01-24-2017, 12:59 PM | #4876 |
Re: What did you do to your truck today? Chapter II
01-24-2017, 07:23 PM | #4877 |
Swapped out the back glass rubber for a used one with the stainless trim.I bought a back glass with trim for $20.00 at my local pick and pull.My back glass was in better shape so I just used the rubber and trim.
01-24-2017, 08:22 PM | #4878 |
Today I pulled the old JVC radio out to see if the dash had been hacked up by any of the previous owners. It was nice to see that it wasn't. I will get an original looking radio some day.
This week I ordered pins and bushings to rebuild the door hinges, as well as a NOS door stop retainer to replace one that is missing. |
01-24-2017, 09:46 PM | #4879 |
yes its a smaller starter. I think they may consider them high torque mini. not sure on that. We used one a 468 13 to 1 motor. Im not sure when gm started using them? I just order a starter for a 98 1/2 ton 350. Used them on several cars now. It was 210 from the chevy house. half the weight and size of the old starters.
01-24-2017, 10:18 PM | #4880 |
spent the evening on the internet researching roller motor with mechanical fuel pump realize I need a better job or a good lotto win
01-24-2017, 11:28 PM | #4881 |
01-24-2017, 11:58 PM | #4882 |
01-25-2017, 09:11 AM | #4883 |
I never liked the stock location of the step bumper on my truck. It always looked too low to me. So, after doing the 2.5" frame raise in the rear, it was the perfect opportunity to tuck the bumper higher up. I think it looks much cleaner now. I was originally going to ditch this bumper for a sport bumper, but this simple step bumper is growing on me. I think I may keep it.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
01-25-2017, 10:27 AM | #4884 | |
I really like what you've done there. I have a similar bumper, and the same issue with it mounting an inch too low. I may just have to do this myself. It looks much better.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
01-25-2017, 01:33 PM | #4885 | |
01-25-2017, 01:37 PM | #4886 |
Mounted the inverter and Bluetooth, usb, sd card, 1/8 jack, FM radio install started.
01-25-2017, 03:02 PM | #4887 |
I love your tailgate mod. That is one of the coolest mods I've seen on this forum. I think with all the fab work you've done on your truck, you could knock out that bumper raise in no time
01-25-2017, 04:51 PM | #4888 |
Thanks it was not easy to get all of it to fit, but nothing is impossible, it's just never been done. I've done quite a few mods that only a trained eye would see.
01-25-2017, 05:20 PM | #4889 |
I changed out the ignition switch today. it was acting up, ( cranked fine but wouldn't start till I let off the key to run position ). All planets are once again aligned....
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
01-26-2017, 02:30 PM | #4890 |
Installed new fuel line, filter and guage....old rubber one was clogging up filter.
1970 C10 Short Stepper with 71/72 front clip. |
01-26-2017, 10:08 PM | #4891 |
Before
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
01-26-2017, 10:13 PM | #4892 |
After
01-26-2017, 11:42 PM | #4893 |
Old member
Worked on the Ramp Rat tonight. Got the electric washer jug plumbed and the screen in the cowl installed. Picked up some epoxy putty to start on the rebuild of the GM steering wheel tomorrow also.
01-27-2017, 12:18 AM | #4894 |
Started to put body molding on, not really digging it seems cheap and flimsy. Not so much the side stuff but for sure the tailgate.
01-27-2017, 07:28 PM | #4895 |
Old member
Took the old seat out and replaced with a 90 model seat. Put the drivers side harness in have to make a LQ yard run to pick up some more belts. Installed the new strob light also.
Took the hump out and sealed it up good and put more screws in it. Got to get a rubber mat for it and the inside should be done.
01-27-2017, 08:44 PM | #4896 |
01-28-2017, 08:23 AM | #4897 |
Rust repair and body work is done. Got some paint on her. Custom PPG not the original "Medium Red" and not quite "Hugger Orange".
01-28-2017, 08:25 AM | #4898 |
New Goodmark bed sides.
01-28-2017, 10:01 AM | #4899 |
How did I get this OLD!
http://67-72chevytrucks.com/vboard/a...1&d=1485611782
Painted my later model console fawn beige to fit in between my Procar seats in my Vermillion 67
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
01-28-2017, 10:25 AM | #4900 |
Paint looks great SOCO.
