01-02-2016, 11:44 PM | #451 |
Re: Project 68 k10 LWB..aka "The Hulk"
This is what it looks like from inside the cab.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
01-02-2016, 11:48 PM | #452 |
Time to clean up from the past couple days in the shop. Feels nice to almost be down with the metalwork on the cab.
01-02-2016, 11:58 PM | #453 |
Picture of the firewall before I grounds down all the welds. OH and I did cut the fuse block bulkhead whole and drilled the mounting holes.
The painless harness I installed before used long bolts to mount to the firewall. The American auto wire harness uses long wood screws from inside the cab towards the firewall. Looks like I am going to get long bolts or maybe even weld studs in like I did for the column mount. Has anyone welded studs to the firewall for the fuseblock bulkhead?
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! Last edited by First c10; 01-04-2016 at 04:16 PM. |
01-03-2016, 01:43 AM | #454 |
I like the 10/24 studs Nice job ! What did you decide for the fire wall insulation ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-03-2016, 02:04 AM | #455 | |
I am thinking lizard skin spray on liner or dynomat or equal.
01-05-2016, 08:09 PM | #456 |
I don't want to have a bolt or screw through the firewall for the fuse block so I used 1/4-20 x3" countersink machine screw. I used a half inch nut as a spacer to tighten the counter sink bolt to create my own counter sink in the metal. Then ground down the counter sick head and welded it in.
01-05-2016, 08:11 PM | #457 |
The inside studs.
01-05-2016, 08:11 PM | #458 |
With the fuseblock in place.
01-05-2016, 08:14 PM | #459 |
The firewall with the initial grinding. Now I need to finish the rest of the holes that I welded up and then that is complete.
Ok now what to do next???
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! Last edited by First c10; 01-06-2016 at 01:51 PM. Reason: wrong "whole" |
01-06-2016, 11:11 AM | #460 |
Excellent work as usual Scott!
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
01-07-2016, 11:44 PM | #461 |
That is a great idea on the fuse panel mounting. I'm going to have to steal that idea if you don't mind
Project is coming along real nice! |
01-08-2016, 02:43 PM | #462 | |
And thanks for the Comments
01-14-2016, 12:35 AM | #463 |
Has anyone ever removed the gas pedal bump or raised mount area in the floor? I was thinking about cutting it and folding it down to the same as the rest of the floor pan.
01-14-2016, 05:16 PM | #464 |
I left it in on my cab.
01-14-2016, 07:45 PM | #465 |
Did you just put bolts in the holes or weld them up?
01-15-2016, 12:22 AM | #466 |
Had a few minutes this evening so I cut the low hump out and got the high hump installed. I am going to weld 3/8" nuts to the floor and use stainless steal Allen button head bolts to hold it down. What sealer do I need to seal the high hump to the floor pan?i
01-15-2016, 12:26 AM | #467 |
Also drilled a hole for the driver door jamb. This hole is behind the driver AC vent location. If I want to run wires to the door I can just add a conduit from the jamb to the door. Via a conduit.
01-15-2016, 12:27 AM | #468 |
The passenger side does not have a location preset like the driver. So I went above where the AC vent would go.
01-15-2016, 12:35 PM | #469 |
01-15-2016, 12:37 PM | #470 |
3M has a product to seal the cover. I think GMC Paul or LMC caries it.
01-15-2016, 03:09 PM | #471 |
I think the factory just plugged the holes with some pan head screws originally. You are making everything so smooth it would not surprise that you guys might smooth that also!
Great job on the high hump we welded a square nut on our c10 project prior to cut out similar to what GM had used in our high hump RV cab. I'd like to know what that 3M product is as well?
01-27-2016, 01:24 AM | #472 |
I was able to take a picture of the buys I welded to the underside of the cab for the high hump. I used 3/8" flanged nuts.
01-27-2016, 10:11 AM | #473 |
That's a good idea, just needs to stay put if the high hump was ever removed again.
01-27-2016, 07:39 PM | #474 |
Got some Raptor liner for the underside of the cab. Oh and some of there Grip prep.
I was able to Rust Mort all the cracks and crevices on the cab. I also DA'ed the underside with 80 grit. Have a couple questions for you guys. 1- do I need to seam seal the underside before the Rapter coating? 2- is there anything I need to do to the underside before I coat? Thanks guys. Scott
01-27-2016, 10:48 PM | #475 |
Not being a body guy my first thought was to wipe it down with wax and grease remover. I also think when i had a Rhino liner installed they used scotch brite on the surface of the paint.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
