05-29-2012, 01:19 PM | #4651 |
Re: 67 cheby's Dropmember build thread
I love how you put them both in Slosh Tubz t-shirts.
The setup is looking really nice man... If you are anything like me.. when You get into this home stretch your frame rails start filling up with all kinds of stuff, you start really debating on where you are going to hide things, then you may have to redo some things. It looks like you have planned things out pretty well so HOPEFULLY you wont have those problems. BTW... did you cut those elevel sensor wires?
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
05-29-2012, 01:56 PM | #4652 |
67cheby
thanks man , i am considering running my batter wires through my step notch by drilling a hole and welding a piece of pipe in, just wondering what that might do to the structural integrity of the notch ? and yes i cut and shortened my level sensor wires ! ( i really didnt want to do that but...)
05-29-2012, 02:04 PM | #4653 |
i was thinking about a truckarm kit for the sake of simplicity but looking at the space created inside the frame from using the four link i might convert , on the other hand i might not be able to put brackets on the outside of the frame because of the arms there
has anyone ever considered z-ing the rearframe 6 to 8 inches bout right after the bulkhead of the bed ? doing it that way and raising the floor of the bed to the same amount might make mounting stuff under the floor eazier and keep the mountings to the floor stock figured to make a jig under the frame to hold the parts in there place make a precice slant cut over 6 inches raise the backhalf 6 to 8 inch where it sits and have a steelmill bend me some slantcut 6 inch wide U's the same thicknes steel of the original frame to weld in vertical in between them prolly need to make a pretty solid crossmember inside that z the thing with the wirefeed though the pipe you where talking about , it shouldnt make a difference , it might even be stronger , look at airplane ribs they fill them with holes and flange them there just as strong but lighter
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
05-29-2012, 02:45 PM | #4654 |
Congratulations Mike I know its been a long road and you are finally seeing an end! Good for you. Ill be looking for it out here in the mags!
05-29-2012, 02:55 PM | #4655 |
looks great brother
05-29-2012, 03:20 PM | #4656 |
Super sweet......Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
05-29-2012, 03:21 PM | #4657 |
67cheby
thanks...plugging away !
05-29-2012, 03:27 PM | #4658 |
Nice Video, looks great
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
05-29-2012, 05:35 PM | #4659 |
6>8 Plugless........
Awesome progress! I'd like to put air ride on my Longhorn. That'll be farther down the road.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-29-2012, 06:09 PM | #4660 |
Still Learning
Cool video Mike. Congrats on more progress
Posted via Mobile Device |
05-29-2012, 08:29 PM | #4661 |
Looks great buddy !
Stocker to Rocker http://67-72chevytrucks.com/vboard/s...=1#post5148380 "THE GRADUATE" http://67-72chevytrucks.com/vboard/s...08#post5763408 JohnnyC http://instagram.com/texpinstriper/ |
05-29-2012, 10:09 PM | #4662 |
I remember how I felt after i got mine plumbed and ran the valves manually! I was giddy as a school girl too! Nice Work Mike!
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
05-29-2012, 11:33 PM | #4663 |
Lol !!! I love it !!! It's coming around, Mike ! Congrats dude !
Chris click here to see my buildpage http://67-72chevytrucks.com/vboard/s...d.php?t=394656 ---------------------------------- 1979 C10 Silverado Big10 SWB Factory 454/400 Cardinal Red/Santa Fe Tan (original paint) 1969 Camaro X44 LS swap 1968 C10 SWB Fleetside (SOLD) 468BBC MultiPort TPI / Dynamic EFI P4 Black/Black 1963 Nova SS convertible (SOLD) 194 I6/ PowerGlide |
05-29-2012, 11:37 PM | #4664 |
chevy only
congrats! cool stuff
CHEVY ONLY... Nothin Else ! |
05-30-2012, 10:01 AM | #4665 |
67cheby
thanks guys, i installed all of my ride height sensors last night, now time for mounting the ride height sensor arms, and getting some pipe today to run through the notch for my wiring
05-31-2012, 10:20 AM | #4666 |
67cheby
i managed to get my wiring routed in all of the directions it needs to go (and zip tied it all into place) next step, i will weld 3/4 inch tubing to run it all in , keeping most of it hidden. I drilled one hole through both notches and welded in a piece of 3/4 pipe to run part of my wiring through , starting to clean all of the wiring up !
05-31-2012, 10:23 AM | #4667 |
67cheby
here are a few pic of the notch tube
05-31-2012, 10:36 AM | #4668 |
Nice work Mike looks great, always thinking of a clean way to do things.
05-31-2012, 10:52 AM | #4669 |
67cheby
thanks, i just want to hide as much as possible !
05-31-2012, 11:17 AM | #4670 |
Nice job on routing the wires, very clean
05-31-2012, 12:39 PM | #4671 |
CCTek
Good Stuff Mike! Keep it coming!
Chad 68 swb Project http://67-72chevytrucks.com/vboard/s...d.php?t=262840 72 swb Project SOLD http://67-72chevytrucks.com/vboard/s...=1#post3993641 THANKS TO: Hermance Design (www.hermancedesign.com), Paradise Road Rod & Custom, Harry Opfer Welding, Tri-State Machine, Wegner Automotive Research, Nsane Hotrodz (www.nsanehotrodz.com), Clayton Machine Works, CCTek (http://www.candctek.com) |
05-31-2012, 12:53 PM | #4672 |
mike you should get a kit from painless and bundle and cover the wire, go to like ace and get a frame plug to protect the power wire, also one all the level sensors are wired up and good to go all lights on the controller should be white no more red.
05-31-2012, 12:56 PM | #4673 |
also you running one battery or two?
05-31-2012, 01:26 PM | #4674 |
67cheby
the wires will be wrapped and then slid through the pipe that i will be welding to the frame in several places , i still need to tap my control arms and 4 link for the other end of the levelers, and 1 battery
05-31-2012, 01:55 PM | #4675 |
very nice and clean ....theh accuair extreem mount of wires was a little of a throw off but after some adult beverages and some brainstorming in finally too came up with a clean plan....I actually went from under the brige but ours is differnt..your idea is nice and will come out nice like all the things you have done....wish i had the time to put into it like that but its like I get maybee an hour or so to play and then its time to wash up and eat to get ready for work. the wife will kill me when I get the engine bay started, the bed frame wasnt so bad, lowes is so close so tubing is easy to get too so that saved some time but when it i need to buy a dimple dye set and a bead roller she isnt gonna be thrilled but I got a nice new back splash for the kitchen im gonna supprise her with. one last time for a question, run the vinspeeds or the octanes w/tribar????? ive narrowed hundereds to them, I got my brake together after a fun afternoon of safty wire and the wheels go next, Ive got my $ with Schott but can go either way at this point...I think the octains will really stand out of a crowd and fit the truck well. your thoughts?
Tags |
fiberglass inner fenders, pb hood hinges ", w/pb 4 link |
