12-24-2016, 09:56 AM | #4776 | |
Old member
Re: What did you do to your truck today? Chapter II
[quote=ole dollor;7804150]
I got it right after we bought the 64 SS Impala. We decided we needed something to haul the 56 Bel Air and the 64 SS Impala along with my truck to shows!
12-24-2016, 01:47 PM | #4777 |
Getting some freshtoration done on the '72. Here are before and after pics of the seat. Time of day and sun make the color look different, but it's not, it's original vinyl in the original color.
12-24-2016, 05:16 PM | #4778 |
Scored a 60/40 bench for my '71. In decent shape for $70. My bench is trashed and not comfortable
1982 K10 SWB 1987 V20 - Sold - Doh! |
12-25-2016, 05:00 AM | #4779 |
Got tired of not having a working radio so since the dash was still cut up I decided to take a old radio that was laying around and wire it in. Put some 200 watt 4 inch speakers under the seat and popped a CD in!
The good: It sounds awesome! The bad: Auxiliary In seems yo not work right now but I think its because of a cord that is a little too long (25ft). Once I try a reasonable lengthened cord and get that working then ill just have to plug in a antenna so I can listen to the radio. |
12-25-2016, 03:20 PM | #4780 |
changed up the interior on the project for the third time. got a good deal on some white bucket seats. found door panels on ebay for $20
12-25-2016, 03:57 PM | #4781 |
Yesterday, I finally finished up under the dash, and installed my "new" glovebox insert (I've had it in the garage for about six years, so it was time ). For those wonderinding "how difficult was it?, not at all, it just takes a little patience to get the screws to start. I also changed out my window seals. Makes all the difference in the world.
12-25-2016, 09:14 PM | #4782 |
Started running all the new SS brake lines.. Not sure why they all came out on the OUTSIDE of the frame at the front where the all meat up to go up to the MC... but I guess i can fix that easy enough...
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
12-25-2016, 09:31 PM | #4783 |
I recently redid my brake lines and remember reading that there were some trucks in '67 that had the brake lines run to the outside of the frame like this, and there were kits available that replicated this. For the kit I used, I remember there being an option to choose inside or outside the frame. Looks like you ended up with the kit that goes outside.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
12-27-2016, 02:12 PM | #4784 |
Thats a deal!!!
Brad handshoe |
12-28-2016, 12:36 PM | #4785 |
Well, initially I was going to install an adapter plate for my qjet to performer intake and check the rear differential fluid level. I was able to install the plate and clean up the intake somewhat, then I started to inspect my v-belts. I had new ones in case they were due. That some when I noticed this....
My lower alternator bracket was clean broke off at the rear mounting tab. Have no idea how long it's been like that... I did just adjust the belt tension about 2 weeks ago. I did notice a difference in the electrical side of things (dim headlights, static on the radio speakers, dim gauges.) Also, we had some rain last week, and was using the wipers, I was told by previous owner that the washer pump had a hiccup in it that would run the reservoir dry and continue to pump without turning off. I must have forgotten that when I rewired the entire vehicle, rewind back to last week and I was messing with the switch and noticed if I pressed the wiper switch in my wipers would kick on to the slowest speed, "cool." I thought..... well when I got home I tried sticking my hand under the dash to see if I could clear up the static I was picking up on the radio, when my hand grazed the wiper motor that thing was cooking! Got a nice red mark on my knuckle just to show how hot it was. So I immediately recalled what the P.O. had said about the pump. So I waited a few minutes and disconnected the harness, we'll, I tried to at least.....the wires were stuck on there, so much as that the ground terminal for the pump pulled the connector clean out of the pump body. Each of the ground wires were really on there. To make a long story short, I'm assuming that maybe because my alternator tab was broken causing intermittent grounding issues, the wipers were having a hard time finding ground and used the washer pump case as a ground,and heated it up from the voltage. So I just pulled the washer pump ground wire from the switch and harness,no more heat, and I still have my wipers. Luckily I learned my lesson about throwing out old parts, I had another lower alternator bracket in the garage, also I was able to swap out my belts. Good enough reason for me! Lol
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
12-30-2016, 12:19 AM | #4786 |
12-30-2016, 09:54 PM | #4787 |
Finally got a week plus of no work and no classes to do some serious work.
Stripped, de-rusted, minor dent/pitting repair and primered the long fleetside to replace the current rust bucket on my truck. That took several days, mostly due to my confined workspace (single car garage). Today, pulled out the seat, ripped out the rotting carpet and mounted the refurbished gas tank behind the seat.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
12-30-2016, 09:54 PM | #4788 |
Double post deleted
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 Last edited by DarkFlounder; 12-30-2016 at 09:57 PM. Reason: Duplicate |
12-30-2016, 09:56 PM | #4789 |
More body work
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
01-02-2017, 03:48 PM | #4790 |
Swapped the cast iron intake and qjet now I need newer kick down and probably swap to cable throttle while I am at it. Truck barely got out of it's own way before. Feels like it flies now
01-02-2017, 09:58 PM | #4791 |
Painted the top of the dash black. Column is getting painted black next. Just thought with the orange dash, the "Parchment" white visors, door panels, arm rests and seat upholstery will contrast better against the black, carpet, column steering wheel and dash pad.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
01-02-2017, 10:03 PM | #4792 |
After
01-02-2017, 10:08 PM | #4793 |
It's too damn cold to be doing much around here but I managed to paint my tie rod ends. I'm about ready to put the front suspension back on and hook up brake lines on drum/disc conversion.
Hey man 67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603 |
01-03-2017, 01:40 PM | #4794 |
Removed old rusted bed. Assembled and mounted replacement bed. It's not perfect, but it's a HUGE improvement. And the extra weight from the rust-free bed has smoothed out the ride into work.
And now, with the bed out of the garage, I've got more room for activities.
01-03-2017, 04:37 PM | #4795 |
Hi - I am just up the freeway in Vancouver - '68 owner..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
01-03-2017, 06:58 PM | #4796 | |
Sounds like a really rusted bed for being out in California!
01-03-2017, 07:14 PM | #4797 | |
70+ ( Old Skool Club )
https://www.theweathernetwork.com/ca...ewan/saskatoon
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-03-2017, 09:22 PM | #4798 |
The truck and I had a discussion about what was going to happen during the winter. We did some tequila and talked some more.
01-04-2017, 11:01 AM | #4799 |
So, how did the truck react after it's portion of the 2-kill-ya?
01-04-2017, 01:33 PM | #4800 | |
Just because it's been in California all its life doesn't mean it wasn't a hard life.
