits because the Alternator and LS ECM both require clean path's. So with that said, the battery relocated to passenger side behind cab, my PDU mount and ECM will all be together on driver side core support, I'm already running power and ground there anyways so I said screw it, going big all the way to the front
"It's only money".
