Old 03-02-2008, 07:05 PM   #26
RustyParts
RustyParts's Avatar
Re: 67-72 BigBlock 4x4s! Pos pics info here.
I put a 454 in my '72 Jimmy and had to do some work to the firewall on the drivers side for valve cover clearance. I cut out some of the firewall moved it towards the drivers side and rewelded it.
I also moved the engine, tranny/transfer case forward 1" for HEI clearance, didn't really have to move the engine, but the HEI was to close for my preference.
Also had to trim the frame rails for header clearance.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 03-06-2008, 04:20 AM   #27
CDA 455
MidlifeCrisisUnderWay
CDA 455's Avatar
Awesome thread!
As soon as I put the Ram Jet 502 in my '72 Blazer, I'll post pics.
DIY4X
1972 CST Blazer <---sold
CDA 455 is offline   Reply With Quote
Old 04-02-2008, 05:57 PM   #28
green724x4
green724x4's Avatar
Here is my swap.
427 bored .30 to 431 ci
Thorley = 304-Y
Moved drivetrain 7/8" forward for clearance.
Running what I believe is a oil pan out of a passanger car with stock crossmember. Som slight modifications to the firewall.
green724x4 is offline   Reply With Quote
Old 04-05-2008, 01:39 AM   #29
Virginia72SWB4X4
I'm confused about whats different between a 2WD and 4 WD when it comes to engine placement. There were BB's put in 2WD trucks.
Does the engine sit further back or higher in the engine bay in a 4WD then a 2WD?
Why the need to cut the firewall on a 4WD?
Gary
Virginia72SWB4X4 is offline   Reply With Quote
Old 04-05-2008, 08:36 PM   #30
Yukon Jack
Post Whore
Yukon Jack's Avatar
Yes, the motor in a 4wd is set further back. Probably partly for better weight transfer and partly to give a slightly longer front driveshaft to reduce it's angle.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-07-2008, 07:16 PM   #31
Virginia72SWB4X4
Thanks Yukon. I was always puzzled why the modifications were necessary.
Gary
Old 04-08-2008, 04:17 AM   #32
FormerMember
Bigger block (Cadillac!) in my former C now K40:
I used the DIY4X engine crossmember and made the engine saddles.
Squeezes in there:
Should be fun with the dual turbos...
FormerMember is offline   Reply With Quote
Old 04-26-2008, 05:04 PM   #33
hellrazrblade
Purple People Eater
hellrazrblade's Avatar
'71 Blazer w/ 3" body lift and a 396 ('69 Chevelle). It has plenty of room, and I even put in a huge Mallory HEI with no clearance issues. The hood's straight now, by the way.
1971 K5 Blazer 396ci/TH400/NP205/Dana 44/GM 12 Bolt/38" TSLs
2004 Chevy 1500 4X2 X-Cab 327ci
hellrazrblade is offline   Reply With Quote
Old 04-26-2008, 09:06 PM   #34
Yukon Jack
Post Whore
Yukon Jack's Avatar
Can you shoot a couple pics of your firewall in the valve cover area?
What engine crossmember are you using and how is your oil pan clearance?
Good looking K5 btw.
Old 05-10-2008, 05:39 AM   #35
CDA 455
CDA 455's Avatar
Here's a sneak-peek at mine and the rig the motor is going into:
DIY4X
Old 05-10-2008, 03:03 PM   #36
FormerMember
I dig the Michelin XML's. I've been looking for a set.
Old 05-10-2008, 05:21 PM   #37
Yukon Jack
Post Whore
Yukon Jack's Avatar
Tasty looking motor!!!
Old 05-11-2008, 04:04 AM   #38
Burt4x4
Burt4x4's Avatar
Hell Ya CDA that will be fun to drive!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 05-11-2008, 07:34 AM   #39
CDA 455
CDA 455's Avatar
Thanks!
I also have a set of Michelin XML 325/85R16's (39X13) as well.
DIY4X
Old 05-11-2008, 07:45 AM   #40
CDA 455
CDA 455's Avatar
Thanks guys!
Basically the only thing left to get is a fuel tank and fuel system.
I'm thinking a late model Blazer tank and a 8.1 Vortec fuel system set up.
I need baffles in the tank and a high pressure pump (40-70 PSI).
DIY4X
Old 05-11-2008, 07:48 AM   #41
FormerMember
Thanks!
Where are you getting them? I want a set for my tow rig.
Old 05-11-2008, 08:33 AM   #42
CDA 455
CDA 455's Avatar
I bought them off of eBay the last couple of years.
From a place at the International Border down in San Diego.
The skinny set I bought two years ago and the wider set I bought last year.
DIY4X
Old 05-11-2008, 08:37 AM   #43
CDA 455
CDA 455's Avatar
When I order my T-case I'll use my TH350/NP205 in the mean time.
I'm looking at the Atlas 4SP or the StaK 5.44.
DIY4X
Old 05-11-2008, 02:42 PM   #44
FormerMember
When you go Stak, you never go back.
Let me know if you can find more of the wider XML.s
Old 05-11-2008, 04:34 PM   #45
CDA 455
CDA 455's Avatar
Which StaK T-case is that?
DIY4X
Old 05-11-2008, 04:57 PM   #46
FormerMember
4 speed. It's in my Jeep.
http://www.pirate4x4.com/forum/showthread.php?t=489888
It's on topic, too... it's a BBC in a 4x4 :p
Old 05-11-2008, 09:31 PM   #47
CDA 455
CDA 455's Avatar
You mean 3 speed ?!
Why'd you pick StaK over Atlas?
The only reason I'm thinking of getting a Stak is because Atlas is going through major changes in their gear-cutting. They're bringing it in-house and I'm concerned about QA since they're starting from scratch.
DIY4X
Old 05-11-2008, 11:24 PM   #48
FormerMember
You mean 3 speed ?!
The Atlas isn't rated for our trucks. Talk to Vic. I have too much HP and too heavy a rig. Atlas = Dana 300 based t-case. Stak all new engineering.
Old 05-12-2008, 01:31 AM   #49
CDA 455
CDA 455's Avatar
Really ?!!
On their website they claim they can handle tons of torque. My rig will weigh approx. 5500LBS to 6000LBS easily (Fully loaded for a trail-run). And the Ram Jet will be doing 565FT/LBS of torque (At the crank)!
This is a first for me: Atlas = Dana 300 based t-case.
And StaK is all new engineering from the ground up?
I'm eye-balling the StaK 5.44/3.05:1 model.
BTW; Who's Vic ?!
DIY4X
Old 05-12-2008, 01:35 AM   #50
FormerMember
Really ?!!
BTW; Who's Vic ?!
Vic is one of the original owners of Atlas
When they released the Atlas, it was SWB only (Jeep, Bronco, Land Cruiser, etc). You can find pictures all over the place. It's one of the original marketing points for the NP205 derived Lomax by Novak.
Stak is it's own design, not based off a production t-case. They were also first to market with a tough 3 speed t-case, they also have proto-type four speeds out... same case.
