#26 | |
Re: Anyone have pics of their rear air bag setup?
That comment is very true, but I am sure you would agree that the bags designed ride height is one of the most critical points of setting up an air system that rides well.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#27 |
Active Member
heres mine but i think im going to change it to 4 link
#28 |
I'm almost 100% sure those are Firestone's pictured. The pewter looking top, and the color of the rubber give it away, not to mention that slam bags have the rubber going over the side of the caps.
#29 | |
tyhink im goin to do something like it
1985 GMC ( future plan pro tour build for the wife ) Black 2013 GMC single cab 4/7 drop on 24'' Torque Thrust ST ![]() ![]() ![]() |
#30 |
Junior Member
Pics of my set-up!
#31 |
nice job man! I need to get myself a tube notcher.
What route did you take with your rear disk setup? What tire size it that? and backspacing? Last edited by jlaird; 02-05-2007 at 09:39 AM. |
#32 |
Junior Member
CPP crossdrilled brake set-up F/R . 22x10 w/285 tire and a 5" backspace. Thanks!
#33 |
#34 | |
It's Better With Nitro
#35 | |
#36 |
Are you referring to the trailing arm? If so, no. I do have an adjustable panhard bar since my ride height is considerably lower than stock.
#37 |
I only wanted to be able to control my ride height so I went with 8" bags that can go up to 12" in height, I installed a top cage to make the install easy, and just bolted the air bag directly to the trailing arm and bolted it on. I inflate with a schrader valve and it works like a champ. Cost less than $200.00
http://kieth.smugmug.com/Trucks/66-G...5_pTfv9bn-A-LB |
