01-02-2007, 02:13 AM | #26 | |
In Memoriam...
Re: water trick
That sound like a pretty sweet deal there. Might be worth a try.
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." |
01-02-2007, 06:12 AM | #27 | |
Weekend Warrior
Re: water trick
like i said - pretty hard to kill them.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
01-03-2007, 12:52 AM | #28 |
Having issues
Re: water trick
Well, I seen a good 'ol 350 throw a rod at IDLE, what does that have to say about ford VS. chevy? I thought it was pretty funny, but the owner didnt, that was his work truck.
(engine failures happen to us all, and I think brand loyalty is stupid, they all crank out garbage) |
01-03-2007, 01:05 AM | #29 | |
Re: water trick
although i will say... The thing that keeps me driving chevy's (although i was raised in a ford family), is the abundance of aftermarket and replacement parts, which keeps the prices down, and all this is due to the fact that most parts are practically universal since the SBC was pretty much unchanged from the late 50's till the late 80's.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
01-03-2007, 06:21 AM | #30 |
Re: water trick
well im not sure which one ill do yet but if i do go with the seafoam do i pour it in the same way as i would with the water??? and i guess if my truck runs good now and i get all the carbon out itll run even better, and if it put it in the oil do i put it in inplace of a quart??? and with the feul do i pour it as i would any other feul treatment??? Thanks for all the comments and advice guys, id be lost with my truck if hadnt found this board.
-steven
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME Last edited by GREASEMONKEY72; 01-03-2007 at 06:27 AM. |
01-03-2007, 05:19 PM | #31 |
its all about the +6 inches
Re: water trick
I've never used seafoam, however, if it is a liquid, you can hydro lock... read the instructions. I'd imagine it says something like rev engine to 2000 RPM and slowly pour into carb.
01-03-2007, 05:27 PM | #32 |
Parts and more parts
Re: water trick
We used to take a pint of tranny flluid and pour it down the throat of the carb, with the idle being held open to keep them otor running. Then as the container was just about used up, let it drown the motor out and kill it. Let this soak for a short period, so that it will loosen any carbon residue and then start the engine and drive it until ths moke clears out of the engine. It appeared to make a difference in the motor's operation. We called it a "Hydraulic Valve Job".
I have also seen brake fluid dumped down the carb in the same fashion |
01-03-2007, 05:55 PM | #33 |
Re: water trick
So.....Hmm....
If you did use seafoam, water or whatver else to clean up the valves, how would you know whether or not it worked? Would crap shoot out the exhaust? I assume it would right? |
01-03-2007, 06:20 PM | #34 |
Re: water trick
Depends on what type of muffler you are running. If it is a straight through, then MAYBE you would see something, BUT I doubt it. What might give you a clue is the performance is smoother, the acceleration is better, the miss that you had is gone, or heck even all of the cylinders are actually firing now.
01-03-2007, 06:21 PM | #35 |
Questionable
Re: water trick
Don't bother with water. Strong potential to hydrolock! Water doesn't compress, if you're going to try this method, use a spray bottle and mist the water into the carb, I wouldn't POUR it in, even slowly.
http://67-72chevytrucks.com/vboard/s...hlight=seafoam Please read that thread, it discusses Seafoam, how to use it. I have had *exceptionally* good results with Seafoam. You are not supposed to use it on 120k mile or more engines. IT can remove oil deposits from your gaskets that are holding them together, causing leaks Believe me - when you kill the engine, then fire it up 10 minutes later, you'll know it worked, it smokes like holy hell from the carbon it's burning off. I saw someone take a bore scope inside a cylinder before and after using Seafoam - things went from brass colored to shiny, shiny silver. The stuff is no BS. People have been using it for decades with great results.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 01-03-2007 at 06:22 PM. |
01-03-2007, 07:34 PM | #36 |
Re: water trick
As stated earlier, I have been pouring water down the carbs of my vehicles for over 20 years, using a cup at at a time at fast idle and have never hyrolocked anything, personnely I don't believe you could lock it. It would take a lot of water to completely fill a combustion chamber on most any engine while it is running. It shoots a ton of crap out of the exhaust and you will notice a difference in how it runs, it will be better.
I have a 1934 John Deere D that has a factory water injector on it that is attached to the block and draws water directly from the cooling system. When a farmer hit a rough spot while plowing he could turn a handle that opened the valve and WATER is injected into the 2 combustion chambers, and puff, no hydrolock, just more power! Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
01-03-2007, 08:09 PM | #37 |
Re: water trick
Water going down into a cylinder will create a steam cloud and that is where the extra power comes from. This steam will loosen hardened carbon depsosits in the upper cylinder regions. This was used in the WWII era, by the Germans to get their airplanes to move faster, with more payload. Pouring water down the intake in a controlled volume will not hydralock the piston on a running engine. Some of the newer modern engines, with close tolerances, could get some damage, but only if the water is poured in fast.
01-03-2007, 08:25 PM | #38 |
Re: water trick
I used to use the GM product called "Top Engine Cleaner" or some such name that you poured down the carb at high idle and gassed out all the neighbors with huge plumes of white smoke. They stopped selling the stuff in California a couple years ago,but I know a GMC parts guy that stockpiled some. That stuff REALLY works to clean out carbon. Now I have a rebuilt so no such probs.-cougar--'69 Custom Camper Longhorn,2nd owner
Last edited by WorkinLonghorn; 01-03-2007 at 08:29 PM. Reason: added my truck descrip. |
01-03-2007, 09:28 PM | #39 |
Re: water trick
sweeeeet... another longhorn owner. Welcome to the forums
01-03-2007, 09:48 PM | #40 |
Re: water trick
Seafoam rules. I run a can of it through my older vehicles each spring. If you have one that has never seen the treatment, some (including myself) could feel the difference in power. Also will be better on gas. Start your truck & on high idle, slowly trickle about half of the can through the carb. It will stumble a little & bog but keep pouring & keep it running. When you have half of the can in & it running, dump the rest down the carb until it kills the motor. Let it set @ 20 minutes. Start it up & go for a ride. You will draw a lot of attention because your truck will smoke up a storm. Drive it until you cant see the smoke & you will be sold... Also a splash in your mower in the fall is better than any stabil because it doesnt gum anything up. I use it year round in small engines. Put it in a spray bottle & use it like wd-40.... Geez I sound like a salesman for the stuff, Im done...
