Old 10-07-2016, 09:10 PM   #4851
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by daddyjeep View Post
I went into my local Sears last week for a socket and they had that exact torque wrench on sale for $39. Of course i brought it home with me. The plastic collar that adjusts the weight on my old Craftsman broke after about 15 years.
Well you was right about the price, I saw the same one that I bought for $39 on their website so I called them up and asked if they would price match their own site and they said bring it in and we'll see what we can do. So today I drove in with my Chinese wrench in hand and got $32 bucks credited back to my account, nice, the new wrench is sorta worth the $39 bucks I paid for it, makes it easier to swallow
Gregski is offline   Reply With Quote
Old 10-07-2016, 09:11 PM   #4852
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Status Report: so after rejetting the carb to the 63/67 primary/secondary jets the truck runs better, I drove it in to work today again then ran over to SEARS, but its still lean at WOT, so tonight after it cools off (the engine not the weather, ha ha) we will rejet it to 64/69 the default jets the carb would have come with new
Old 10-07-2016, 10:16 PM   #4853
69heavychevy
69heavychevy's Avatar
Re: Restoring Rusty
Originally Posted by Gregski View Post
I believe I am, it's the Fel-Pro 1255 part number, and this is what Summit says:
"Designed for GM Vortec, ZZ4, Edelbrock E-Tech cylinder heads. End rail seals are not included. Installation to be done with a bead of silicone at the manifold ends. Dual bolt pattern. No exhaust crossover openings. Not for use on 1982-85 fuel injection. Gaskets fit many O.E. and aftermarket heads."
I was going to use fel-pro ms98000t, but if those 1255's seal just as good i'll use those instead. I like that price a lot better.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 10-08-2016, 03:21 PM   #4854
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
That is a good gasket but I think it's only available in a kit, which is pretty expensive if you just want that gasket. Stock Suburbans run them, see below
Old 10-08-2016, 03:28 PM   #4855
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Engine Ratlle
Well not good fellars! After putting on just over 100 miles on the newly reassembled engine I started hearing a rattling sound coming from the engine. Naturally I can't tell where exactly it is coming from, (I even tried the long pipe to the ear trick)
Sounds like there is a loose nut bouncing around one of the valve covers.
So I removed both valve covers and did not see anything peculiar there. So I thought maybe a rocker is loose, nope. Maybe a collapsed lifter, nope. Well I readjusted the valves just for good measure, and went for a test drive, and the rattle is still there. Cant really hear it when the engine is idling but it increases with RPMs gets faster and louder.
Hmmm sound familiar? I swear it better not be these pesky Hooker headers again!
I'm off to the gym now to blow off some steam, gonna bench press 300 lbs (plus or minus 200, ha ha) when I get back I plan on removing them headers and trying my old OEM stock exhaust manifolds, joy!
Old 10-08-2016, 03:48 PM   #4856
Wide Open
Re: Restoring Rusty
Wow that sucks
Wide Open is offline   Reply With Quote
Old 10-08-2016, 09:35 PM   #4857
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by Wide Open View Post
Wow that sucks
Yup, big time!
Old 10-08-2016, 09:39 PM   #4858
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Well I strapped on my ol' exhaust manifolds back on with the ol' LMC Truck dual exhaust with the generic turbo mufflers and the rattle is still there, so the good news is it wasn't my Hooker headers leaking again, the bad news is we don't know what it is, and it could be ugly, something in the bottom end
Old 10-08-2016, 10:29 PM   #4859
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
unplugged one spark plug at a time and started and ran the engine to see if the rattle noise goes away and it does not, darn it, tomorrow the oil pan comes off and we take a deeper dive
Old 10-08-2016, 11:19 PM   #4860
Marshy
Re: Restoring Rusty
In your last trip into your engine did you check the condition of the main bearings when you replaced the rod bearings? Did you check the rod bearing clearance when you were there? In most cases people have the crank polished when they do bearings.
I was surprised to see you deglazed the cylinder bores with the crank still in and replace the rod bearings without polishing the crank or check the makings (maybe you did but didn't tell us?). At this point you would have been farther ahead to send the block to the shop to get cleaned up inside and out, had crank turned or just polished and had them put new cam bearings in. Then you'd have a whole new motor. Sorry for the set back, I know how that can be. Knowing which corner to cut can be tricky.
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15
GM 4 bolt 880 roller block, 062 Vortec Heads
Comp Cams XR258HR-10, MSD Street Fighter HEI
Edelbrock: Performer Intake 2116, 1405 Carb
Long tube headers, 2.5" duals to Flow Master Super 40's
Vortec Engine Build
Marshy is offline   Reply With Quote
Old 10-08-2016, 11:29 PM   #4861
harley87ta
Re: Restoring Rusty
Good Luck.. Hopefully it's something simple
harley87ta is offline   Reply With Quote
Old 10-09-2016, 01:08 AM   #4862
SkinnyG
SkinnyG's Avatar
Re: Restoring Rusty
Make sure the rod caps were put on the correct way.
The two "tangs" that notch the bearings in go together.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 10-09-2016, 10:17 AM   #4863
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
True but I didn't have $1,500 to spend and I wanted to do the work myself or at least see if I could
Old 10-09-2016, 11:07 AM   #4864
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Yes sir, I payed attention when I took them off and I noticed that there was a sharp pointy ridge or edge on the driver side bearing caps all pointing to the front of the truck and the opposite was true on the passenger side so I made sure I put them back in, in the same fashion, I even double checked after torquing down the cap bolts to spec
Old 10-09-2016, 11:09 AM   #4865
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I'll tell you this much I will be pissed and relieved at the same time if I just find my 9/16ths six point socket rattling in the oil pan (I'm looking at you Craftsman you know you love to get lost all the time) ha ha
Old 10-09-2016, 11:25 AM   #4866
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
Did you change the oil pump while you had the pan off?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 10-09-2016, 11:27 AM   #4867
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
No, cause it is brand new I did that about 6 months ago already, new pump new pickup screen etc.
Old 10-09-2016, 11:36 AM   #4868
SkinnyG
SkinnyG's Avatar
Re: Restoring Rusty
These notches, in green. You can see the shadow of the notch on the rod.
Though it sounds like you put the caps on correctly anyway.
Old 10-09-2016, 11:43 AM   #4869
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
Well it's probably not needed then...
Old 10-09-2016, 11:44 AM   #4870
Marshy
Re: Restoring Rusty
You bought standard size bearings IIRC. Could it be possible the rod journals are already 0.010 under and you bought the wrong bearings? If you have the old bearings check the backside and see if they are 10 under bearings.
Vortec Engine Build
Old 10-09-2016, 12:11 PM   #4871
68Timber
I know the pieces fit
68Timber's Avatar
Re: Restoring Rusty
I forgot about that, but I wondered about that too when you bought the bearings and mentioned they were standard size. Did you mic the crank to see if it'd been turned?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-09-2016, 02:13 PM   #4872
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originals were stock
Old 10-09-2016, 02:14 PM   #4873
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Of course not, ha ha, this is a dingleberry rebuild, if I was to do it all over again I would have re used the old bearings and just changed the rings, oh well, live and learn
Old 10-09-2016, 02:21 PM   #4874
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Status Update: so dropped the oil pan and did not get killed by any falling shrapnel, so that's good
managed to pull out the first four bearing sets (to do the others I need to rotate the crank and things will get mangled or the pistons will have to be pushed up out of the way) so we do half at a time
#1 more wear than #3 and #4 too loose to snap back in to the cap
#2 more wear than #3 and #4 too loose to snap back in to the cap
#3 normal wear, snaps back in to the cap
#4 normal wear, snaps back in to the cap
as you know The Greg only blames himself or at least himself first, but remember how my torque wrench gave up the ghost while torquing the cylinder heads, well guess what the last thing I torqued prior to that was my bearing caps, so there I'm looking at you Craftsman
so I am going to get two new bearings and pop them in to #1 and #2 and torque them down with my brand new China made Craftsman torque wrench
Gentlemen, I have seen many opposite recommendations on how to install the new bearnigs, from clean them with brake fluid, wipe them down and install them dry, to use engine oil, to goop some engine assembly lube on them, so what are your favorite ways to install these bad boys? the last time The Greg just used engine oil
Old 10-09-2016, 02:33 PM   #4875
Marshy
Re: Restoring Rusty
Clean them with brake kleen then use engine oil or assembly lube, your choice, can't go wrong with either. Dry is not a good idea IMO. Also not checking that you have the right bearing could mean another trip back into the engine and another replacement. Plastigauge is a sound method for checking journal clearance. How about those main bearings? If the rod bearings needed replacing then the mains did also. Might want to check then while your in there.
Vortec Engine Build
