03-02-2018, 08:13 PM | #26 | |
Re: Proportioning valve question
1972 GMC 157" dump |
03-03-2018, 01:56 PM | #27 |
What if I have a 68 that had drum brakes and I am retrofitting to disc. I have a new valve with dual front outputs, but the original lines use a T. Would I be better off running separate lines to the left and right?
03-03-2018, 03:20 PM | #28 |
You can hook it up either way and it won't make any difference in how the brakes function. The dual front outlets of the combination valve are basically like a Tee fitting built into the valve housing. So the only difference is the location of the Tee.
04-27-2018, 04:13 PM | #29 |
I'm in the process of installing the proportioning valve I mention above.
The proportioning valve has 3/8 ports for the front brakes. My original front brake lines(I assume from non-power drums, but someone had a 3/4 ton booster and master installed) are 1/4 down to the T fitting on the crossmember. Then the lines are 3/16 from the T out to the brake hoses. I am making new lines for the front. It does not appear that I can use a 1/4 hard line into the proportioning valve because I can't use a 3/8-24 fitting with a 1/4 line. Would it be ok to use a 3/16 line from the Proportioning valve down to the T fitting? |
04-27-2018, 06:29 PM | #30 |
04-27-2018, 07:45 PM | #31 | |
Yes, you should be fine. |
04-27-2018, 11:06 PM | #32 |
Thanks Randy. I was looking around and it appears the 71-72 have 3/16 brake lines from the proportioning valve down to a Tee and then 3/16 lines to each caliper. Can any one confirm the front brake lines are smaller than the others?
