Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-18-2007, 11:02 PM   #26
Big J
Its lookin' like a Blazer!
Big J's Avatar
Re: "Slowly but Surely" Big J's build thread...
[QUOTE=72lb4x4;2448513]Sorry to barge in, but since the body's off could you do me a favor and snap some pics of one side of the ubolt/block/snubber/spring plate area of the rear end?QUOTE]
I think this is what your looking for.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 11-18-2007, 11:09 PM   #27
Big J
Big J's Avatar
I've about got the motor done. Put on a new oil pan, intake, dizzy, fuel pump and some other goodies. I should have it in and running tomorrow. Heres some pics of what I've got so far. The frame made a nice makeshift work bench
BAZINGA!
My Build
Old 11-19-2007, 02:54 PM   #28
72lb4x4
Perfect. Thanks!!
72lb4x4 is offline   Reply With Quote
Old 11-20-2007, 12:00 AM   #29
Big J
Big J's Avatar
Got some more done today in between all the normal weekend fun. Got the flywheel, clutch, and pressure plate on. Dropped the motor in. Put in some new plugs and wires. I still don't have them quite like I want them though. I believe everyone has that problem, lol. Friggin' plug wires. I got the starter on and as soon as the gas hit the carb it fired right up. I giggled like a little kid. I've got a question. Does anyone know if the exhaust manifold bolts have to be a special bolt or can I use any old bolt? Grade 8 or 5 or?????? Someone told me that if you use a regular old bolt that they can't take the heat and would probably break when I try to take them out later on down the road. Heres some pics.
BAZINGA!
My Build
Old 11-20-2007, 07:16 AM   #30
jaros44sr
jaros44sr's Avatar
Nice work!!! Must be great to hear it run, congrats.
Didn't know this, but Rokcrln said they are special bolts that are designed to stretch. If you find a set LMK, as I want to put a set in as well. J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-20-2007, 08:37 AM   #31
Big J
Big J's Avatar
Yeah, it was definitely good to hear it run. I had issues with the previous 350. Lots of issues, lol. Looked for some bolt kits online and came up with this:
http://store.summitracing.com/partde...5&autoview=sku
I'm still gonna call some local parts places and see what they come up with. Might be cheaper
BAZINGA!
My Build
Old 11-20-2007, 08:51 AM   #32
jaros44sr
jaros44sr's Avatar
Seems a little pricey, but it's a start. I have all 12 pt. ARP fastners so far, maybe I'll check them out. I also have to build the locking tabs to keep the bolts from backing out...
Man I wish I could hear mine run, I still have to build the exhaust and get my T/C back in then.... maybe vrooooom
SAFETY FIRST
AS usual, off topic
Jim
Old 11-21-2007, 04:57 PM   #33
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks great keep up the good work wish my blazer was in the rebuilding stage..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-21-2007, 07:51 PM   #34
chipflyer
chipflyer's Avatar
Good looking project, nice work!
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 11-22-2007, 08:25 PM   #35
Big J
Big J's Avatar
Few more things done. Got the core support on and radiator hooked up. Took a couple pieces of angle and braced it up so I don't have to worry about the fan getting into the shroud. Went ahead and put the other drivetrain together so I can mount it up on a pallet. Its about time to pull the chassis out and bring the body in.
BAZINGA!
My Build
Old 11-22-2007, 08:34 PM   #36
5150
C10 Club Tennessee
5150's Avatar
Looking good J
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 11-22-2007, 09:17 PM   #37
jamie72
jamie72's Avatar
put a bucket on it and take it for a spin!!
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 11-22-2007, 09:49 PM   #38
Big J
Big J's Avatar
Yeah, I actually thought about trying something like that . I figured I'd better spend my time workin' on the rest of it though instead of crashing what I've got done.
BAZINGA!
My Build
Old 11-27-2007, 07:31 PM   #39
Big J
Big J's Avatar
Had a busy day yesterday. Got the motor tuned in/up...... Hit the key and if fires right up everytime, I luv it! Got the tractor and boom out (man its great to have this stuff at my disposal). Stuck my other motor/tranny/x-case on a pallet and moved it out under the shed. Then I hooked up the chassis and with some help moved it under the shed. Gotta love the shed. We then pulled the other Blazer in. Yippie, time for body work! So far I'm still strippin' it. Got the doors, tailgate, and hatch off. I've still got a bunch of strippin' to do though. Dash, harness, air, column, brake booster, trim, lenses, etc. Then onto the cuttin'!
BAZINGA!
My Build
Old 11-27-2007, 08:05 PM   #40
jaros44sr
jaros44sr's Avatar
Man, you sure have been busy. Sooooo, how much rust are you looking at, rockers and floors? Is the green body the one your using? J.
SAFETY FIRST
AS usual, off topic
Jim
Old 11-27-2007, 08:39 PM   #41
Big J
Big J's Avatar
Yep, I'm using the green body. Its going to be less work than the orange one. The rocker boxes are mostly intact. Some P.O. cut a big square out of each bottom of the box to put in some steps. They also cut the corners off of the wheel openings. Other than that its solid, except for a little bit of the floor pans and rockers. The windshield frame and bedsides are nice. I do have a large dent to pull on the drivers side but thats no biggie.
BAZINGA!
My Build
Old 11-27-2007, 09:19 PM   #42
jaros44sr
jaros44sr's Avatar
Not to bad, I've seen worst. In my workshop
That 'B' post hides alot, whole bunch of layers there. Good luck on your build
SAFETY FIRST
AS usual, off topic
Jim
Old 11-28-2007, 07:07 AM   #43
vtblazer
vtblazer's Avatar
Pretty typical pillar/rocker rust out but definitely fixable.
Faced one similar to yours once myself.
vtblazer is offline   Reply With Quote
Old 11-28-2007, 08:34 PM   #44
byrd
Union Electrician
byrd's Avatar
Man you sure are getten r dun
The blazer looks great!!! I really like the lift and the stance, rockin!!
It was nice to see you again, and god luck with the rest of the build.
I guess I really should get over here on the blaze board more often
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 11-29-2007, 10:17 PM   #45
Big J
Big J's Avatar
Yep, fun stuff. It actually is relaxing to go over and work on the blazer. Thanks for the bumper! Now I just need a front one and a cowl hood and a grill and and and......
BAZINGA!
My Build
Old 12-04-2007, 11:02 PM   #46
Big J
Big J's Avatar
Had some fun this weekend... Went up to Alvin's and picked up a sweet set of doors. If anyone is in need of a cab or a SWB he's got some good stuff.
I worked on the blazer for awhile today. Still stripping... Got the heater box, column, dash, wiper motor, and the lenses off. On to the pics...
BAZINGA!
My Build
Old 12-05-2007, 05:42 AM   #47
jaros44sr
jaros44sr's Avatar
That tub looks really nice, good progress! Do you have your new patches yet? Nice workshop ya got... J.
SAFETY FIRST
AS usual, off topic
Jim
Old 12-05-2007, 09:02 AM   #48
Big J
Big J's Avatar
I have most of what I need but theres still a couple things to pick up. The tubs in pretty good shape, still alot of work to do though, lol..... Well the workshops not mine. I help build it and it is right across the yard. Its my neighbors..... I've outfitted it with all my tools, I get free use of the shop, he gets use of my air and mig.... Real nice people.
BAZINGA!
My Build
Old 12-05-2007, 09:38 AM   #49
jaros44sr
jaros44sr's Avatar
Nice to have good neighbors, real important!! What kind of stuff does he work on?
SAFETY FIRST
AS usual, off topic
Jim
Old 12-07-2007, 09:33 AM   #50
Big J
Big J's Avatar
He likes to tinker. We just built a winch mount and a plow mount for his sons atv and finished up the brake lines and gas tank on his wifes S10. Now hes tearing down a tractor and fixing the guard on his mowing machine. The shop moto is if its broke we can fix it, or make the problem worse then bring in someone who knows how, lol......
BAZINGA!
My Build
