Old 05-02-2007, 02:38 PM   #26
gregfull
gregfull's Avatar
Re: New Project... Low 50
Originally Posted by gray776 View Post
Rear Disc Brakes...
Brackets: $70
Loaded Calipers: $66 (local Auto Parts)
Rotors: $56 (Local Auto Parts)
Total: $189
Rear Disc for under 200 bones...
How about some more info on the rear discs. Where to buy brackets, which calipers, and which rotors? Thanks for the help, seems really cheap for a rear disc setup. Thanks in advance!
My Suburban Project
72 Suburban
68 SWB
57 Belair
55 Cameo
06 Chevy 1/2 ton crew
09 Suburban
gregfull is offline   Reply With Quote
Old 05-02-2007, 03:19 PM   #27
1-ton of fun
polishing a turd
1-ton of fun's Avatar
my guess would be camaro rotors, eldorado calipers, and brackets to make it work here are a few i know about:
www.scarebird.com
http://www.steeltechsolutions.com/RE...PAGE_CODE.html
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 05-02-2007, 05:18 PM   #28
GraybealGarage
GraybealGarage's Avatar
The brackets are from a company called kingtek performance, and I got them off ebay. http://cgi.ebay.com/ebaymotors/ws/eB...m=180113049416
Then you have some options, the instructions included are very good. They explain exactly which rotors you need(5x5, or 5x4.75) and which calipers you need to match, these are actually front S10 calipers.
The rotors (5x4.75) are from a 79-81 firebird.
Jason
1971 SWB currently reconstructing...
Dropmembers, 20/22 rushforths...
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=467329
GraybealGarage is offline   Reply With Quote
Old 05-02-2007, 10:16 PM   #29
cajundragger
what size tire are you going to run on the 20's?
cajundragger is offline   Reply With Quote
Old 05-03-2007, 11:23 AM   #30
GraybealGarage
most likely 255/35/20.... just like you.
Prolly something in the 25" tall range for the front...18" rim.
Jason
Old 05-04-2007, 11:32 AM   #31
1-ton of fun
polishing a turd
what are you doing for an e-brake?
Old 05-04-2007, 11:46 AM   #32
youngrodder
youngrodder's Avatar
I converted my rear brakes to disc and I used older Cadillac calipers that have the parking brake built into the caliper. I think that they were from a 85 Eldarado or something. The core charge was steep so I picked up a set of the calipers at a salvage yard to use as my cores.
My kit was a weld on. Gray776's kit looks very clean.
Marc
youngrodder is offline   Reply With Quote
Old 05-04-2007, 01:03 PM   #33
gregfull
gregfull's Avatar
Thanks for all the info, I really appreciate it!
My Suburban Project
72 Suburban
68 SWB
57 Belair
55 Cameo
09 Suburban
Old 05-04-2007, 07:45 PM   #34
cajundragger
your going to have to do something with the rear fenders then. Im stretching the bedsides and pushing them up 2". And will add to the bottom to get them back with the running board.
Old 05-06-2007, 09:25 PM   #35
1-ton of fun
polishing a turd
i just used rear discs from a 98-02 f-body. 12 inch rotors, 1.75" PBR calipers with parking brake drums. they bolt right up to my '77 nova 8.5" 10-bolt rear. i just had to swap sides (mount left on the right, and vice versa)
Old 05-09-2007, 09:16 PM   #36
cajundragger
Im using dodge disks from a new pickup...cheap as hell and give me my bolt pattern.
Old 06-06-2007, 12:35 PM   #37
GraybealGarage
Update... Sorry guys, been busy at work... busy playing (motocross, triathlons) on weekends... Got some progress completed.
Got the wheels/tires. Foose nitrous 18x8.5 and 20x10
Tires are 235/40/18 and 285/30/20
Been working on the motor/tranny mostly lately. LS1/4l60e, and it is just about ready to mount up.
dont have pics of the motor yet, but here are a couple of the wheels/tire combo...
not as low as cajun's but close enough!
Jason
Old 06-06-2007, 08:30 PM   #38
cajundragger
niceee, yea its a PITA to get it flat...I still like 3/16 of an inch more...
Old 06-07-2007, 03:06 PM   #39
Daniel U
Daniel U's Avatar
Not exactly "Slow and low...." but low and fast is better IMO. Looking good.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 06-07-2007, 04:29 PM   #40
youngrodder
gray776-
I wish I had gone with the LS1. I went with an LT1/4l60E. I have had my motor and trans for a few years and the LS1's were almost twice as much.
Who are you using for your motor wiring harness? I am no electrician, so I went with an aftermarket harness. I chose Howell engine performance. They are somewhat local and a little cheaper then S&P. I did use S&P for all of my pullies.
I really need to get around to buying my wheels and tires as well. I have been butting it off until the end.
Again the truck looks good.
Marc
Old 06-08-2007, 12:14 PM   #41
GraybealGarage
Marc,
I'll probably go with Speartech for the wiring. They get a lot of good reviews at www.ls1tech.com He is a little more expensive than some but the quality is there I am sure. I think his website is www.speartech.com
Yeah, the LS1 is nice and you can get parts so cheap now. I was going to go with just a small block but now I am really excited about this setup.
Jason
Jason
Old 06-08-2007, 12:15 PM   #42
GraybealGarage
Daniel, I agree completely...
BTW, Your truck is looking good as well!
Jason
Jason
Old 06-08-2007, 03:12 PM   #43
cajundragger
Marc,
Jason
I was going to go with a mild 383/muncie 4 speed, and in the long run my LS1/T56 will be cheaper, more reliable, and more powerful.
