12-11-2016, 10:01 PM | #4726 |
Re: What did you do to your truck today? Chapter II
12-11-2016, 11:22 PM | #4727 |
This is the link to the item I purchased (eBay):
12V-24V Car Vehicle Waterproof 5V 2.1A + 2.1A Dual USB Power Sockets Outlet I had to use a "step bit", it's used to cut small holes into larger ones for conduit into electrical panels (I have used them many times) they are about $35 at Lowe's Home Improvement, make sure to get the one that is up to 1-1/8", at least that's what mine was. See if you have an electrician friend, they may have one you could use. Don't try holding a hole saw in place - it won't turn out well (for the truck or you, I have seen people try it). I have several vehicles that I want to add one of the sockets to, so the $35 wasn't a bad deal. I took a round file to remove the barbs that remained from the bit. It was a really tight fit so it doesn't move around inside the hole, I just got it in there, I started to hook up the wires, but when I started looking at the wiring, it was quite obvious that whoever installed the radio (non factory, i don't think a dealer did it either), there was a nest of wires, a lot of them were cut and hanging loose, so I need to chase them out and see what goes where and remove wires that are not necessary. Nothing can ever be easy! You may be able to use a small grinding wheel on a Dremel tool to make the hole larger, mark the hole needed then cut, this would also allow you to leave the sides flat so the power adapter is "keyed" into the hole. After that you just simply connect the old cigarette wires to the back using the supplied crimp connectors. That's about all I know that you would need. I hope it helps! Thanks guys! |
12-12-2016, 12:07 AM | #4728 | |
This has not failed me yet. The different metals with expand and contract at different rates breaking the corrosion bond. You do not need much torque. It will break free when the bond is broken. |
12-12-2016, 12:36 AM | #4729 |
12-12-2016, 10:17 PM | #4730 |
12-12-2016, 10:53 PM | #4731 |
Ordered more parts to get ready to lower my 70. Should have all pieces I need to get project started. Going to do 3 and 4 inch drop and install front sway bar and adjustable track bar in rear with lowered shocks. Hope to get started soon.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
12-12-2016, 11:01 PM | #4732 |
12-12-2016, 11:43 PM | #4733 |
12-12-2016, 11:49 PM | #4734 |
I have never been much for blue,,,but yours has totally captivated me, so nice a shade and the perfect rim and size, you hit the mark with your truck and I don't say that lightly.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
12-13-2016, 12:10 AM | #4735 |
RAT1968 '68 Cab/'71 Parts
Once again, I'm right there with you, Mud.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
12-13-2016, 11:20 AM | #4736 | |
Thanks!! It's a love/hate relationship with this truck.. |
12-13-2016, 03:56 PM | #4737 |
Went from all blacked out to chrome, blazer is still blacked out so im not to bothered by not having a completly blacked out vehicle
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
12-13-2016, 10:17 PM | #4738 |
12-13-2016, 11:13 PM | #4739 |
laying low
But it looks like glass already!
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
12-14-2016, 01:17 AM | #4740 |
12-14-2016, 09:36 AM | #4741 |
this was on my FB feed this morning, thought you guys would get a kick out of it. Ingenuity at it's finest!
"Roads? Where we're going, we don't need roads!" I think he needs to paint the rims white and make some hub caps to match the front! Last edited by matthamby; 12-14-2016 at 09:53 AM. |
12-15-2016, 11:03 PM | #4742 |
I have been working on installing this cup holder and I got it finished today.
http://67-72chevytrucks.com/vboard/s...d.php?t=698292 |
12-16-2016, 08:14 AM | #4743 |
I like that cup holder much better than the ash tray version I'm using. What did that come out of?
Only Two...... Only two have laid down their lives for you, Jesus Christ and the American GI. 2007 Chevy 2500HD 4x4 Duramax 1970 Chevy K20 (SOLD) 1972 Chevy C15 (1/2 C10, 1/2 c20) 1970 Chevy C10 (parting out) |
12-16-2016, 08:25 AM | #4744 |
Looks good...what did your rear mounting bracket end up looking like?
1970 C10 Short Stepper with 71/72 front clip. |
12-16-2016, 10:53 AM | #4745 | |
I wish I had a picture. I used two 3/4x1/8 strap steel, curved and bolted to the lower heater control mounting bolts on the bottom of the dash then screwed to the lower heater housing. I bolted on each strap a small piece of the strap metal sticking out to catch the mounting clip on the cup holder.
12-16-2016, 08:37 PM | #4746 |
now thats a cool go anywhere kinda truck.....
12-16-2016, 09:10 PM | #4747 |
Old member
I need a couple of these for the 56 Bel Air and 64 SS Impala!
12-17-2016, 08:59 PM | #4748 |
Nice job installing the carpet too. Mine looks like a wrinkle bomb and not even close to as smooth as yours.
12-17-2016, 09:59 PM | #4749 |
12-17-2016, 10:17 PM | #4750 |
I installed a bench seat I got cheap but it's in excel lane condition. I also cleaned up my differential and started the new yukon gear posi carrier install with a 4.10 gear... With a 4 speed it'll be really fun behind that 454....
