Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 10-12-2006, 06:15 AM   #26
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
Nice detailed pics, brings back alot of rusty metal memories I thought I had finally put behind me.
J/K, great work, your on the 'fix it' side of things now.
One question I can't see from the pics, is the hard top on?
If not it really should be to keep those lower door pillars where they need to be.
I like this pic with the coffee cup...speakes volumes.
vtblazer is offline   Reply With Quote
Old 10-12-2006, 07:47 AM   #27
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I have the cowl hangin' from a pipe that goes across my workshop, plus I have taken a diagonal measurement across the door opening. When I mount the door back on that becomes the final check, worked for the drivers side. I think that as long as you don't fool with brace/channel that connects the cowl with bed evrything should stay in place. Only do one side at a time, I think you said this? I usually give the winch 1 or 2 clicks up after I cut to prestress the metal. I guess there a lot of ways to do this.
Your green truck has always bin one of my fav. ones, although mine will never be that nice, I shot for that excellance
Sorry to bring back rusty memories, I think the cure is to buy a Arizona truck. Hope they realize how lucky they are!!
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-12-2006, 09:38 AM   #28
florida4x4
Re: PO has me PO'd
wow thanks for the pics. that looks just like my junk in 2000. be really careful about putting in the rocker panel. I set mine in a little high on the drivers side and had contact with the door. To fix it, I took a 5lb sledge and a piece of oak to "settle" the rocker. I didn't cause any visible damage but I'd rather not have had to do it that way.
1972 GMC Jimmy - 383SBC | TH350-NP203-NP205 | D60PL | 14FF Detroit | 42 TSL's | 4Xeyes | Heavy FOotE
"Trail in. Trash out."
Florida4x4 dot Com
florida4x4 is offline   Reply With Quote
Old 10-12-2006, 07:56 PM   #29
RustyParts
RustyParts's Avatar
Re: PO has me PO'd
Sometimes newmetaltherapy is the only way to put that ole rust into remission. But it feels sooooo good to get rid of it.
Nice work.
RustyParts is offline   Reply With Quote
Old 10-13-2006, 06:38 AM   #30
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
Sounds like you have it covered.
Knowing is half the battle.
AZ. rides definetly have an advantage but their not perfect by any means either.
I flew out to AZ. and drove my green one home because I was thinking along those same lines, cool adventure but not even close to rust free.
Not meaning to highjack and nowhere near your metal replacement but here's what my AZ. blazer was like. (yes, there was more on the other side too)
What color are you going to paint it when the body work is done?
Old 10-13-2006, 08:44 AM   #31
florida4x4
Re: PO has me PO'd
... I think the cure is to buy a Arizona truck. Hope they realize how lucky they are!!
Just make sure it lived it's whole life out there and when you get it home disassemble, clean and rust proof it!!
Florida4x4 dot Com
Old 10-13-2006, 03:33 PM   #32
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
After looking at the green one, I thought it came that way and you just picked a clean rust free Blazer, had no idea you did all that work. Looks like an original one, nice work, I think we all strive for that level of craftmanship. I don't know what you do for a living, but sure could get into the restoration business.
Didn't know you were hijacking, lot to learn on this here computor.
I would really like to paint it two-tone, white panel w/dark green metallic to match my dash. I was going to use the early trim to cover up my eyebrows as they are still a little tatty. Maybe gun metal panel to be a little different...
SAFETY FIRST
AS usual, off topic
Jim
Old 10-13-2006, 03:42 PM   #33
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Nice work.
Thanks Rusty, you know, right now I have air where the rust used to be and it still looks a hole he!! of alot better.heh heh
After working on these things for 35 years, I should have a BS degree if not a Doct. in rustymetalolgie.
SAFETY FIRST
AS usual, off topic
Jim
Old 10-13-2006, 07:24 PM   #34
RustyParts
RustyParts's Avatar
Re: PO has me PO'd
Amen Brother, Amen.
Old 10-13-2006, 08:07 PM   #35
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Rusty, it must be beerthirty in Ol' Kentucky by now!!
SAFETY FIRST
AS usual, off topic
Jim
Old 10-15-2006, 10:43 AM   #36
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
OK, here's the last step of disassembly. Take your time on the seams as you don't want to destroy the sheet metal underneath. The method that works best for me is as follows
Pry up what ever you can get and pull back with pliers, it helps if you can wedge a small screwdriver on the other side of the spotweld, now when you use your cutoff wheel it will grind both sides of the spot weld, top and bottom, try pulling some more and you should see movement, if not grind some more. After it breaks lose, you'll end up with a 1" pc., cut that off and start on the next one. It's sorta like opening an old ham can. Channel locks work best as they have a rolled head that is helpful in the cam action that is required. BTW you should be cutting, grinding in the same direction that your seam is running! Once you see blue metal, you are almost thru the first layer of metal. Give yourself plenty of light, so you can see exactly what you are cuttin'
Here's some pics.
BTW, your seams should be cut flat, like a ribbon, as any angle on it will only give it more strenght and you don't want that!!
As you can see in one of the closups, I had planned to just weld up the hole that looks like a sailboat, but after separating the seam the rust was hidden and it doesn't make sense not to fix it at this stage, as it will only bite you in arse a few years down the road.
OK new parts are here from Goodmark, time to cut and fit, cut and fit .....
SAFETY FIRST
AS usual, off topic
Jim
Old 10-15-2006, 11:22 AM   #37
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Dude, that rocker floorboard is freakin' ugly, then I see a post elsewhere with a prestine orange painted floor and a blue cowl. What gives?
SAFETY FIRST
AS usual, off topic
Jim
Old 10-16-2006, 07:05 AM   #38
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
That would be a different project blazer currently under construction.
That pristine floor is original paint and the blue cowl is from a truck that I grafted a blazer windshield frame onto, it's about five different parts trucks being put together to make a blazer for my daughter.
http://67-72chevytrucks.com/vboard/s...d.php?t=156022
Old 10-18-2006, 11:44 AM   #39
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Floorboard is in loosely, have to trim everything up to get it to fit right, I'll take pics. when I get back from salmon fishing in N.Y., truck still not ready for yet another fishing trip. Oh well, maybe for the spring trip!
SAFETY FIRST
AS usual, off topic
Jim
Old 10-23-2006, 05:18 PM   #40
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Well here is my current progress, the kickpanel is a PITA, so I'll get into that later. BTW, pics. are loaded backwards
Any questions?
SAFETY FIRST
AS usual, off topic
Jim
Old 10-23-2006, 08:11 PM   #41
72CSTC5
72CSTC5's Avatar
Re: PO has me PO'd
Damn you guys build some rusty trucks. I guess if you had no options than........
72CSTC5 is offline   Reply With Quote
Old 10-25-2006, 08:56 PM   #42
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Here are some current pics with the flange being worked on
I'll describe the steps later with the flange bent
SAFETY FIRST
AS usual, off topic
Jim
Old 10-25-2006, 09:19 PM   #43
florida4x4
Re: PO has me PO'd
clecos! whish I had them when I did mine. lol
Looks good including the cinderblock door
Florida4x4 dot Com
Old 10-26-2006, 05:52 AM   #44
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Yeah, they are one of my most fav. tools. Shop is a little small, but it has everything I need. 14'x18' Thanks
Here's some pics. of the flange bend. I've kept my tools to a minimum so anyone with basic hand tools can do it. Channel locks are great for making the flange bend
SAFETY FIRST
AS usual, off topic
Jim
Old 10-26-2006, 06:32 AM   #45
krue
Designated A-hole!
krue's Avatar
Re: PO has me PO'd
Looks like you do good work.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 10-26-2006, 06:48 AM   #46
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks Krue!! Better than putting it in body shop prison, if you can find one to do it. Actually it's good therapy for me, I enjoy taking a rusty POS and turning it into something usable. Someday it might even look as good as VT's green one!! Jim
Wait until you see what I do next, the purist"s are going to scream!
SAFETY FIRST
AS usual, off topic
Jim
Old 10-26-2006, 06:57 AM   #47
krue
Designated A-hole!
krue's Avatar
Re: PO has me PO'd
If I ever get my wife a house built, I'm gonna build me a shop and get started on my trucks.
www.daveramsey.com
Old 10-26-2006, 04:50 PM   #48
84 400
Sb 400 club
84 400's Avatar
Re: PO has me PO'd
COME up here to the salty north and see for your self. you can look on a 1 year old truck and it will have rust that is why alot of us store the nice ones during the winter months. Also that is why i bought my truck down in Texas
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 10-26-2006, 05:35 PM   #49
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I got a better idear, live in a trailor and build a workshop. I'm sure the Mrs. would love that idear
SAFETY FIRST
AS usual, off topic
Jim
Old 10-26-2006, 06:45 PM   #50
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
No chance...No way...couldn't happen...
J, your bringing another one back from the brink, keep it up.
