#4476 |
![]() ![]() Join Date: Mar 2016
Re: What did you do to your truck today.The 3rd chapter
You are replacing those brake hoses I hope.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() |
#4477 |
Yah, I have new hoses. Just waiting til I get the brakes on before I replace them. I got the driver side line to break free from brake hose. The passenger side would not break free. I had to cut the brake line, install a new fitting, and double flare the brake line.
#4478 |
![]() Join Date: Jun 2022
I had not anticipated just how badly I su<k at fabrication, still working on the glovebox :eyeroll:
1970 C10 Custom longbed 350/350 |
#4479 | |
#4480 |
Almost done the exhaust...need another support hanger on each side.
But I couldn’t wait to hear it with the 4” side pipes. https://youtu.be/vtFRFWl6ngs?si=RvuSBsvg6Q9I7DJR I also installed the pressure sender for the new oil pressure gauge, as the stock one still reads about 40psi when the truck wasn’t running. Need to pull the cluster out, and work on that, but I gotta clean up the shop first...metal work is so messy.
"If it ain't broken, fix it 'till it is!" |
#4481 |
Trying to free up space in my shop so I can move the truck in. So I painted a set of ralleys and mounted some used TA radials to make it a roller. Then adapted a squarebody seat into it. Baby steps.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
#4482 |
Junior Member
![]() Join Date: Jun 2023
installed a 1 1/2" shorter steering column and lowered the seat 2" with aftermarket brackets. Much more comfortable to me.
1970 Chevy C10 Stepside, 350 with 700r4 1990 GMC Jimmy |
#4483 |
Tonight I replaced the bearings and races. Got the bearings packed and the brake rotors installed. Installed the calipers and pads and new brake hoses.
I still need to bleed the brakes, grease ball joints and tie rods and install cotter pins. But I had to put the tires on and see if it sat different with new springs. I put 1 lower springs and removed a 1 spring spacer up front. There was 8 between tire and fender and now there is 6, math never fails. Lol. I plan to replace the 27 tires with 31 tires, so that will get it down to a 4 gap. |
#4484 |
Finished the exhaust on the truck.
I'm not a welder, but it shouldn't fall off anyways...
#4485 |
![]() Join Date: Jun 2002
novax522, nice work, but your upper a-arms are on the wrong sides. It's a common mistake.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
#4486 |
#4487 |
Been there and sometimes still do it! Good luck, Rg
#4488 |
I got the upper A arms on the correct sides tonight. Thanks again RG! Glad you caught that. Im going to try to use this as a good excuse to buy another c10. That way if I have one tore apart, I can use the other one as a reference. Lol. Probably wont work, but worth a try.
#4489 |
Great job, that looks much better. The alignment shop would have found it, but it would have cost you!
#4490 |
![]() Join Date: May 2007
"what did you do?.... sadly, nothing on the trucks in quite some time. Maybe once all of this certainteed siding and Rockwool insulation is installed on the house, then it will be back to trucks.
How many do you spot?
LUCKTRUCK ![]() |
#4491 |
#4492 |
![]() Join Date: Feb 2002
Is that a reddish Stepside buried forward of the 2-tone Orange/White cab on the left?
#4493 |
Got all the tie rods, ball joints, idler, and pitman nuts snugged and cotter pins installed. Got everything greased. It doesn’t sound like a lot, but it took a while.
#4494 |
finally found a great 1157 LED bulb that is bright, fits and performs...and reasonably inexpensive. Amazon has them in stock at their fulfillment centers so shipping is fast.
My comparison pic doesn't represent the performance perfectly, as photographing a bright light source is very challenging and it blows out the image. Backstory: I didn't want to swap out the OE lens with one of those printed circuit board type lenses to get some brightness to the back. So over the past year, I have gone thru and tested numerous 1157 LEDs with little success. Many bulbs will not even mount in the socket as they bottom out before you can twist it to get it secured. Others were nearly hyperbright and had not brightness differentiation when you hit the brake pedal. The last ones I had, where the Sylvania 1157s that anyone can purcahse at any autopart store. These worked, but were dim in the standard "on" position, in fact dimmer than incandescent. In short, if you want to be seen from behind when you hit that brake pedal, and still have better than OEM brightness when just cruising, these are the ones! We'll see how long they last!
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
#4495 |
The Niner
![]() Join Date: Nov 2010
Took the Bomber for one last spin today before the snow hits and the salt gets laid down.
It's almost unheard of in Connecticut for it to be this late in the season with no snow yet, so luckily I was able to enjoy driving it for this long till spring.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
#4496 |
![]() Join Date: Jan 2007
Great looking pickup
I live in California, but identify as a Texan ![]() "If a job's worth doing, it's worth doing well" Survivor "Lil Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#4497 |
Started on the rear brakes today. Got one side done, also need to make new rear brake lines.
#4498 |
Got the driver side brakes done and both sides adjusted. Took before and after pictures.
#4499 |
Started on the rear brake line. There was nothing wrong with the existing brake line, other than it looked like crap. I had some leftover brake line material from when I redid the brakes on my elCamino. It is a copper/tin alloy. No rusting and super easy to bend. Got one side done tonight.
#4500 |
Who Changed This?
![]() Join Date: Jan 2013
^ I like that NiCopp line. I'm considering replacing the 54 year old line on my truck with it, just for general principles.
