Old 03-03-2009, 10:02 PM   #26
Cherub
Cherub's Avatar
Re: Cherubs 82 build
Getting everything tied up this weekend so i will hopefully have a video for ya.
The bed, front core support, light were all put back together.
Cherub is offline   Reply With Quote
Old 03-04-2009, 09:43 AM   #27
tvblazer78
Low & Fast!
tvblazer78's Avatar
Sweet!! We love videos!
tvblazer78 is offline   Reply With Quote
Old 03-04-2009, 01:30 PM   #28
menace121978
menace121978's Avatar
right on man! your living my dream!LOL
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 03-17-2009, 09:06 AM   #29
Cherub
Cherub's Avatar
Ok After two weeks of checking and double checking the wiring ive got the engine to crank over. It still wont start though. So now im going to chase that down.
The truck is almost all back together just need to install the grill and align the bed.
Old 03-17-2009, 11:22 AM   #30
HotRod73
HotRod73's Avatar
I saw you had the wiring sent to get reworked, so you did remove the security crap right? I know that will keep it from running. Just a thought, I don't know squat about these swaps but I have read about that before. I hope to do a swap like this some day
1973 Chevrolet C20 (Under Construction)
HotRod73 is offline   Reply With Quote
Old 03-17-2009, 02:31 PM   #31
Cherub
Cherub's Avatar
Yea i told them to remove the vats when i ordered the tune. Is there a way to tell if they've been done?
Old 03-17-2009, 04:37 PM   #32
HotRod73
HotRod73's Avatar
I have no idea but im sure someone else will post up and let you know, I just know i have read about this before and a few people had this problem on different boards.. I cant wait to do this swap!
Old 03-17-2009, 04:38 PM   #33
HotRod73
HotRod73's Avatar
Btw are you sure its a wiring issue? Have you checked all the basics, spark fuel etc... could be something else causing your problem?
Old 03-17-2009, 04:39 PM   #34
HotRod73
HotRod73's Avatar
also maybe that replacement coil pack they sent you may be bad?? just some thoughts....
Old 03-17-2009, 04:56 PM   #35
Cherub
Cherub's Avatar
I checked spark, and Im getint fire. I checked fuel, and im getting 40 psi. Im going to check everything again and see if i missed something.
side note i dont have the maf sensor or o2 sensors hooked up. regadless it should turn on and idle correct?
Old 03-17-2009, 05:02 PM   #36
menace121978
yes it should still fire w/o the maf and o2's. but its the 40psi that worries me.
if im not mistaken you need 58psi on the fuel. i'm gonna look into this on ls1truck and see what i can find out. but i'm almost positive ive read that the motor wont fire if under a certain psi which i think is 58. Dennis
"Dennis the Menace"
Old 03-17-2009, 05:16 PM   #37
menace121978
ok, i have the book "how to swap ls engine in anything" and it says here that you need at least 58psi at the fuel rail. if not the motors gonna have a serious lean condition if it even runs at all.
what pump are you running? and double check your lines for leaks
"Dennis the Menace"
Old 03-17-2009, 08:05 PM   #38
HotRod73
HotRod73's Avatar
Thats what i was thinking, either fuel or the vats in his wiring... I also thought maybe that coil pack they sent him was bad but thats was ruled out... Good luck on fixing your problem hope you get her fixed up really soon, if your like me your dying to drive it!
Old 03-18-2009, 07:59 AM   #39
Cherub
Cherub's Avatar
Im running the AC Delco EP 241 intank fuel pump. I am running an-8 fuel feed line.
Im going to double check for leaks and then Retest to see if IM getting the required 58. Cool cool cool gives me a place to start
Old 03-18-2009, 08:03 AM   #40
menace121978
right on man! keep us posted...
"Dennis the Menace"
Old 03-19-2009, 07:42 AM   #41
Cherub
Cherub's Avatar
Some update. Called Nelson Performance and they removed the Vats and there is not relearn that needs to be done. Also mentioned like yall have said to check my fuel pressure.
I didnt get to check the fuel pressure but i did find a leak at the fuel filter. I would assume this is the culprit.
Old 03-19-2009, 10:45 AM   #42
HotRod73
HotRod73's Avatar
Well get that puppy fixed and fire her up hopefully thats your problem
Old 03-19-2009, 08:10 PM   #43
Cherub
Cherub's Avatar
I appriciate everyone that helped and shot me some ideas and suggestions. This clip is straight header.
LOL i got a few neighbors to come over after i started it up a few time.
Old 03-19-2009, 08:41 PM   #44
menace121978
oh my! dude you just made my day and put a big ass grin on my mug!!! that is pure music... awesome job man. hopefully by summer i'll have my chassis, brakes, and suspension done and be getting everything together for the swap. congrats man well deserved.
"Dennis the Menace"
Old 03-20-2009, 10:20 AM   #45
HotRod73
HotRod73's Avatar
Sounds awesome man!
Old 04-06-2009, 08:34 PM   #46
Cherub
Cherub's Avatar
Some pics of my progress. I went with a 6 drop on the front with 255/50/17. Well it looks good but rubbing bad.
Old 04-06-2009, 08:47 PM   #47
Cherub
Cherub's Avatar
Well i picked up some coys but i sold them to a local guy, i didnt care for the polish quality. So im just polishing up my existing wheels.
Well i picked up some second row tahoe seats......yea they dont fit so im going to hold on to them maybe i can use them later.
Old 04-06-2009, 09:08 PM   #48
flamingbig10
6.0 powered square
flamingbig10's Avatar
nice truck, good job, the stance is killer, and the wheels cleaned up nicely
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-08-2009, 12:45 PM   #49
OrangeAnimal
OrangeAnimal's Avatar
What did you get the LS motor from? Also once you got it running did you have the MAF and the O2's hooked up? I would love to get a LS6 in my truck but that would be years from now unless the engine I put in blows. HHMMMM....
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold
93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs.
09 Yaris wife's daily.
OrangeAnimal is offline   Reply With Quote
Old 04-08-2009, 01:14 PM   #50
Cherub
Cherub's Avatar
The motor came from a 2003 hd2500. It has the LQ4 designation. I went with this motor cause it was the biggest bang for the buck. With alot of performance parts available. Yea all the sensors are hooked up minus the cats. I had all the emissions stuff deleted from the ECM.
I need to get somepics of the engine bay.
