11-01-2016, 02:52 PM | #4576 | |
Re: What did you do to your truck today? Chapter II
1970 C10 Short Stepper with 71/72 front clip. |
11-01-2016, 10:42 PM | #4577 |
On Sunday I built a relay harness for my headlights that plugs into the original harness to activate the relays.
It hooks up to the power junction block and the harness has relay plugs that are mountable (haven't mounted them yet). So as for today I got to try it out since this was the first day I have driven my truck in the dark. Man what a difference. |
11-01-2016, 11:56 PM | #4578 |
Tonight I stitched up the rear passenger bedside in the slightly modified fashion of board member "65standard". I decided to bring my light openings along instead of asking him to borrow his presses that he so kindly offered to loan out to members. I really don't like the paint color on my truck so I'm not too concerned about saving it.
I really appreciate 65standards thread, he gave me the inspiration to give it a shot since I can't really afford new short bedsides at the moment👍🏼 |
11-02-2016, 02:32 PM | #4579 |
Gaylord (r) bed cover. Getting painted next week
72 White Cheyenne, The Ghost |
11-02-2016, 07:58 PM | #4580 |
Since it was such a nice November day, I took ol goldy locks to town to pick up my new toy that just showed up. I'm officially ready for winter now! Almost 50 years separate their build dates, and the sled's MSRP is more than quadruple of the C10.
69 C10 fleetside long bed - 6.0/4l80E in progress |
11-02-2016, 10:34 PM | #4581 |
My 69 orig came with reflectors , I wired up the side marker lamps.
11-05-2016, 11:52 PM | #4582 |
Cleaned remaining parts from the column tear down and removed the brakes down to the booster bracket.
The rear brake line to the back of the combination proportioning valve was on real tight. Discovered you need to support the valve and its bracket with a big crescent wrench, when tightening/loosening that brake line. Bent the bracket, but I was able to bend it back. Lesson learned.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
11-06-2016, 02:21 AM | #4583 |
Installed cigarette lighter in place of the "lighter delete plug"; installed rubber bumpers for glove box door so it opens when you push the button, and replaced the original all black lights and wiper knobs with ones with the stainless trim, so that they match the radio and the new lighter.
Tomorrow, if all goes well, I'm going to install the little metal plate that covers the small hole in the firewall on the right of the steering column. Mine came with tape covering the hole, and it looks like factory, as there are no holes for the plate attachment sheet metal screws, indicating that there never was a plate there. Since the tape was falling off, this will seal the cab interior from the engine bay noise. Don't worry though, cause if I ever want to, I can return it to the way it rolled out of the factory.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
11-06-2016, 02:22 AM | #4584 |
Tomorrow, if all goes well, I'm going to install the little metal plate that covers the small oval hole in the firewall on the right of the steering column. Mine came with tape covering the hole, and it looks like factory, as there are no holes for the plate attachment sheet metal screws, indicating that there never was a plate there. Since the tape was falling off, this will seal the cab interior from the engine bay noise. Don't worry though, cause if I ever want to, I can return it to the way it rolled out of the factory.
11-06-2016, 07:23 PM | #4585 |
Put some Packard 56 series 3 contact connectors on new LED side markers for the 72 C20. Just need to wire the rear markers to act as turn indicators now.
'72 C20 Custom Camper - SB350/TH350, Daily Driver |
11-06-2016, 10:13 PM | #4586 |
Took the engine back out of the frame after getting the break in runs done so I can take it to the dyno shop and see how my engine build went.
11-06-2016, 10:22 PM | #4587 |
11-06-2016, 11:22 PM | #4588 |
"LeRoy" got his grill on........
11-07-2016, 01:47 AM | #4589 |
Where did you get that beautiful grille please ? .
I bought a " GM HERITAGE " grille that was worse than my old slightly dented original one ~ no way could it be made to fit . I'd love a nice one just like yours .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
11-07-2016, 11:24 AM | #4590 |
I got it local here in Houston at Outback Truck Parts. Paul and Tracy are great folks to deal with.
For something like this I prefer to purchase local so I can "put my hands on it" and make sure it is a quality part. Bought the inner grill as well. We had one of our larger swap meets this weekend and some of the replacement grills I saw were pretty bad...over spray on the paint and some with small dents and scratches. Hope you find a good one. |
11-07-2016, 11:48 AM | #4591 | |
I stopped in at outback Friday after I left the Conroe swapmeet.. yea I noticed also some of the replacent grills at the swapmeet weren't something I'd wanna receive in a box.. |
11-07-2016, 11:55 AM | #4592 |
I just tried ther web site, it's all screwed up .
http://www.outbacktruckparts.com/default.aspx They're in Spring, Texas now having just moved I guess .
11-07-2016, 12:19 PM | #4593 |
I'd call them direct tomorrow, they are closed today.
11-07-2016, 02:03 PM | #4594 |
Added some more bling...chrome master cylinder
11-07-2016, 02:22 PM | #4595 |
Got my eBay door hinges disassembled and ready for new pins/bushings. Only took the shop press, a lot of hammering, grinding the head off one of the pins, and a fair amount of cussing. But they're disassembled (almost, got a few roll pins to drill out) and ready for a proper cleaning, repainting, and new pins/bushings.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
11-07-2016, 03:16 PM | #4596 | |
Active Member
I took a few loads of leaves over to the leaf pile last night. We dropped a new to me, used 350 in this and I'm still ironing out all the issues with it. Ran pretty well, considering I need a little carb fine tuning......
The Dude abides. |
11-08-2016, 12:24 AM | #4597 | |
Give them a call, they are excellent to deal with and really nice folks.
Matt Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655 "Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!" |
11-08-2016, 01:49 AM | #4598 |
I spoke with Wes from Classic Heartbeat and he gave me some major tips about reassembling my front end.
11-08-2016, 09:49 AM | #4599 |
11-08-2016, 02:39 PM | #4600 |
Secrets hey, sure.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
