#26 |
Global warming is a myth
There is a vendor on CK5 that just recently started fabricating a really good looking tubular engine crossmember. He goes by "Cyberfire" over there & his website is diy4x.com.
Apparently, he's a pretty good fabricator & a damn good guy according to others that have dealt with him. I haven't dealt with him yet, but I plan to. Just FYI, Buddy
Henderson, NV 1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!! 1990 K5 with 37's 2003 Discovery SE7 - Wife's |
#27 |
Re: tubular motor mounts
yeah i would im using the front holes and tubular mounts elite headers don't fit either side
pics would be nice both sides if possible the more the better |
#28 |
back bolt hole is off about 1/4 inch what can i do to fix this problem what could i have done wrong
#29 |
any ideas anyone?
#30 |
I see a difference. I'm using poly mounts vs what you have there. My poly mounts came with the tubular mounts from performance online. Mine do not hit there.
#31 |
thats not my truck i have the poly mounts and thats were its hitting i just used the pic from the thread
if u have some pics it would be nice to have to compare to |
#32 | |
PITbut
That pic that you ahve with hitting here, mine is about .5 inch clearance.. You think thats enough room??? |
#33 |
sam e motor mounts in a 67 - i had to notch the frame as described - i am running a small block though
http://67-72chevytrucks.com/vboard/s...d.php?t=248222 Last edited by 67c-10Texas; 07-29-2008 at 05:34 PM. Reason: link not working |
#34 |
![]() Join Date: Feb 2008
Just a quick thought, Is your engine square in the engine compartment. I found with my BBC that there is enough room with the bolt holes that one side could be further forward than the other side. I installed my tubular mounts and left the bolts loose. Then measure the transmission tailshaft to ensure it was center within the frame. If your not centered shifting the transmission may provide you with the needed clearance. Good luck.
#35 | |
#36 |
Wanted to add some pics for reference (396 with Camaro headman headers...1-3/4" primaries). I also wanted to ask if anyone has found an electric fan setup that works with these mounts, big block and short waterpump? I have just under 4" from the waterpump pulley bolts to the 4 core radiator. These mounts pull the motor forward a touch more than the OE big block mounts.
You can see on the passenger side I had to clearance the frame a touch for the header, this was the only mod that I needed. I will also not that these mounts set the engine angle at 6 degrees which presents an issue that I am dealing with now. The best angle I can get with shims under the trans mount is 3 degrees which is great but I now have about 1/8 " clearance between my transmission and the tunnel (low hump).
Rottenwood Garage 1970...71...72 C1500 aka Orange aka Sideshow Bob 540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600 2 Tons of Fun |
