09-29-2006, 06:43 AM | #26 |
Re: Factory auxiliary fuel tanks ? Surely not................
Lemield,can you show the sticker?And/or,give the RPO?If this is true,it`s news to me.I`d like to have it varified.Not doubting your word as much as wanting to varify it as fact.In all these years I`ve never seen another auxilary tank in that location as a factory option.
09-29-2006, 07:45 AM | #27 | |
I did that for a while but as bartstoy points out it doesn't always happen at a good time. I bought a float and gauge kit at JC Whitney. Followed the directions in the kit for the install. Then mounted the gauge knee-knocker style in the cab.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
06-05-2014, 07:23 PM | #28 |
Hi folks. New to the group. I own a '69 3/4 ton with Auxiliary fuel tanks. Last weekend I drilled out the rivets to the fuel doors to get them off the bed so I could replace the locks (no keys). Does anyone know if these doors or the locks are still available from any source? One of the doors is in pretty bad shape. Thanks.
06-06-2014, 12:04 AM | #29 |
Take the lock to a locksmith and have keys made. They are pretty generic. BTW welcome and thanks for searching
06-06-2014, 02:42 AM | #30 | |
As all have mentioned above, the only factory installed extra tank setup for trucks was RPO NL2, it came with the fuel gauge selector switch and sticker just above where the left a/c outlet is on the dash and it came with the switch for physically switching the fuel flow on the driver's side door sill so the driver could reach it while driving, and the filler neck and fuel cap coming thru the upper bedside as Tim mentioned. The aftermarket tanks could be single or dual, dealer installed or owner installed, doors thru the bedside or filler neck inside the rear wheelwell just in front of the tire. I have two in my back yard from my 71 that the guy I sold it to didn't want! They were made by companies like Travel Tanks and there was one named camel tanks or something like that... Here are some factory NL2 tank ref docs: |
06-06-2014, 02:43 AM | #31 |
and here are some aftermarket dual tank instruction manual pics for ref:
06-06-2014, 02:44 AM | #32 |
and a few additional ones of aftermarket switching arrangements
06-06-2014, 08:46 AM | #33 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=330636 Another thread that discusses the option.... http://67-72chevytrucks.com/vboard/s....php?p=2979585
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
06-06-2014, 11:52 AM | #34 |
Thanks Larry, good point. I shoulda said the only factory saddle tank, and I tend go think in terms of 71/72 stuff, sorry about that.
Which switch pic is for your rear tank? What was the RPO for the rear tank? Thanks for adding this in. |
06-06-2014, 11:59 AM | #35 | |
The option code on my SPID is 4N18JS. The dash switch is above the lighter and it controls the guage. The manual switch is on the drivers side rocker panel. The pictures of these are in this link: http://67-72chevytrucks.com/vboard/s...d.php?t=330636
06-06-2014, 12:23 PM | #36 |
Thanks Larry, I had totally forgotten about this (obviously). I can't really tell in the pic in the shared thread, what were the markings on your dash switch for the fuel gauge selector (and were you ever able to figure out if the fuel gauge selector switch was factory? Seemed like that part of the discussion trailed off in the thread)? Main/Rear? or something different? Just never have seen one of the N18 switches up close.
06-06-2014, 12:30 PM | #37 |
Jocko,
I don't know what the original label looked like or if there even was one....when I got the truck it had one of those old plastic labelmaker labels on it. I used my more modern labelmaker to put MAIN AUX on there...so that's what is on it now. I too am curious about what was there originally. I am certain that the dash switch is factory since there is a sending unit in the aux tank. Looks like the factory used the same switch location for the dual tank setup too. Maybe SSTim or Special-K or DeadheadNM will chime in as they seem to know about this stuff too.
06-06-2014, 12:39 PM | #38 |
I have the switch on my dash . And had it on my floor next to seat I pulled them out . It's on the SPID as well aux flue tanks
1969 C20 CUSTOM "RUMBLEr" |
06-06-2014, 12:48 PM | #39 |
Which one are you talking about 69Rumbler - the N18 or NL2 type?
Larry - I just noticed you had this same discussion IN THIS THREAD back in 2006! sorry about that, I knew it was a very old thread, and just read the recent post by TJ and kwmech. |
06-06-2014, 12:50 PM | #40 |
No problem Jocko...I can always discuss 67-72 Chevy or GMC trucks or anything with an engine for that matter!
06-06-2014, 03:28 PM | #41 |
Carpe manana
I've had two sets of 1970 aux tank parts (including that from the truck in post #32 above) and Larry's appears to be the correct GM toggle switch in that those I had appeared the same. I actually still have one whole setup (sans the Blazer tank) sitting in a box in my garage now. Would be fun to put together a thread illustrating all the components for both types (70 and 71/72) with diagrams. The 70-only tank is one of the least seen factory options for 67-72 trucks IMO.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
06-06-2014, 03:53 PM | #42 | |
06-06-2014, 04:29 PM | #43 |
Yes, I have filler necks in both left and right wheel wells, with the same floor switch as in the pictures above. I never switched over to either auxiliary tank because the gas in them is probably varnish now. Besides, it costs too much just to fill just the one tank now.
06-10-2014, 12:08 AM | #44 |
The spot welds on one of the doors broke loose while trying to get the original lock out. Patience is not always one of my virtues. That is why I was wondering if there was a source for the assembly anywhere or if anyone had the part number of the assembly. On the other hand I may have just created a justifiable reason to get a cheap spot welder...
I purchased a couple mail box locks at Home Depot that look like they may work once I get the old locks off (hopefully without breaking the spot welds on the other door). Regardless...thanks for the suggestion. Taking to a locksmith is definitely something I'll look into if these new locks don't work out. |
03-04-2015, 10:53 PM | #45 |
I had a 1972 C20 402BB w/Turbo 400 Auto, Factory Air, Tilt Wheel, it had two Auxiliary Fuel Tanks with one mechanical switch next to the seat. When I had it switched to the aux tanks the fuel pump would take excess fuel not used by the engine and return it to the main tank behind the seat, filling it. you could watch the fuel gauge rise up till it was full or the aux tank was empty then I would have to switch back to the main tank.
I sold this truck 20 years ago, I recently purchased a 71 C10 350 w/Turbo 350 Auto, Factory Air it has one drivers side Aux Tank I haven't tried using it yet, it has only one mechanical switch next to the seat as well. |
09-01-2019, 11:37 PM | #46 |
I just bought a 1968 Suburban with one of these auxiliary tanks. I wish I knew when this could have been installed. The tank is drilled for the second row seat too.
09-02-2019, 10:34 AM | #47 | |
Who Changed This?
