Old 10-23-2003, 11:18 AM   #26
Izzy
Trucker.
Izzy's Avatar
Originally posted by crazy4chevs
I wouldnt of put somthing like that up front, I was just thinking more clearance for towing if I decided to in the future. I think it sounds like the firestone 2600 at all 4 corners is the way to go. This should be a little bouncy?, but I think a good compramise if I want to tow somtime down the road.
(you never know when you will need to tow somthing, and wish you would have made it so you can.)
Can I see some stance pics, and a quick suspension rundown and tire wheel size?
Example: pic, firstone 2600 all around , dropped spindles and 235-60-15 on 15x8's
Thanks,Lance
The 2600's are good all around, up front they're perfect and they're better than a sleeve bag out back,for towing, because they can hold nearly double the weight per corner.
Izzy is offline   Reply With Quote
Old 10-23-2003, 01:25 PM   #27
Physh1
Originally posted by nate68
I want to do bags eventually. What rides the best? My interest in air ride is to improve the ride so that i can stand to drive it
Any well designed system will give you a plush caddilac style feel. Very comfortable. You can also make them handle well too
Cameron
Please visit http://www.WhosNextRacing.com & http://www.FSCustoms.com
2000 Chevy Crew Cab Dually, 1994 Chevy ECSB 4x4, & 1983 GMC Sierra Classic
Physh1 is offline   Reply With Quote
Old 10-23-2003, 08:19 PM   #28
BigChevMan
My Thoughts Exactly!
BigChevMan's Avatar
Thanks,Lance
Well..either way your talking minimal differences between the 2500 and 2600 bag. On our type of trucks with the trailing arm, the bag is sort of in a leverage position. This is why the double convoluted bag is used versus the sleeve bag that cam was talking about. On later model trucks where a 4-link or leaf spring setup is used, the sleeve bag is used because that setup is in a 1:1 ratio, whereas the trailing arm suspension is closer to a 2:1 ratio. Even still your talking about a bag having the ability to support 1300 lbs each which is more than most tongue weights of trailers and trailer hitches.
If it were me I'd stick with the 2600 lb bag upfront and the 2500 lb bag out bag. Your not sacrificing your towing capacity, but you'll gain a little in the way of comfort from the ride.
BigChevMan is offline   Reply With Quote
Old 10-23-2003, 10:03 PM   #29
7T7
Regular guy
7T7's Avatar
Wasn't it AIM that started that whole 2500lbs, 2600lbs stuff?
I'm not being a smart azz. I use those numbers also from time to time when I'm trying to get someone to understand the differance between the bag sizes.
I know it used to chap Tony's hide when people would refer to firestone bags as 2500 or 2600. hehe.
The Firestone numbers are confusing and change from time to time. And now with other companies jumping in it's hard to keep up. I think I need a program.
SAY! Justin, can you guess who this is.
I'v been away from this "on line" stuff for a while.
F&S
7T7 is offline   Reply With Quote
Old 10-23-2003, 10:23 PM   #30
lotik
drag it like you stole it
i am running slam es-82s all the way around. i am going to switch the fron to es-72's before to long. the 82 is to much bag for the front. it maxes out the suspension easily. i can definately say i wouldn't ride anything else, but i may try the new airlift bags.
negative camber //LA\\
lotik is offline   Reply With Quote
Old 10-24-2003, 10:52 PM   #31
BigChevMan
BigChevMan's Avatar
F&S
Frank! My long lost teacher! I just asked Jon a few weeks ago if you were still alive and kicking! Man..glad to see you back!
As far as the 2500 lb 2600 lb thing...it's just easier to describe than using proper terms.
I mean..how many people actually know the difference between a f6957 versus f6873?
Then you have the 224c and the 255.
and then with airlift and slams added in that adds the 2b7 and the es-82, hs-82 and such...
so therefore I stick to the 2500 lb and 2600 lb anymore and save myself all this typing.
Man..it's great to have you back frank!
Old 10-24-2003, 11:21 PM   #32
Chevy4Life
Chevy4Life's Avatar
I bought a set of rs-72's for the rear and planned on running rs-82's up front. Should I use the 72's in the front and put 82's out back? or run 72's all around? How do the 82's ride in the back? I think I would gain an inch of lift with the 82's, but I don't want it to be to rough.
Who sells the bag brackets and cups for the front end? and rs-72 or 82's, pending lotik's reply?
Jay
Chevy4Life is online now   Reply With Quote
Old 10-25-2003, 10:15 AM   #33
phantom dually
Project92 SWB stepside
phantom dually's Avatar
I have a set of frontbracket cups for up front NEW for $110 shipped. Pm for pics. Also they are powdered black
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 10-25-2003, 02:14 PM   #34
lotik
is your truck bodydropped? are you trying to lay frame? 72's will max out the front suspension for sure. it wouldn't hurt to run the 82's out back, but it doesn't really matter. it also depends on where you mount the bags.
Old 10-27-2003, 06:03 PM   #35
Chevy4Life
Chevy4Life's Avatar
No, it's not bodydropped, and I'm not trying to lay frame. I want my ride height to be about a 4/6 or 5/7 drop. The front has 2 1/2" drop spindles and the rear bags are in the stock coil location. would the 72's ride softer out back than 82's. what combo would be better to get the truck level( or slight rake) at ride height.
Thanks,
Jay
Old 10-27-2003, 06:07 PM   #36
Chevy4Life
Chevy4Life's Avatar
phantom dually,
PM sent on the brackets.
Old 10-29-2003, 11:11 PM   #37
solidaxel
solidaxel's Avatar
O K, I want to put a four bar out back and air bags behind the axle on my 55 1st series GMC, what bag do I use, and will I need a compressor and storage tank/ Where do I find a listing on these parts (air bags)
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-29-2003, 11:27 PM   #38
lotik
i would suggest a sleeve bag for behind the axle. not sure on the model# but its by firestone.
Old 10-30-2003, 03:11 PM   #39
rigo
Flake Daddy
rigo's Avatar
#f9000 is the rear sleeve bag by firestone most commonly used...
make sure you use a limiting strap with them...or if the bag overextends..it will pull the bellow of the ringed end..
rigo
1968 SWB Fleet Daily Driver 350/TH400 shaved driprail,emblems,tailgate,air ride suspension
1964 Pontiac Catalina 2dr. hardtop shaved everything, air ride suspension
1998 Range Rover
1960 El Camino....in the works.....
rigo is offline   Reply With Quote
Old 10-31-2003, 01:06 PM   #40
Izzy
Trucker.
Izzy's Avatar
rigo
Been there, done that and it's no fun.
It's easier just to use the shock to limit the suspension than adding limiting straps but either way you'll be fine.
Old 10-31-2003, 11:11 PM   #41
rustyold69
student wrench turner
rustyold69's Avatar
i dont want to try and steal the post or anything but does anybody have pictures of the brackets there using up front?
1969 Chevy C-10 with 250 L6
2002 GMC Sierra 2500 HD Duramax with banks six gun
rustyold69 is offline   Reply With Quote
Old 11-01-2003, 03:56 PM   #42
BigChevMan
BigChevMan's Avatar
The first one is from airlift. The second one is from captain kaos. it's very easy to make your own brackets.
Old 11-02-2003, 12:11 PM   #43
Izzy
Trucker.
Izzy's Avatar
Here are the ART mounts.
Old 11-03-2003, 01:58 AM   #44
nate68
we really need a air ride for dummies thread.
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
