Old 01-23-2006, 11:03 PM   #26
project76
project76's Avatar
Re: Bagged project progress
Looks damn good!!!
What bags are those? Are you planning on running stock control arms up front?
Oops nevermind, i see the control arms in one of the pics
Brandon
project 67 swb bagged on 20" Coddingtons
project76 is offline   Reply With Quote
Old 01-23-2006, 11:39 PM   #27
fletch4x4
fletch4x4's Avatar
Bags are slam specilities RS-72's They just came out with a new model and i got these cheap.
Im gonna hopefully use some kind of modified stock arms, we will see.
Bagged/Turbo 1970 GMC C-10
Crew Cab 1984 Chevy R-20
fletch4x4 is offline   Reply With Quote
Old 08-08-2006, 03:21 AM   #28
fletch4x4
fletch4x4's Avatar
Holy Crap! an Update!
Well, Summers been busy and the GMC got very little attention until tonight.
This is how it has been sitting
The Air Brake Hoses that Im using as short leads from the bag to the hardlines that im going to use copper for (Plumbing company is the family business).
Makin the Front Bag Cups
All done except for some some grinding and paint.
Makin the plate to attach to the crossmember
Front bag assembly being made. The brass fittings were changed a few times , they wont actually work how it is in the pictures out of the crossmember.
Old 08-08-2006, 03:22 AM   #29
fletch4x4
fletch4x4's Avatar
Gettin there...
And Finally Back on 4 wheels for the 1st time in wayyyy too long
Here is just a cool pick i took while takin a break
Its good to get back into the Truck... but unfortunatly I only have the next 2 weeks to really work on it untill winter time. Look forward to some more updates soon though. The front is still 4 or so inches off the ground, but its only the bag thats holding it back....more cutting to come!
Old 08-11-2006, 06:16 PM   #30
Lumpy33
Just get rid of those lower cups..
Lumpy33
72 C-10 step
Lumpy33 is offline   Reply With Quote
Old 08-11-2006, 06:29 PM   #31
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Or cut them down. I cut my lowers down to about 3/4"
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 08-12-2006, 01:05 AM   #32
Bushmaster
Junior Member
I can't wait till I start mine. Looks good.
If You Can't Spark It Park It...
Bushmaster is offline   Reply With Quote
Old 08-12-2006, 05:31 PM   #33
fletch4x4
fletch4x4's Avatar
Im down to about an inch on the bottom with them now, and Im also using a cup on the top too... but I need to trim that down a little more and it will finally lay with the bag installed
Old 08-12-2006, 08:52 PM   #34
67Fleet
67Fleet's Avatar
cup in the top? You're not running upper plates?
-Bret
Old 08-21-2006, 03:44 PM   #35
fletch4x4
fletch4x4's Avatar
I have 2 options, cutting up the upper bag mount, or using the upper and lower cups. There isent enough room for the bag with a plate in there for the front to lay out.
Old 08-21-2006, 06:27 PM   #36
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Looks like it might be kinda low, look out catapillers
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 12-17-2006, 12:43 PM   #37
fletch4x4
fletch4x4's Avatar
Well Its been way too long and I only get to work on the truck now and then.
But i have some time over the holidays and have been workin on the truck as much as i can
I made these brackets for the bags....I know there pretty far inboard but its just how it worked out
I also finished up the welding on the notch....finally and this is how she sits right now.
The front is getting some ART strong arms (horray for christmas!) insted of some cut up stock ones.
Ill keep posting updates over the next few weeks
Old 12-17-2006, 01:19 PM   #38
poorboy
poorboy's Avatar
Truck is looking good. I wish I had a lift. It must make things alot easier.
poorboy is offline   Reply With Quote
Old 12-27-2006, 09:03 PM   #39
fletch4x4
fletch4x4's Avatar
Some more work done....
Air Tanks (used to be fire extinguishers)
Filled in some holes so i can bolt the crossmember back in after the section in it
New ART Stong Arms
Holding itself up! (finally)
Old 02-05-2007, 04:06 PM   #40
fletch4x4
fletch4x4's Avatar
Its been a while again, but started workin on the engine. My plans are to build a 383 after the truck is on the road and I have some more cash. So in the mean time I cant put a dirty engine in a shiney truck.
A little nasty
So after striping the accessories off and spending wayy to long with degreaser, cleaning solutions, and scotch bright pads. heres the 1st coat.
All the parts were sandblasted, or cleaned up in some way.
Old 02-05-2007, 04:06 PM   #41
fletch4x4
fletch4x4's Avatar
edit: double post
Old 02-05-2007, 07:28 PM   #42
jlaird
jlaird's Avatar
Is your frame laying on the ground in the pic where you have your StrongArms installed?
jlaird is offline   Reply With Quote
Old 02-05-2007, 08:48 PM   #43
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
How much did you section out of the crossmember? And how far is the frame section under the cab from the fround.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-05-2007, 09:28 PM   #44
Mello Mel
African-American Shaolin Monk
This is sweet ! i will hopefully be starting my project soon ! threads like this always get me going !!! keep up the excellent work !!!!!!!
Mello Mel is offline   Reply With Quote
Old 02-10-2007, 11:53 AM   #45
fletch4x4
fletch4x4's Avatar
Not too sure which pic you are talking about but yea it does just barley lay frame in the front, the rear is no problem. With the weight of the rest of the truck and engine i doubt it will be a problem.
There is 1 3/4 sectioned out of the front crossmember. The crossmember to the rear of the cab I also cut up some, but im not 100% sure the hoop is going to be highenough for the driveshaft when its laid out. Thats why ive been workin on cleaning up the engine/tranny (plus its a nice change of pace)
Old 02-10-2007, 12:27 PM   #46
67Fleet
67Fleet's Avatar
Looking killer fletch. I can't wait to see more progress pics!
-Bret
Old 02-10-2007, 03:28 PM   #47
FRENCHBLUE72
PROJECT 7DEUCE
Thanks you anwsered my ?
MEMBER #6377
Project "7DEUCE"
Old 02-11-2007, 12:16 PM   #48
[ol'Blue]
[ol'Blue]'s Avatar
cant wait for more pictures!
[ol'Blue] is offline   Reply With Quote
Old 02-11-2007, 03:12 PM   #49
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Good work, I'm now subscribed.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 02-11-2007, 03:57 PM   #50
AA Taco Chris
AA Taco Chris's Avatar
looks great!!
But with the front crossmember sectioned... should you be basically laying rocker w.o a bdrop??
Or would you need to Z it as well?
AA Taco Chris is offline   Reply With Quote
