Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-20-2007, 09:47 AM   #26
RustyParts
RustyParts's Avatar
Re: Got Rust?
Keep your Tetnus shots up to date.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 06-20-2007, 02:34 PM   #27
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Re: Got Rust?
Believe it or not, I just had one about a month ago...so I'm good to go.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 06-20-2007, 09:45 PM   #28
jcfoote60
Active Member
jcfoote60's Avatar
Re: Got Rust?
when was the last time you got a tetnous shot? wow........if you only lived closer to Idaho I would give you a 72 body and great frame just to help you avoid the rust repairs...I backed away from this one but it looks like it's off the showroom floor compared to yours....dang I have never seen a northwest blazer in that condition...good luck
JC
jcfoote60 is offline   Reply With Quote
Old 06-20-2007, 10:07 PM   #29
Chevyman63
Chevyman63's Avatar
Re: Got Rust?
Originally Posted by LUV2XCLR8 View Post
So does that tub pictured have a good rear floor?
Hey Luv, how much do you need? I checked it out tonight and found that the center looks pretty good, straight and no rust, but the outsides are wasted.
Let me know.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 06-20-2007, 10:33 PM   #30
72CSTC5
72CSTC5's Avatar
Re: Got Rust?
You guys are my heros, I would not touch that thing with a 10 foot pole. The best of luck to you there buddy. Why don't you spend more money on one in good shape then spending 1,000.00 dollars in replacement panels, time, money, mig wire, grinding disc, primer, sealer, undercoating, etc. You would save a lot more money buying one in better shape and starting from there.
72CSTC5 is offline   Reply With Quote
Old 06-21-2007, 02:23 AM   #31
DURRTY
USMC
DURRTY's Avatar
Re: Got Rust?
One big reason for me is that I am a fabricator/welder and used to be a pipe welder. I have more consumables (aside from any primer paint......) than I have room for. the grand or more in sheet metal plus other parts to get it running will still get me under what an even close to rust free blazer would cost around here. South of me in AZ they know what there rust free rides are worth. Then add a ton more if the thing has a good engine and drive train. id be looking at close to 10 grand.
Mine has a bone stock but rebuilt 350 and a good drive train, all the outer sheetmetal has been replaced or patched. good top so I took it over the built up rusty ones or the high priced rust repaired ones. Plus when its done(this is the most important to me) is when I get asked did you do the work? buy it like that or pay to have someone do it? I can say HELL YES I BUILT IT and its EXACTLY how I want it.
Its going to be sixes on the money saving too. If planned out properly both ways can be cheap or expensive.
Jeff
Semper Fi
DURRTY is offline   Reply With Quote
Old 06-21-2007, 05:56 AM   #32
Chevyman63
Chevyman63's Avatar
Re: Got Rust?
Jeff
Well put!
And in addition to that, it's alot easier to lay down 10 grand over a period of 2 or 3 years, then all in 1 day. I also looked at the route of buying something in great shape, but finding this is tough to do, plus everything I found from down south still needed inner and outer rockers and sometimes more, unless you've got 12 to 20 grand to spend, and I don't. But everyone is different and this just makes more sense to me.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 06-21-2007, 02:14 PM   #33
70rs/ss
70rs/ss's Avatar
Re: Got Rust?
Well, I have mine for $4500 and I'm in AZ. It needed rockers and a floor patch (gotta love the rubber floor mats!) I have done the Driver's side inner and outer, as well as the floor patch. I need to do the passengers rocker. It has a 454 and a 4-speed/205. It is an AC truck with most of the stuff there. I think building one yourself is great if you want/can finish it. I personally am ready to sell all of my needs a little TLC's for one I can get in and drive. $10 grand is not that much money, besides I've seen some nicer ones for $6500.
70rs/ss is offline   Reply With Quote
Old 06-21-2007, 02:29 PM   #34
Chevyman63
Chevyman63's Avatar
Re: Got Rust?
I'll be there (Phoenix) in Dec., maybe I can arrange to stop by and check it out, if you still have it.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 06-21-2007, 02:52 PM   #35
70rs/ss
70rs/ss's Avatar
Re: Got Rust?
You bet, did you ever get the info on realators in AZ. I was going to find some stuff, then guys from Tucson Chimed in and I figured you were set up? It is only going to be 113-115 in Phoenix today, so bring a coat with ya!! It is normally in the 80's up here, but we may crack a 100 but with like 8% humidity it is real nice!!
Old 06-21-2007, 04:58 PM   #36
jaros44sr
jaros44sr's Avatar
Re: Got Rust?
Originally Posted by Chevyman63 View Post
Well put!
I bought mine for 700.00, then put 10,000 into it over 4 yrs. so that's not tooooo bad...I keep telling the wifey that, but she still doesn't get it. She may be coming around, bought a hot bikini to go with my truck---- life is good
I'm the only one in avery large area with a Jimmy, only saw one in 4 years
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-21-2007, 08:31 PM   #37
AJ4X4TJ
AJ4X4TJ's Avatar
Re: Got Rust?
I had lots of rust on my Blazer too. I recommend the Rhino coating. See attached pictures.
AJ4X4TJ is offline   Reply With Quote
Old 06-21-2007, 10:10 PM   #38
Chevyman63
Chevyman63's Avatar
Re: Got Rust?
Can't wait to go there. We're staying at the Fort McDowell casino just for a few days, but I will contact you before we head that way to possibly get together.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 06-22-2007, 05:34 AM   #39
jaros44sr
jaros44sr's Avatar
Re: Got Rust?
[QUOTE=AJ4X4TJ;2233074]I had lots of rust on my Blazer too. I recommend the Rhino coating.
Did you fix the rust before you had the rhino lining applied?
SAFETY FIRST
AS usual, off topic
Jim
Old 06-22-2007, 12:43 PM   #40
Chevyman63
Chevyman63's Avatar
Re: Got Rust?
I haven't decided what I'm doing with the inside yet...I have a considerable amount of time to decide though.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 06-23-2007, 06:41 AM   #41
Chevyman63
Chevyman63's Avatar
Re: Got Rust?
The donor needs inner & outer rockers and a firewall swap, but it beets the crap out of what I have. Thanks to Blazerb71 for the tub, doors and firewall. I'm finally starting to tear apart the rust machine.
Thanks for the reminder of your link Curt, I will use it for reference a lot.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 06-23-2007, 07:28 AM   #42
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Got Rust?
Nice project man!
I'm just across the river in Petrolia,Ont.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 07-01-2007, 07:54 PM   #43
Chevyman63
Chevyman63's Avatar
Re: Got Rust?
Originally Posted by BobbyK View Post
Nice project man!
Thanks...if you're ever heading towards the middle of the state, let me know, I believe I'm only about an hour and a half due west of Port Huron.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 12-30-2007, 02:55 AM   #44
vtblazer
vtblazer's Avatar
Re: Got Rust?
Alright...we need some current pics, we know you've been working on it.
Like the crate the tub is sitting on, did you make that?
vtblazer is offline   Reply With Quote
Old 12-30-2007, 03:10 AM   #45
Chevyman63
Chevyman63's Avatar
Re: Got Rust?
Yeah I built it, but after spending a lot of time measuring every mounting point on the tub and building that monstrosity, I think it was overkill. But it did make a 6 hour trip without incident.
Up to date pics soon.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 12-30-2007, 03:29 AM   #46
jaros44sr
jaros44sr's Avatar
Re: Got Rust?
Overkill is always a good thing, where's the pics? can't wait...
REEEEEAAALLLL curious to see how a w/s cowl gets mounted up
To answer your question, Nope, don't got no rust...LOL
SAFETY FIRST
AS usual, off topic
Jim
Old 12-30-2007, 03:57 AM   #47
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Got Rust?
Let me know.
TVM, But I need a complete floor
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 12-30-2007, 04:54 AM   #48
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Got Rust?
That body crate frame is awfully sweet.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-30-2007, 09:17 AM   #49
Chevyman63
Chevyman63's Avatar
Re: Got Rust?
Thanks.
I picked up the tub from a board member in Iowa, so I wanted to make sure it would make the trip safely...and it did the job. I had the whole thing screwed down to a car trailer, a little much maybe, but it worked.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 12-30-2007, 12:25 PM   #50
jojotonka
jojotonka's Avatar
Re: Got Rust?
Well Tim, Have you started tinkering yet??
Hunting season is over... I'm ready to have a wrench in one hand and a beer in the other!!!
Call me when Bodywork 101 starts, I'm ready to be schooled by the master!!
jojotonka is offline   Reply With Quote
