03-29-2024, 11:47 AM | #4701 |
Re: What did you do to your truck today.The 3rd chapter
Hopefully in the short rows of a power steering install on my 67. Everything has gone about a smooth as expected to this point. Waiting on new hoses as the initial ones I purchased I did not like the way they fit.
It looks like the power steering box I installed is going to cut about one full steering wheel turn from lock to lock. I will have to learn how to drive the truck all over again.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
03-31-2024, 01:52 AM | #4702 |
Installed this crossmember that moves the trailing arm attachment upward and provides more clearance for the driveshaft to be higher. This allowed me to raise the rear of my transmission to improve the u-joint angles.
03-31-2024, 02:01 AM | #4703 |
I like your cross-over exhasust pipe.
03-31-2024, 02:05 AM | #4704 |
The guy who built my exhaust system just decided to do it that way. Not sure why.
03-31-2024, 02:47 AM | #4705 | |
The pulses from one bank of cylinders cancel out the pulses from the other bank, resulting in less perceived noise to human ears. [Dogs, not so much.] Also helps scavenging to increase low end torque. I have it on my '71 Jimmy. Crossover is behind the transfer case. Symetrical with a V8. With an L6, cylinders 1-2-3 have the forward collector, and cylinders 4-5-6 have the aft collector. So the cross-over has to slant diagonaly to occlude each other's detonations. [So an ''N'' pipe instead of an ''H'' pipe. My C/10 Stepside was set up in the '80s at Simmons' Engineering in Tucson. My project mechanic was an old country boy Circle Track hand. He knew a few old tricks as Chevy Sixes were preferred in that event due to their quicker hole shot response. X-Pipes are supposed to have the same effect, but I think when they channel down into one double tube, they don't get the scavenging the two interconnected tubes get. IDK. Probably a good topic for someone with a Dyno and no other obligations than to pursue automotive research.
03-31-2024, 12:07 PM | #4706 |
Nice weather this weekend so yesterday finally got the C10 on the road to put some miles on the new 327 and 5 speed to fully shake it down. Stopped at a museum that had some planes parked outside for a picture.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
03-31-2024, 12:29 PM | #4707 |
That's a nice pic. Reminds me of when I lived closer to Miramar. At that time a naval air station and home of Top Gun. (1980s) The Blue Angles came to town every year. What a show. It's all Maine now, but I think the Angles still do a show. If you have not seen a Blue Angle air show, it should be on your bucket list. TV does not do justice. Top fuel drag race and Blue Angles are must see live events.
03-31-2024, 02:16 PM | #4708 | |
03-31-2024, 02:48 PM | #4709 |
Otis is done that way, the truck had brand new Magnaflow's on it when I got it, but were way too loud and raspy for me, so my muffler man said this will tone it down, and it did...a lot. It makes the distinct left/right exhaust tones blend to a more pleasurable combined tone.
03-31-2024, 03:08 PM | #4710 |
At the body shop.
1904 Qjet hopefully leaks less than the 45 yr old one before.
" That didnt make it any newer " " Dont antique the equipment " |
04-01-2024, 07:09 PM | #4711 |
Already been told no “While it’s apart I might as well” cleaned the crude off the upper control arms truck has the original ball joints .
04-02-2024, 01:35 AM | #4712 |
Finally finished my speaker "enclosure" and bolted it to the dash
1970 C10 Custom longbed 350/350 |
04-02-2024, 12:24 PM | #4713 |
That's one of the nicest trucks I've seen.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
04-02-2024, 09:08 PM | #4714 |
Got the engine out today
04-03-2024, 04:05 PM | #4715 |
It’s a good thing that the engine leaked oil everywhere .
04-03-2024, 04:08 PM | #4716 |
And the list gets longer by the day
04-03-2024, 07:00 PM | #4717 |
Nothing like working on a west coast truck
04-04-2024, 01:24 AM | #4718 |
That is some clean sheet metal
04-04-2024, 08:55 AM | #4719 |
Nice work so far Mark, well done man
when I was cleaning my frame, I was always excited to see numbers ...........
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
04-05-2024, 03:55 PM | #4720 |
Cleaned up the old block . 3500 psi hot water pressure washer
04-05-2024, 08:02 PM | #4721 |
Frame came out real nice with the hat pressure washer . All the original brake lines look new . The pressure washer rental cost me $96 for the day I would do it again in a heartbeat.
04-06-2024, 11:59 AM | #4722 |
Who Changed This?
That came out nice, and you didn't even have to take the washer off the trailer. Mighty handy.
04-06-2024, 04:13 PM | #4723 |
Started prepping to replace the water pump today. Decided the radiator and fans needed to come out so I started draining it and unhooking lines and hoses. The goal was not to make a mess. With that in mind I decided to move the truck out of the shop onto the gravel to remove the radiator and pump, this way any coolant in the block could just run out there. OK! I hop in the cab and fire it up, pull it into reverse and didn't get that immediate thump into gear...it took me maybe a second to go from I'm gonna move this truck to engine OFF NOW! ...and so now I get to do exactly what I was trying to avoid, and then some! -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
04-06-2024, 06:44 PM | #4724 |
I just painted everything black since it’s a driver
04-06-2024, 09:07 PM | #4725 |
Not on my truck, I just drove mine to my buddies. New power steering is working great and wish I’d done that swap sooner.
Helped my buddy get his radiator in, all hooked up, and filled. We then rebuilt the driveshaft with all new u joints and carrier bearing. Got right the point of ready to fire up and ran out of time. Ready for first start and break in after full rebuild.
