#451 |
Cruzin
Re: Lime Wife's 67
took the steering column apart to replace turn switch, paint etc. also ground off the piece for the shifter handle and filled it. Man this stuff doesn't weld good at all. I took it to work after trying at home and backed it with aluminum and filled it with rod with a tig welder. Then ground it smooth and put some filler on it to make it slick.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#452 |
Re: Lime Wife's 67
man im glad im not the only one using rags! good work keep it up!
#453 |
Cruzin
Re: Lime Wife's 67
ha, thanks
#454 |
Cruzin
Re: Lime Wife's 67
turned the center link around like it should be never assume that somebody else did it right
#455 |
Cruzin
Re: Lime Wife's 67
got the column reassembled today with new turnsignal switch and switch lever. the end of the shaft has been messed up the threads are crappy i'll probably find me another shaft and replace it sometime, looks better shaved
#456 |
Cruzin
Re: Lime Wife's 67
yesterday i reinstalled the gauges, made me a tach wire to hook it up. Just have to installed a couple of knobs to finish. I love "hump" for the shifter being shaved off look, much cleaner.
#457 |
Grandpa in the rustmobile...
Re: Lime Wife's 67
This truck oughta look really good when its all green and finished! I assume the red carpet wont stay forever lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#458 |
Cruzin
Re: Lime Wife's 67
I hope so no the carpet is temporary the new stuff will be a charcoal or shade of gray probably.
#459 |
Re: Lime Wife's 67
So whats the color scheme gonna be? Are you gonna go to those november cruise ins at south pittsburg? dad was telling me 41 was pretty going from manchester to chatt. ive always done interstate
#460 | |
Cruzin
Re: Lime Wife's 67
#461 |
Re: Lime Wife's 67
I like to see the scenic roads. You and beth should see some of the roads just east of me (fall creek falls area, dunlap etc).
Real pretty area. You two dont strike me as hikers but you should check out greeter falls/stone door.
#462 |
Re: Lime Wife's 67
http://www.tn.gov/environment/na/natareas/savage/
Greeter falls isnt a state park, but could be its very secluded and a pretty drive up there a really pretty overlook I took these up there this time last year
#463 |
Re: Lime Wife's 67
thats a old hotel that looks out over a VERY pretty view of irving college the greeter falls spiral staircase is a bit of a hike but its good for ya
#464 |
Cruzin
Re: Lime Wife's 67
installed the glove box light and changed the "things" on the bulbs from red to green on the gauges.
#465 |
Cruzin
Re: Lime Wife's 67
Noticed fuel gauge wasn't working right, did some research the gauge is not the same ohms as the factory sender (they are available don't know why they didn't get it) but one that works with universal sender. So i took the old sender and guage hook it up to a battery to test and figured out it wasn't getting a good ground to the sender. They had the piece attached to a factory pickup with a WOOD SCREW! so the screw with the ground wasn't even touching the sender tube, so i secured it correctly and all works.
#466 |
Re: Lime Wife's 67
Noticed your new sig saying lol
wood screw makes me think of something my grandpaw would do
#467 |
Re: Lime Wife's 67
looking @ your project it has disc brakes what did you do to get that conversion, or what ? what did you use?
#468 | |
Cruzin
Re: Lime Wife's 67
The disc swap was already done when i got it but you can use a front suspension from a 71-72 or 73-87 just a few differences from 73 on. This truck has 86 model ball joints, and calipers, spindles etc.
#469 |
Cruzin
Re: Lime Wife's 67
figured i'd post something, i primed the door panels while back and installed with hardware from lowes. Works good don't know what color they will be so this will do for now. Its rained so much around here the trucks aren't going anywhere without a pull from another truck
#470 |
Cruzin
Re: Lime Wife's 67
heres a pic of the wheel i got painted awhile back to cold to paint anymore for now shade pic, sun pic
#471 |
Re: Lime Wife's 67
Brittany said she doesnt want it to look like a clown car
![]() Im not sure if I like it or not yet either. Better question-how did you paint in this weather LOL
#472 |
Re: Lime Wife's 67
Looking good
Posted via Mobile Device |
#473 |
Cruzin
Re: Lime Wife's 67
figured i should update: Got the wheels painted and mounted not the best pics all i have right now
#474 |
Cruzin
Re: Lime Wife's 67
there was alot of moisture in the engine, so i took the intake off to check for leaks most seem to think that its the pvc valve to blame when alot of moisture in the valve covers so i changed to a better one than that crap chrome one.
#475 |
Cruzin
Re: Lime Wife's 67
was running alittle off so i rebuilt the carb and tuned it, adjusted timeing and runs like a top now.
