Old 12-05-2006, 06:16 PM   #26
raggedjim
raggedjim's Avatar
Re: 1-Piece Window and a better bodyline....??? (pic)
Well, don't go expecting any special treatment just because you're blue...
We treat 'em all the same, that's what makes this board better than others!
Just kiddin', Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 12-05-2006, 06:18 PM   #27
-Greg72
-Greg72's Avatar
Just kiddin', Rg
Geez....if I had known that, I could have bought $25 worth of fiber cutoff wheels instead!!!
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s
Find me on INSTAGRAM @MIGHTASWELLK5
'72 K5 - Greg's "Might As Well™" Build
-Greg72 is offline   Reply With Quote
Old 12-05-2006, 06:21 PM   #28
raggedjim
raggedjim's Avatar
It's money well spent, I know it takes alot of time and effort to keep this board running...
Rg
Roger
'70 GMC Jimmy 2wd
Old 12-09-2006, 07:41 PM   #29
pharcyde05
pharcyde05's Avatar
that makes scence you would need the a piller to stablize the front of the window when its up my piller is gone cause i am not putting a window back i was just showing the amount off top of door i think the window will be stable just being held in by a piller and making the horz felts tight fit to glass if you can get regulator remounted to make room for larger glass
pharcyde05 is offline   Reply With Quote
Old 12-10-2006, 01:43 AM   #30
72CSTC5
72CSTC5's Avatar
Pharcyde05, did you cut the front pillar of the door off too? I am doing the same thing on mine and wad debating if I should cut the front pillar portion of the door off or to leave it on. I am going to chop down my windshield two inches and weld the cowl panel to the frame and then move out the windshield mounting lip to have a flush mount windshield and lay it back just a touch and shave off the top of the drip rail and make it smooth.
72CSTC5 is offline   Reply With Quote
Old 03-22-2007, 02:16 PM   #31
herb101
Used Register
herb101's Avatar
Sorry about the thread resurection here but,....
I was searching for posts about door cracks in the hinge area and found this. I read through and it got me to thinking and remembering my 1st car - 1974 Impala 2dr hardtop. It had HUGE doors, no vent windows and no window support frames above the door. Thinking "yeah, but it is supported by the hardtop" - I went searching for a similar converible and found this photo:
Is this not the same design we are shying away from when going to 1 peice windows on Blazers & Jimmies? GM used it for years. Are we making too much of the unsupported window theory? Just some food and photo for thought.....
Herb
herb101 is offline   Reply With Quote
Old 03-22-2007, 04:13 PM   #32
-Greg72
-Greg72's Avatar
With thick enough glass, anything should be possible!!!!
Old 03-22-2007, 05:42 PM   #33
jaros44sr
jaros44sr's Avatar
Hey Greg just went thru your gallery, cool stuff. That one road trip with the Burb and trailer looked like a tuff trip. Thanks for the views. J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-28-2007, 09:05 PM   #34
Hollywood Knight
Junior Member
Hollywood Knight's Avatar
How about this one.
Hollywood Knight is offline   Reply With Quote
Old 03-28-2007, 10:28 PM   #35
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Originally Posted by Hoolywood Knight View Post
How about this one.
I think in order to have a 1-piece window, you need side windows...
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
