Old 05-16-2022, 08:18 PM   #451
Jason 56
Re: My 56 build
Handles are done and some progress on the accent pieces. As far as bodywork goes, I’m close to getting everything back in primer
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 05-16-2022, 09:31 PM   #452
tdishon
Re: My 56 build
Very cool!
Current project: 59 Apache with 2012 Corvette drivetrain
Jeep Trackhawk(beast)
tdishon is offline   Reply With Quote
Old 05-19-2022, 09:46 AM   #453
my56chevytruck
my56chevytruck's Avatar
Re: My 56 build
I follow your detailed work you do to see the next finished part you create. The work and skill you have is amazing. Keep it up. When do you predict a rolling classic?
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 05-19-2022, 06:06 PM   #454
Jason 56
Re: My 56 build
Thanks. I’m hoping to be driving by the end of August. We’ll see
Old 05-25-2022, 10:02 PM   #455
Jason 56
Re: My 56 build
Progress pictures. Rear view mirror, visors and dash emblem are mounted. Everything is back in epoxy primer before the humidity gets bad. Still have to finish the front fenders and firewall. Once everything is black I’ll spray gray high build to block for final paint. The color change should help prevent sanding to metal.
Old 05-25-2022, 10:05 PM   #456
Jason 56
Re: My 56 build
A few more pictures in primer. Also finished the door panel wood.
Old 05-25-2022, 11:31 PM   #457
dsraven
Re: My 56 build
nice work. you gotta love seeing it all one colour, even if you will be sanding it.
Old 05-26-2022, 06:04 AM   #458
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: My 56 build
Very nice work! Those wood pieces are going to look killer!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-26-2022, 06:39 PM   #459
Jason 56
Re: My 56 build
Thanks, I thrive on seeing progress. It’s amazing how long it takes to prep for paint, but the result is very satisfying.
Thanks, I’m really happy with how all the wood is coming out. I still plan on doing a small panel in the center console, lower section of the center console, and the lower seat panels in wood. Should look unique.
Old 06-06-2022, 11:52 PM   #460
Jason 56
Re: My 56 build
Finished fab work on the center console. Should be the end of metal fab on this project. Plan on putting a charging port on the back of the console. Just some bodywork and it should be done. Even had time tonight to make the wood insert.
Old 06-06-2022, 11:54 PM   #461
dsraven
Re: My 56 build
Good idea on the charging ports. I would put in a couple, 1 hot with key on and 1 hot with key off.
Old 06-07-2022, 07:45 AM   #462
Father&son56project
Re: My 56 build
That's some intricate fab work on the console. The pic that shows the backside of the console really shows how much effort went into creating that panel. Nice work!
Father&son56project is offline   Reply With Quote
Old 06-07-2022, 11:40 PM   #463
Jason 56
Re: My 56 build
Thanks, I plan on doing something like that.
Thanks, I’m getting pretty good a beating metal into the shape I want. I plan on installing a double din pioneer radio in the top of the console to finish it off.
Old 06-15-2022, 10:49 PM   #464
Jason 56
Re: My 56 build
Center console just needs body work. Ended up mounting the radio from the back with a couple straps. It the opposite of how it’s supposed to be. The single din radio part is supposed to be mounted and the screen is supposed to float. I didn’t like that look. I rolled all the edges of the opening for a consistent look. I really like how I turned out. I have next week off, so I’m hoping to get the frame stripped down and painted.
Old 06-15-2022, 10:58 PM   #465
Kevin_C
Re: My 56 build
Looking good. I know what you mean about those screens. The advertisement photos always shows them straight on but I never like the look from the side when you can see how much it sticks out. Hope to get back to work on my console soon. Keep up the good work
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90
http://67-72chevytrucks.com/vboard/s...d.php?t=746958
Kevin_C is offline   Reply With Quote
Old 06-16-2022, 11:17 AM   #466
6DoF
6DoF's Avatar
Re: My 56 build
agreed, screen looks great this way.
6DoF is offline   Reply With Quote
Old 06-24-2022, 10:10 PM   #467
Jason 56
Re: My 56 build
Progress update. I’ve been working on final details that need to be addressed before paint. Drilled holes and mounted the door cards. Kick panels are in with speakers. Also made the wood base for the center console. My grille finally came in, so I made sure all the front end chrome would fit!
Old 06-24-2022, 10:21 PM   #468
Jason 56
Re: My 56 build
Ive been trying do figure out how to stop the hood from falling into the grille when it’s open. When I was taking apart my tailgate I decided to use the same style spring latches. Works well and won’t need a prop rod. I have about 1” + clearance to the grille. I have to do some final fitting of the hood and doors. Then everything gets pulled apart and I’m going to finish and paint the frame. Then onto the body paint
Old 06-25-2022, 04:49 PM   #469
slammed57
slammed57's Avatar
Re: My 56 build
Lookin great bud
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 06-27-2022, 07:57 AM   #470
6DoF
6DoF's Avatar
Re: My 56 build
well played
Old 06-29-2022, 09:13 AM   #471
my56chevytruck
Re: My 56 build
great job, looks perfect
1940 Ford Dlx Coupe
1969 Mach1
Old 07-09-2022, 07:14 AM   #472
Jason 56
Re: My 56 build
Last piece of fabrication… I think Made a cold air intake box. I noticed when I was just idling it down the road the intake air temp was 120 with the filter so close to the exhaust. Bought the paint yesterday. A little more fit and finish and it’s coming apart to paint the frame.
Old 07-09-2022, 12:23 PM   #473
slammed57
slammed57's Avatar
Re: My 56 build
lookin fantastic.... gettin close... I can smell the paint fumes comin soon
My 57 current build
Old 07-10-2022, 11:42 AM   #474
Tempest67
Tempest67's Avatar
Re: My 56 build
nice work, as usual.
Can't wait to see it in paint
Tempest67 is offline   Reply With Quote
Old 07-11-2022, 09:28 AM   #475
6DoF
6DoF's Avatar
Re: My 56 build
that is a really nice execution, and even adds a little bit of ram-air in there.
